Replacing system clock on my Falcon
This is the gallery. It's where we put the pictures upon pictures of us all showing off our dens and collections.
COTAFAJ
Postby COTAFAJ » Sat Mar 16, 2013 11:21 pm
I really was quite tired of not having the system clock on the Falcon. So...I decided to go the route of ripping out the old chip and putting a socket in. I ordered a couple of clock chips and I just finished about an hour ago.
I know. BORING you say. well...2 reasons I mention it here. 1, it worked and 2, my wife could care less about this achievement.
COTAFAJ
"There are 10 types of people in the world. Those that understand binary, and those that don't"
Coding on the Atari Falcon and Jaguar
Former registered developer with Atari, Commodore and Sony.(I know.....who cares)
Falcon 030/Sony Net Yaroze/Nuon
TheNameOfTheGame
Re: Replacing system clock on my Falcon
Postby TheNameOfTheGame » Sat Mar 16, 2013 11:31 pm
I gotta do this soon too. If I could ask, where did you get the socket from? I have the clock chip already.
Good Job Man! :cheers:
Postby DarkLord » Sat Mar 16, 2013 11:51 pm
Yes, very good job - clean and neat looking, unlike my stuff. :)
COTAFAJ
Postby COTAFAJ » Sun Mar 17, 2013 12:18 am
Got mine here. They should be available if you google it. Maxim Dallas 12887, 12887+ is the time chip.
http://www.digikey.com/scripts/DkSearch ... C%20SOCKET
COTAFAJ
ToasTuk
Postby ToasTuk » Sun Mar 17, 2013 10:27 am
For those with a Dallas installed not wishing to remove the clock chip here is a simple mod I found on the Internet.
Cut/file (or melt in my case but not advised >:) ) the sides to expose the contacts.
Solder on the + and - wires to the battery connector. Insert the battery and reset the Nvram.
The original link : http://www.mcamafia.de/mcapage0/dsrework.htm
This is what someone else done and it worked fine for me. Obviously the other way is tidier.
This is the inside of the mk chip after I ripped it open. As you can see a similar process can be achieved on the side of the u56.
Note: if the clock chip has a distorted case then the battery inside has leaked and needs replacing.
ToasT
ATARI Machines:
64bit: Jaguar + CD unit + Alpine, tap tap, jag link,pro controller
32bit: Abaq(ATW800) + Charity(Blossom), Falcon CT63, Falcon 030 (*2), TT030
16bit: MegaSTE, STe, MegaST, MegaST4, STFM, STF, Stacy
8bit: 130XE
http://www.funkymicros.com
Life: its all about the journey.
Postby Dal » Wed Jun 05, 2013 3:46 pm
OK I can see where you've connected the battery on one side of the chip, but what is that you have connected to the other side? looks like an elecrolytic capacitor but the photo is not clear. Can you also confirm you used the red lead for positive?
BoNuS
Postby BoNuS » Wed Jun 05, 2013 6:27 pm
I have to do it too, twice even :( Not looking forward to it but okay.
It is annoying when it is off all the time and the setting of the vram are wrong...
http://bonus.home.xs4all.nl/
Return to “Gallery”
