MINT and Falcon
fidzen
MINT and Falcon
Postby fidzen » Sun Jul 24, 2016 7:39 pm
Hi all.
I have a Falcon 030 with CT63 and SV that I run with TOS and Magic6.
With a absence from the Atari community for almost 17 years I have missed a lot,
and are trying to catch up.
One thing that I see people talking about is MINT, and I wonder what that is,
what its good for and how to install it?
Thanks in advance.
BR
Fredrik
Atari 2600 4-switch Woody
jfl
Re: MINT and Falcon
Postby jfl » Sun Jul 24, 2016 9:18 pm
MiNT (known as FreeMiNT nowadays) is an operating system originally from Atari and later released as free software and still developed by volunteers. One could describe it as a multitasking TOS with some (good) Unix compability. MiNT and MagiC are mostly compatible in their TOS-like behaviour, and depending on your use case you might prefer one over the other. See here for more details.
Jean-François
GEMDict – GEMClip
Playmobil
Re: MINT and Falcon
Postby Playmobil » Sun Jul 24, 2016 9:46 pm
Under Mint you can do somthings like that ! :lol:
Sorry for my poor english
fidzen
Re: MINT and Falcon
Postby fidzen » Mon Jul 25, 2016 11:03 am
So is MINT something I can run parallel with TOS and Magic6?
Or do I need to have a MINT only system?
Anyone here that has a link to a good start package of MINT for Falcon?
Thanks in advance.
frank.lukas
Re: MINT and Falcon
Postby frank.lukas » Mon Jul 25, 2016 11:58 am
jfl
Re: MINT and Falcon
Postby jfl » Mon Jul 25, 2016 12:17 pm
fidzen wrote:So is MINT something I can run parallel with TOS and Magic6?
You can certainly install MiNT alongside MagiC (TOS being in ROM it's always there) and boot into either of them (or even TOS) by using a traditional boot manager. Both OSes are executed from the AUTO folder. MagiC then looks for its data in C:\GEMSYS (I think, I've never used it) and MiNT in C:\MINT. So if you're careful not to mix stuff up you should be fine having both installed.
Jean-François
GEMDict – GEMClip
fidzen
Re: MINT and Falcon
Postby fidzen » Mon Jul 25, 2016 6:48 pm
Is it possible to install MINT on any partition, for example H: or U:?
I understand that this partition needs to be created as a LNX partition.
Thanks in advance.
calimero
Re: MINT and Falcon
Postby calimero » Mon Jul 25, 2016 6:58 pm
Playmobil wrote:Under Mint you can do somthings like that ! :lol:
you can do same with MagiC :P
Linux partition is optional. You need it only if you would like to run Unix/Linux programs. Otherwise, everything is installed on C: (or any other partition if you hardisk-driver allow boot from other partitions)
btw what happend with VanillaMint?
Re: MINT and Falcon
Postby wongck » Mon Jul 25, 2016 11:37 pm
Sorry but I cannot support MagiC properly, just that some stuff on Network is inferior to Mint.
May be I do not research enough, I do not know.
Also I have issues running MagiC (read here)... so i try not to use it at all and therefore lack of further researching.
(To be fair, it's on my HDD but just don't use it).
Re: MINT and Falcon
Postby joska » Tue Jul 26, 2016 7:47 am
calimero wrote:btw what happend with VanillaMint?
Very little, but you can still find it here :)
I have done some work on it, e.g. it now has a GEM-based screen resolution tool so no manual editing of config files is necessary. However, I have not updated the "distribution" yet. I'm currently busy with some hardware projects, but will - hopefully! - pick up my software projects again this autumn/winter.
jfl
Re: MINT and Falcon
Postby jfl » Tue Jul 26, 2016 8:38 am
fidzen wrote:Is it possible to install MINT on any partition, for example H: or U:?
You can't install on U: because it is a pseudo drive created by the system (MagiC actually adopted this 'Unified Drive' approach from MiNT).
As already mentioned you only need a special partition (generally ext2) if you intend to install a full blown Unix-like FreeMiNT system (with compilers, shells and the like). If you don't, you'll be fine with just the kernel (MINT.PRG), the AES (XaAES or MyAES) and a decent desktop.
Basically, a simple FreeMiNT setup isn't that different from a MagiC one. Both systems mostly tried to keep compatible and influenced each other over the years.
Jean-François
GEMDict – GEMClip
Re: MINT and Falcon
Postby joska » Tue Jul 26, 2016 9:09 am
If you want to use MiNT to multitask GEM applications and maybe get online with GEM-apps like Troll or Litchi you can try my VanillaMiNT which is an easy way to get started. No special partitions needed.
calimero
Re: MINT and Falcon
Postby calimero » Tue Jul 26, 2016 11:50 am
I also vote for joskas VanillaMiNT!
It is perfect starting point!
