some patch for steeemsse
ecureuil
Postby ecureuil » Sun Jul 28, 2013 11:40 am
Hello Steven Seagal,
You will find a patch which contains the previous update and linux one. Like the last discussion, I can not provide a 100% compilated program because there some workaround with the typing problems. I fixed someone... but it's not the last.
The patch was realeased with the svn-r81.
Next, I will open a repository too to be synchronized with the trunk and to provide an up to date fixing.
The patch will be in attachment.
Have a nice sunday , byebye
Re: some patch for steeemsse
Postby Steven Seagal » Sun Jul 28, 2013 7:21 pm
Yo
Problem is I can't apply it just like that, is there automation (ha!), is it unix, or am I supposed to do it manually? It would be error-prone.
Isn't it simpler if you submit code in the SVN repository at sourceforge:
https://sourceforge.net/projects/steemsse
I think you just need to click somewhere, I get an email, I add you.
Not to forget
http://code.google.com/p/steem-engine/
but nothing moved there since I uploaded "SSE" 3.3.
Steem SSE: http://ataristeven.exxoshost.co.uk/Steem.htm
ecureuil
Postby ecureuil » Sun Jul 28, 2013 7:49 pm
Steven Seagal wrote:Yo
Not Necessarily, You can use tortoiseSVN.
Steven Seagal wrote:Isn't it simpler if you submit code in the SVN repository at sourceforge:
Not to forget
Thank you !!! I will send a mail via sourceforge panel. :cheers:
Postby Steven Seagal » Thu Aug 01, 2013 11:10 am
I don't use tortoiseSVN, I use plain SVN, it's quite easy (now).
I see you've uploaded your patch. It was the easiest way.
If you're a linux boy, don't hesitate to take matters in hands, what I do for linux is the strict minimum.
ecureuil
Postby ecureuil » Fri Aug 02, 2013 7:28 pm
Steven Seagal wrote:I don't use tortoiseSVN, I use plain SVN, it's quite easy (now).
With svn , it's merely :
 svn patch yourpatch.patch
I'm not a linux boy nor a windows boy or what's else.
Just interesting to compile with the different compilers which are in src repository to improve the code in backstage stuff.
Postby Steven Seagal » Sat Aug 03, 2013 6:02 pm
ecureuil wrote:I'm not a linux boy nor a windows boy or what's else.
But you're a Steem boy hopefully? :)
ecureuil
Postby ecureuil » Fri Aug 09, 2013 12:48 pm
May be ;)
Return to “Development”
