Milan ATI
mfro
Re: Milan ATI
Postby mfro » Mon Apr 10, 2017 5:10 pm
joska wrote:
mfro wrote:If the Milan's startup sequence is similar to that in FireTOS (which is what I assume), the emulator is only needed to run the card's BIOS once for basic initialization.
The problem is that the x86 emulator spend around 30 seconds to run the VGA BIOS on a Milan060. I haven't even tried on a 040... And this is done on every (re)boot, which is quite annoying.
BaS_gcc contains the x86 emulator from FreeBSD (which is slightly faster than the one in FireTOS which originates from U-Boot AFAIK). The one from FreeBSD - obviously inspired from the knowledge that gcc doesn't optimize too well with lots of global variables - wraps the emulator state variables into a large struct and passes a pointer to it into all its functions. On my m5484 evaluation board (200 MHz), it takes about 2 seconds to execute the ROM BIOS (but this will vary for different cards as well, I have one where it takes remarkably longer).
I don't know about the Milan, is it an auto folder program or executed from ROM? If the former, it might be possible to adapt it to your hardware and give it a try.
Re: Milan ATI
Postby joska » Mon Apr 10, 2017 5:47 pm
The emulator runs from ROM, before TOS is executed.
PeterS
Re: Milan ATI
Postby PeterS » Tue Apr 18, 2017 7:55 pm
I think the x86 emu is in the bootblock part of the ROM, which is 44k, is that big enough for the emu ?
The Rage board I have is labelled ATi D33053 RV6P NB3. I can't remember how long I waited when I tried it but it didn't seem to boot the graphics at all.
PeterS
Re: Milan ATI
Postby PeterS » Sun Sep 30, 2018 12:17 pm
With my Milan in 60MHz I gave the Radeon card another go but after 5 minutes no screen display and the monitor says there is no input. :-(
I assume from this that the Radeon is not starting.
mfro
Re: Milan ATI
Postby mfro » Sun Sep 30, 2018 1:56 pm
PeterS wrote:I think the x86 emu is in the bootblock part of the ROM, which is 44k, is that big enough for the emu ?
I wouldn't think so. The code I have is roughly double the size.
PeterS
Re: Milan ATI
Postby PeterS » Tue Oct 02, 2018 10:12 am
It could be compressed but 2:1 might be a bit much.
It did occur to me that I have never tested this card in a PC so I am assuming it works at all.
Return to “Hades / Milan”