@wongck I did not know that you have such bad experience with MagiC and did not know that your internet software does not work on MagiC! (MagiCnet can not help?)
fidzen
Re: MINT and Falcon
Postby fidzen » Tue Jul 26, 2016 2:07 pm
I have installed VanillaMINT now but I get messed up graphics when Terradesk should appear.
I have tested different settings in the xaaes.cnf, but without any luck.
I have NVDI version 5.03, is that to old or should it work?
I also wonder if it's possible to run VanillaMINT with CT63 card Supervidel?
Thanks in advance.
Re: MINT and Falcon
Postby wongck » Tue Jul 26, 2016 2:37 pm
yes, I believe it was due to MagiC. With Mint I have not any HDD being trashed.
(I did have some IDE failures on my FB, but that turned out to be the original Falcon IDE ribbon was bad )
Some of my software should work, like PHGmap as I did test that on my MagiC setup and also someone (frank?) would like to have it on MagiC.
I cannot remember which software I tested on MagiC & which not, but I know for sure not all of them.
IIRC, MagiC did not implement non-blocking networking among some other netwrok stuff.
And I had to change my code to make it work, may be not all my program have this workaround.
Re: MINT and Falcon
Postby wongck » Tue Jul 26, 2016 2:45 pm
fidzen wrote:I have installed VanillaMINT now but I get messed up graphics when Terradesk should appear.
Thanks in advance.
Should be the mode code needs changing. I do not have some used by Supervidel but I have for the CTPCI.
May be they will work. They are listed here
https://sites.google.com/site/probehous ... lling-mint
Re: MINT and Falcon
double post
Re: MINT and Falcon
Postby joska » Tue Jul 26, 2016 7:18 pm
fidzen wrote:I also wonder if it's possible to run VanillaMINT with CT63 card Supervidel?
You need to replace the kernel (mint030.prg and XaAES module (xaaes.km) with the 060-versions for the CT6x. VanillaMiNT is for the plain Falcon030 and TT without graphics cards. Also, XaAES (and thus VanillaMiNT works fine on the SuperVidel, but I don't know how the SuperVidel modecodes works.
fidzen
Re: MINT and Falcon
Postby fidzen » Tue Jul 26, 2016 8:05 pm
Hi.
I tested to replace the mint030.prg with the mint060.prg from the Easymint package,
and also took the xaaes060.km from this package and replaced the one in your package.
When I reboot I get some errors about missing files and so on.
Do you know how to get your VanillaMint to work with the CT63 and the SV-card?
Thanks in advance.
Fredrik
Re: MINT and Falcon
Postby joska » Tue Jul 26, 2016 8:25 pm
Sorry, I don't have a CT6x. But it sounds like you've mixed files from different versions of MiNT.
fidzen
Re: MINT and Falcon
Postby fidzen » Tue Jul 26, 2016 8:35 pm
I just tested to move the 060.files from Easymint to Vanillamint, but it didn't work.
So as I have understood I need to run the Easymint package to be able to run with 060?
I managed to install Easymint, but your package is much easier to handle and setup.
Re: MINT and Falcon
Postby joska » Tue Jul 26, 2016 9:01 pm
No, you don't need to use EasyMiNT with the 060. You "just" need the correct files from freemint.org. That means downloading FreeMiNT 1.18 (which IIRC is the version I used in VanillaMiNT) and replace mintXXX.prg and xaaesXXX.km files with the 060-versions.
Or you can install EasyMiNT :) EasyMiNT is a bit complex though, as it attempts to implement a unix-like bootup sequence.
calimero
Re: MINT and Falcon
Postby calimero » Tue Jul 26, 2016 10:15 pm
I install both (first easymint 1.17), than vanillamint 1.18 and than replaced some files with 1.19. :D and added ct060 and supervidel files and svethlana files :)
My main problem is that I can not choose betwen xaaes and myaes... I love both and there is no clean winner so I switch betwen them (same with tera deak and jinnee).
Btw
It would be nice to have ONE web site (or wiki) with all relevant information regarding actual atari software. We are small community and it should be not complicated to have one central place with actual information... Atari forum wiki is good as wiki (as a plarform) can be.
calimero
Re: MINT and Falcon
Postby calimero » Tue Jul 26, 2016 10:21 pm
Btw
Playmobile, what you have install for sidebar and taskline and what desktop and aes do you use?
Re: MINT and Falcon
Postby Dal » Tue Jul 26, 2016 11:19 pm
Btw
There is no sidebar? I can just see a vertical column of icons on the desktop on the left hand side ;)
As for taskbars:
ZTask (By Zorro): http://the.zorro.free.fr/ztask.html
Taskbar (By Joska): http://atari.nvg.org/Taskbar/ <<<---- There appears to be a permissions issue on Jo's server right now though?
Return to “CT60 / CT63 Area”
