USB HxC Floppy Emulator and RaspberryPi
Jeff_HxC2001
Postby Jeff_HxC2001 » Wed Sep 18, 2013 7:15 am
USB HxC Floppy Emulator and RaspberryPi TCP/IP Network Floppy Emulator : control & upload through a web browser
http://www.youtube.com/watch?v=wJEekEhZtD8
:D
Re: USB HxC Floppy Emulator and RaspberryPi
Postby Dal » Wed Sep 18, 2013 10:53 am
Nice solution! :)
alexh
Postby alexh » Wed Sep 18, 2013 1:19 pm
Yeah. Very nice.
May I make a suggestion? You have implemented control of the USB HxC Floppy Emulator via a webpage. How about controlling the USB HxC Floppy emulator using the host? Via an equivalent of the HxC Floppy Emulator Manager? That would make the system headless.
Actually thinking about it, perhaps that would be too much work. People who want that functionality could use the SD card version.
evil
Postby evil » Wed Sep 18, 2013 3:07 pm
Jeff_HxC2001 wrote:USB HxC Floppy Emulator and RaspberryPi TCP/IP Network Floppy Emulator : control & upload through a web browser
Nice choice of background music, must be from a great demo... :roll:
Postby DrCoolZic » Sun Nov 02, 2014 4:53 pm
Where can we find the software for the RPi ?
Just to make sure this would work with HxC Rev C ?
Jeff_HxC2001
Postby Jeff_HxC2001 » Tue Nov 04, 2014 6:36 am
DrCoolZic wrote:Where can we find the software for the RPi ?
For the Rev C ? This is just the normal software :
http://sourceforge.net/projects/hxcfloppyemu/
Just checkout this on the RPi
http://sourceforge.net/p/hxcfloppyemu/code/HEAD/tree/
and add fltk http://www.fltk.org/index.php (1.3.x) into the "HxCFloppyEmulator_software\trunk\sources\thirdpartylibs\fltk\fltk-1.3.x" folder
enter the "build" folder and do a "make all"
You may need to add some X11 devel library (some apt-get to do...)
Note : All plateforms share the same hxc software : Windows, PC Linux , Rpi Linux (or other Linux board), Mac Os X...
You can also get the latest pre compiled version there :
http://hxc2001.com/download/floppy_driv ... t_beta.zip (Windows + Mac OS X)
Postby DrCoolZic » Tue Nov 04, 2014 8:20 am
Thanks I will look at that.
Stupid question: Do you think it would be possible / easy to add the RPi Web server software on Jookie CosmosEx device?
So just connect the USB HxC on one of the USB port of the RPi in CosmosEx and be able to control it from Web!
Jeff_HxC2001
Postby Jeff_HxC2001 » Tue Nov 04, 2014 11:36 pm
DrCoolZic wrote:Thanks I will look at that.
This shouldn't be a problem : This is just some CGI scripts and programs calling the command line version of the hxc software (hxcfe).
the server used is lighthttpd
Postby DrCoolZic » Wed Nov 05, 2014 8:35 am
I guess you also need a driver for HxC USB ?
Jeff_HxC2001
Postby Jeff_HxC2001 » Thu Nov 06, 2014 6:54 am
DrCoolZic wrote:I guess you also need a driver for HxC USB ?
Yes sure ! It use the libftdi driver :
http://www.intra2net.com/en/developer/libftdi/
JimDrew
Postby JimDrew » Wed Nov 12, 2014 7:18 pm
You can use this same library to access and control the SuperCard Pro board, as it uses the FTDI 240X FIFO chip.
I am the flux ninja
