EtherNat direciion on CT60
Rustynutt
Postby Rustynutt » Thu Apr 27, 2017 10:22 pm
Couldn't find a photo or docs on which direction the EtherNat is fitted atop the CT60. Photos I've seen look to be a newer version.
Comments? (no, have not powered up yet :) )
Re: EtherNat direciion on CT60
Postby mikro » Fri Apr 28, 2017 12:34 pm
Here you have one, surprisingly from Nature's homepage:
So you're holding it exactly the opposite way. ;)
Btw one has to be really careful with fitting -- I once fried mine just with fitting it one pin to the left (yep, didn't double check before powering on!)
Rustynutt
Postby Rustynutt » Fri Apr 28, 2017 3:54 pm
Had it the other way, noticed in the photo it had been rotated. Did find one single photo on all of Google like this rev. Been using 30mm extensions working with the SV :)
Did the same with a CT60 AND motherboard having the ST RAM module offset, that hurt.....down there with a magnifier and flash light every time now.
Return to “CT60 / CT63 Area”
