CT60e ?
jvas
CT60e ?
Postby jvas » Fri Nov 21, 2014 7:10 am
Re: CT60e ?
Postby joska » Fri Nov 21, 2014 7:35 am
Yes, I heard about this a few weeks ago. I will almost for sure buy one.
jvas
Re: CT60e ?
Postby jvas » Fri Nov 21, 2014 8:17 am
Me too. My current setup can't go above 70Mhz if the SuperVidel is attached. Without it 90+Mhz is ok. I know, that the BUS of the CT60 is a little bit noisy. Maybe this one will solve this problem too....
Re: CT60e ?
Postby Dal » Fri Nov 21, 2014 11:22 am
Very interesting. I wonder who's building it - Lotharek maybe?
Re: CT60e ?
Postby shoggoth » Fri Nov 21, 2014 11:44 am
Definitely want one. Or two.
AdamK
Re: CT60e ?
Postby AdamK » Fri Nov 21, 2014 12:15 pm
No, it's not by Lotharek.
It is a guy that goes by the nick of Willy. He will be present at SV2K14, so anyone intrested can meet him there.
Scarlettkitten
Re: CT60e ?
Postby Scarlettkitten » Sun Nov 23, 2014 12:07 am
This could be my chance go get an 060, yay.
Music gear
alexh
Re: CT60e ?
Postby alexh » Thu Dec 04, 2014 4:17 pm
I do hope someone on Atari-Forum tries to arrange a group buy. I know my Falcon would appreciate one.
Re: CT60e ?
Postby Cyprian » Thu Dec 04, 2014 4:36 pm
Hi All, a full thread about new CT60 clone you can find there: http://www.atari.org.pl/forum/viewtopic.php?id=12263
calimero
Re: CT60e ?
Postby calimero » Thu Dec 04, 2014 11:08 pm
AdamK wrote:No, it's not by Lotharek.
he made some nice USB to DB-9 mouse adapters.
right now I am using wireless Logitech USB mouse on Falcon :)
HuggyOne76
Re: CT60e ?
Postby HuggyOne76 » Fri Jan 16, 2015 10:49 pm
Some news from the "CT60e" ?
Re: CT60e ?
Postby Dal » Fri Jan 16, 2015 11:40 pm
I emailed him actually. He says it's delayed by around 2 months and he gave me his word he will be announcing here as well as everywhere else ;)
HuggyOne76
Re: CT60e ?
Postby HuggyOne76 » Mon Jan 19, 2015 6:34 pm
Nice ! Thank you for this information ! :D
MacFalcon
Re: CT60e ?
Postby MacFalcon » Fri Jan 30, 2015 10:53 am
Yeah, good news! I also want one :)
Falcon060, 100/25 MHz, 256 MB SD-RAM, PhantomPBS, CTPCI with Radeon, USB and Network Card. atari rulez!
instream
Re: CT60e ?
Postby instream » Sat Jan 31, 2015 10:26 am
A few days ago I had a short email exchange with Willy, and he said that he is almost at the end of the new layout. Functionally the CT60e will be the same as the CT60, which bodes well for compatibility. My brother and I have promised to help him check the layout and schematic before production.
ctirad
Re: CT60e ?
Postby ctirad » Sat Jan 31, 2015 11:29 am
Are there any drawings of the final PCB?
The original CT6x mechanical design is horrible. I never understad why (if the original PSU has to be removed anyway) the board is not designed to fit the whole PSU area and it is packed under the keboard instead.
The proper mechanical design should use the original PSU area completely, its mount holes to secure the board and reuse the AC input and PSU switch holes for switches and connectors. Also there will be lot of room for stacking additional cards. The bigger PCB could have all the 3.3V,5V and 12V DC-DC onboard and just chap external notebook PSU instead of expensive picoPSU or big ATX. The ethrenet and USB could be fitted as option with the connectors on the back side, perhaps a new IDE as well.
Re: CT60e ?
Postby joska » Sat Jan 31, 2015 1:08 pm
I agree, the CT60 layout could be better. And I hope that the new version has soldered-in RAM and not a socket, that would save a lot of space.
That said, I'm going to buy one anyway :)
Re: CT60e ?
Postby Dal » Sat Jan 31, 2015 2:44 pm
if the CT60e does get positioned in place of the old PSU, then an integrated PicoPSU would be nice with the DC socket positioned so that its accessible where the old mains socket used to be.
ctirad
Re: CT60e ?
