FireBee Power Adapter
robl
Postby robl » Wed Jun 20, 2012 8:04 pm
The FireBee documentation included with the case indicates that the power adapter connector has a 5mm outer diameter. Is this correct? I have searched for DC adapters, but I have found only 1 that was 5mm. More common seems to be 5.5mm.
As I don't yet have my FireBee (awaiting delivery), can anyone confirm the correct connector size?
http://firebee.info - Unofficial FireBee Info Wiki
Current Atari Systems: FireBee (soon) - Atari 130XE
Previous Atari Systems: Atari 2600A - Atari SuperPong - Atari 400 - Atari 800 - Atari 800 XL - Atari 520ST w/ 1024M RAM - Atari Portfolio Pocket PC
Re: FireBee Power Adapter
Postby Dal » Wed Jun 20, 2012 8:16 pm
I bought an 80W regulated multi-adaptor. I can set the voltage and it comes with a selection of plugs - at least one of them fits just fine.
robl
Postby robl » Wed Jun 20, 2012 8:24 pm
Thanks, Dal. That makes me hopeful it won't be too difficult to find one that will work.
Can you share the brand / part number for your adapter?
Postby Dal » Wed Jun 20, 2012 8:46 pm
BlankVector
Postby BlankVector » Wed Jun 20, 2012 8:55 pm
robl wrote:The FireBee documentation included with the case indicates that the power adapter connector has a 5mm outer diameter. Is this correct? I have searched for DC adapters, but I have found only 1 that was 5mm. More common seems to be 5.5mm.
Mine has exactly 5 mm outer diameter.
Subscribe to my Vretrocomputing channel on YouTube and Facebook. Latest video: Display a picture in assembly language on Atari ST.
mehlab
Postby mehlab » Thu Jun 21, 2012 5:39 am
Same here i have buy a multi voltage multi plug adapter the guy was nice enough to have a 3 days return.
Did not have to use this option work fine from the very first minute :)
Klapauzius
The Klaz
The Klaz
Postby Klapauzius » Mon Jun 25, 2012 10:04 am
I'm expecting to get my FireBee tomorrow, but just realised I don't have a suitable PS at home.
Do you guys think that this one would be ok?
http://www.amazon.de/Ansmann-5311143-Un ... 491&sr=8-1
Klaz
http://www.klapauzius.net
Postby Dal » Mon Jun 25, 2012 10:16 am
Firebee requires about 20 watts so that supply should be OK.
ldv-01
Postby ldv-01 » Mon Jun 25, 2012 12:02 pm
The requirements are 12–24 V and at least 3A DC. The Ansmann APS 2250 has a lower maximum output current: 2250mA at 12V
http://www.ansmann.de/cms/en/consumroot ... 250-h.html
I suggest at least a 40W power adapter (most netbook universal adapters will fit, better with a manual voltage selector).
ldv
Klapauzius
The Klaz
The Klaz
Postby Klapauzius » Mon Jun 25, 2012 12:07 pm
Damn! Just ordered it! :twisted:
Hmm, the FireBee Wiki says output current between 2A and 3A, so I thought 2.225A should be ok.
http://wiki.newtosworld.de/FireBeeNetzteil
Thanks for that anyway! I'm gonna cancel it, just to be sure, and order a stronger one instead. :)
robl
Postby robl » Mon Jun 25, 2012 12:23 pm
Klapauzius wrote:Damn! Just ordered it! :twisted:
The Ansmann PSU just barely makes the listed minimum specs. However, it is noted that lower voltages & current cause instability and video flicker. The consensus seem to indicate you need to go between 18-24VDC and at least 3A.
vido
Postby vido » Mon Jun 25, 2012 3:32 pm
robl wrote:The Ansmann PSU just barely makes the listed minimum specs. However, it is noted that lower voltages & current cause instability and video flicker. The consensus seem to indicate you need to go between 18-24VDC and at least 3A.
I use 12V with 2,5A without any problem. Someone should just measure how much Ampere it uses.
alienkidmj12
Postby alienkidmj12 » Sat Jul 29, 2017 6:45 pm
how do i get the firebee working with a keyboard and mouse, i have ste and falcon so i cant use keyboards from those.
all i have is ps2 and usb keyboards, the ps2 is not yet implemented i hear :(
dave
vido
Postby vido » Mon Jul 31, 2017 8:13 am
Yes, PS2 is not implemented yet. But USB keyboard should work.
Some USB mouses also should work. Here is the list of some working and non working mouses: viewtopic.php?f=92&t=24582&p=264658&hilit=working+mouse+firebee#p264658
New wireless mouses usualy dont work altought I have workong Genious USB mouse.
You should try USB Keyboards and mouses if they work and post your findings on the list of the thread I put the link to it.
Return to “FireBee”
