Atari PCH204 help needed
All discussions about the Atari 8bit range of machines.
KLund1
Postby KLund1 » Wed Nov 19, 2014 6:50 am
Hi Everyone,
Not sure if this is the right forum for this. It is for an Atari 8-bit computer, just not a 6502 based machine.
I have a working Atari PC1. All seems good with it. But I have a matching but sick Atari PCH204 Hard Drive unit. The actual drive that came with it, an Epson HMC-755 is completely dead. So I trolled ebay and found a similar sized drive, a Seagate ST351A/X. I've have jumppered it several ways and the PC1 will not recognize it. I do not get a 1701 error any more (as when the Epson was installed). But Fdisk from DOS 3.3 reports no fixed disk attached. The drive spins up fine. Perhaps this drive is just not compatible. But the specs show that it is ok for XT and AT uses. I'm assuming the PC1 is an XT clone with some internal upgrades from Atari. I was thinking I need to use the DEBUG command in Dos to low level format this HD, but I have no clue as to what parameters/switches to use. I have received some limited help from VintageComputers.com but nothing that really helps.
Any thoughts, suggestions or ideas?
(I'm going to post this over at Atari-Age 8-bit & ST forums too)
Return to “The Atari 8bit corner”