Postby ctirad » Sat Jan 31, 2015 11:02 pm
joska wrote:And I hope that the new version has soldered-in RAM and not a socket, that would save a lot of space.
Yes, and the 128MB of directly soldered SDRAM would be probably chepaer than the DIMM socket. :wink:
instream
Re: CT60e ?
Postby instream » Sun Feb 01, 2015 3:11 pm
In the first email from Willy on October 2nd 2014 he says this:
"Finally i have bought rights from R.Czuba for production and modification of CT60.
The new verrsion will be called CT60e (e = evolution). It should be 100% electrical compatible with CT63 (CT60_3), use same CPLD code etc.But improved mechanically (moved 30mm UP, the pcb is 30mm larger, instead of use "Falcon Bus Extender" or whatever it's called) and maybe more.
R.Cz. attached also some emails about impedance match on CT60, glitches etc. from You."
So it does sound like he will extend the CT60e so it reaches over the PSU area. Wether he will have soldered SDRAM is not mentioned. Having an integrated picoPSU is mostly negative in my opinion since all PSUs sooner or later die, and then you would have to repair your CT60e yourself by soldering.
Scarlettkitten
Re: CT60e ?
Postby Scarlettkitten » Sun Feb 01, 2015 4:11 pm
I'm really looking forward to this new CT60e :)
Music gear
ctirad
Re: CT60e ?
Postby ctirad » Tue Feb 03, 2015 2:27 pm
instream wrote: Having an integrated picoPSU is mostly negative in my opinion since all PSUs sooner or later die, and then you would have to repair your CT60e yourself by soldering.
There is no reason why the DC-DC converters should die, except the case when extremely crappy caps are used. Anyway, it is a common practice to have one master AC board with single DC ouput and then several DC-DC coverters for all the needed voltages onboard. It is on every PC motherboard, LCD, TV, notebook or DVD player. There is really nothing to worry about.
Re: CT60e ?
Postby exxos » Tue Feb 03, 2015 5:13 pm
I gave up with those PicoPSU's. Everyone I tried either did not work from new, or blew up :( I never "got" how they seemed to be working out the power for it. As if you have a 50W PSU and used 3.3V 8A thats only 26watts. So they say all is good.
But 50watt PSU at 12V is only 4amps. According to the "designer" that will work fine. I asked , well how they getting 8amps out of a 4amp PSU as they do not seem to have a step down coil, if they pulsed 12V down to 2:1 pulse transformer they could get 6V 8A which would work. But I was told they don't work that way. Am I missing something ??
I gave up looking in the end as I couldn't find proper info on them or how they were working. I think I found a much larger PSU in the end, I think that was 200watt rated, even so, the amps on the 3.3V rail were limited to about 8amps anyway. A 100watt version was limited to about 4amps. So that means to me, you need 200watts to power a 26watt load. Not actually due to wattage. but you can't get more amps than your putting in without a step down transformer.
You need 200watts 12V PSU to get 8amps 12V . 8amps at 12V simple switchmode down to 3.3V can only output up to 8amps surely ?! If there was a switchmode down to 2:1 coil, half the voltage, double the current, could get 16 amps then. down to 3V could get 32 amps. Though can't see how they manage to get 8amps out of a 4amps PSU. Unless I am missing something somewhere ??
In anycase, the 200Watt PSU I got powered my CT60 fine. Though those smaller PicoPSU things just get red hot and die. I know lots of people used them and they work fine. Though I can't understand if the 060 CPU is rated at needed 8amps, how a 50watt 4Amp input can deliver the 8amps the CPU needs. Unless those people never tested the CPU at full load. So 4amps might be enough.
Re: CT60e ?
Postby Dal » Tue Feb 03, 2015 5:56 pm
I found a 120W pico PSU and drive it with a 12V 10A supply. Works just fine.
Re: CT60e ?
Postby exxos » Tue Feb 03, 2015 6:33 pm
Dal wrote:I found a 120W pico PSU and drive it with a 12V 10A supply. Works just fine.
That sounds ok. Though i was told that if you only need 3.3V 8A, thats 26 watts, so a 50watt pico would be more then enough, that's what does not add up to me as 50W is only 4amps. Not enough to drive a 8A load.
Return to “CT60 / CT63 Area”
