N.AES
lp
N.AES
Postby lp » Tue Mar 15, 2016 7:16 am
I have patched N.AES in theory if some brave soul wants to test it. Direct link:
http://gfa.atari-users.net/atari/html/n_aes.htm
Note: I only provide a single patched file (n_aes_fb.sys). You will need the RSC file(s) from your original N.AES v2.0 disk.
Technical bits:
I fixed one move.b (sp) and two TAS instructions. Requires FireTOS/CF68KLib.
I was able to test it on ARAnyM. The desktop comes up and all seems ok.
Re: N.AES
Postby shoggoth » Wed Mar 16, 2016 2:30 pm
I tested it on the Firebee. As far as I can see, it works! Hats off!
Re: N.AES
vido
Re: N.AES
Postby vido » Wed Mar 16, 2016 2:37 pm
shoggoth wrote:I tested it on the Firebee. As far as I can see, it works! Hats off!
Wooow! This is really great!
Good work Lonny. This is really nice and usefull contribution for the FireBee users.
I really liked N.AES running it on my Falcon in the past ...
lp
Re: N.AES
Postby lp » Wed Mar 16, 2016 9:29 pm
It needs a bit more testing as it was only tested in the default video mode when the machine came up, but I think it will be ok in other modes. Yet another option for FireBee owners if all goes well. ;)
TheNameOfTheGame
Re: N.AES
Postby TheNameOfTheGame » Wed Mar 16, 2016 11:08 pm
Thanks Lonny!
Re: N.AES
Postby joska » Thu Mar 17, 2016 7:23 am
lp wrote:I have patched N.AES in theory if some brave soul wants to test it.
Good work Lonny :) Now I have another challenge for you - could you fix Geneva as well?
Re: N.AES
Postby wongck » Thu Mar 17, 2016 11:42 am
And how about NVDI 4?
lp
Re: N.AES
Postby lp » Thu Mar 17, 2016 7:32 pm
I tend to work on stuff I care about, unfortunately never used Geneva. I would rather not spend time on that.
Isn't there a patch for the FireBee + NVDI already?
Re: N.AES
Postby wongck » Thu Mar 17, 2016 11:40 pm
FB has NVDI 5 patch, I never tried anything lower than that on it.
May be I try NVDI 3 on the FB over the weekend.
fmh
Re: N.AES
Postby fmh » Fri Mar 18, 2016 5:22 pm
I really like N.AES. So I understand this correctly Do I install N.AES from the CD (SD in my case) on the FireBee or do I copy over the N_AES folder from an installation and change the MINT.CNF and N_AES.CNF files replacing XaAES? Then replace the n_aes_fb.sys file?
I just want to make sure I go about this the right way. MiNT on the N.AES 2.0 CD is version 1.15.5 dated 1999.
Atari Gamer
FireBee
lp
Re: N.AES
Postby lp » Fri Mar 18, 2016 7:49 pm
I can't really help with replacing a working xaaes setup and its been years since I did an actual N.AES install. The setup on TT030 was copied from my MegaST4, then swapped out for the 030 version, then that was copied to my Hades060, and when that died it was copied to aranym.
Re: N.AES
Postby DarkLord » Sat Mar 19, 2016 2:33 pm
Ewww, I can still remember trying to guess what the German menu's said and making
the correct choices when I first installed it from the N.AES (v2.0?) CD I've got.
Re: N.AES
Postby shoggoth » Sat Mar 19, 2016 4:11 pm
Works w. different screen resolutions etc as intended :) Truly awesome.
fmh
Re: N.AES
Postby fmh » Sat Mar 19, 2016 6:04 pm
Just curious, what CPU did you chose during installation? From memory I remember 68000, 68030, 68040, and 68060 or Hades.
Atari Gamer
FireBee
lp
Re: N.AES
Postby lp » Sat Mar 19, 2016 7:27 pm
I don't think shoggoth used the installer. For the firebee it must be the 68000 version, that's the one I patched.
fmh
Re: N.AES
Postby fmh » Mon Mar 21, 2016 1:04 am
I took my 68000 installation of N.AES 2.0 that I did in Hatari and copied it to a blank CF card. I then replaced the N_AES.SYS file with the FireBee Patched one and booted. Here's as far as I get in the boot process before it locks up solid. In the AUTO Folder all I have is the MINTNP.PRG and nothing else.
Atari Gamer
FireBee
lp
Re: N.AES
Postby lp » Mon Mar 21, 2016 2:57 am
If I had to guess, you must use a current MiNT kernal, because it was changed for the firebee. It never even gets to N.AES.
Re: N.AES
Postby joska » Mon Mar 21, 2016 8:04 am
fmh wrote:I took my 68000 installation of N.AES 2.0 that I did in Hatari and copied it to a blank CF card. I then replaced the N_AES.SYS file with the FireBee Patched one and booted. Here's as far as I get in the boot process before it locks up solid. In the AUTO Folder all I have is the MINTNP.PRG and nothing else.
Lonny is right, you need a ColdFire MiNT kernel. Use your current MiNT/XaAES setup on your Firebee. Then start n_aes_fb.sys instead of xaloader.prg (see the "GEM=..." line in mint.cnf). You also need to copy over your N.AES folder from your working N.AES setup.
stormy
Re: N.AES
Postby stormy » Fri Mar 03, 2017 12:14 pm
What is the difference between XaAES and N.AES? Sorry to be a noob! Why would someone choose one over the other?
Falcon ct60e 060 - 256mb ram - phantom bus and dsp accel // Atari TT - Thunder and Storm IDE 64mb ram - Lightning VME - USB LAN - Ati Mach64 2mb // Atari STM 4160 - 4MB ram - 16Mhz exxos 1.5 booster - Ultrasatan
vido
Re: N.AES
Postby vido » Fri Mar 03, 2017 12:30 pm
XaAES is further developed, it has more oprions and runs native on the FireBee.
Still I really liked the n.aes when I had my falcon. It is great piece of software.
Re: N.AES
Postby wongck » Fri Mar 03, 2017 1:30 pm
I used n_aes previously when Xaaes was still a baby, but i cannot remember what was the difference.
lp
Re: N.AES
Postby lp » Fri Mar 03, 2017 6:42 pm
mzry wrote:What is the difference between XaAES and N.AES? Sorry to be a noob! Why would someone choose one over the other?
I still use N.AES. For me personal preference.
Re: N.AES
Postby DarkLord » Sun Mar 05, 2017 1:25 pm
As do I.
stormy
Re: N.AES
Postby stormy » Wed Mar 15, 2017 8:36 am
And where to get N.AES to try it out? Thx (I tried a google search)
Return to “FireBee”
