PP's 1gb image and 1040STe compatibility. HW issue?
A section to cover all the different problems encountered by running game x on system y! Whether it's as simple as a non-STE compatible game through to h/drive installable games. Discuss them all in here.
leech
Postby leech » Sat Dec 31, 2016 6:54 pm
So got a 1040STe (mainly to try to fill out the compatibility range, though I still don't have just a 'normal' ST that works). I downloaded the image from http://atari.8bitchip.info/DiskImgPP1.html and stuck it on a 2gb SD card, and into the UltraSatan.
But it seems the games are very hit and miss whether they work or not. Like Battlechess just turns the desktop into a negative (white turns black, black turns white, oddly I think the green turned yellow). I'm wondering if this is just TOS 1.06 being crappy, or there is some other possibility here (this system looks like it was used for a bit then shoved into a box, so possibly an old capacitor, other weird issue).
I do have 4mb of RAM, which from what I understand could cause some compatibility issues as well, but I thought these games were the tweaked/fixed versions that should work on everything, and just want to make sure it's not a hardware issue.
Thanks for any suggestions.
leech
Re: PP's 1gb image and 1040STe compatibility. HW issue?
Postby leech » Thu Jan 26, 2017 5:32 am
Weird. So Battlechess on TT030 works fine. I upgraded the 1040STe with the TOS 1.62/2.06 switcher from exxos as well as the PSU, still can't get Battlechess to work on either version of TOS for it. I don't think I tried it on the Mega STe, but according to the site, it should work with all of them.
Postby Steven Seagal » Thu Jan 26, 2017 8:10 am
You could check compatibility with an emulator too, before messing with your hardware. :angel:
leech
Postby leech » Mon Jan 30, 2017 9:14 am
This is true, though I was planning on the upgrade anyhow. Pretty sure it crashed there as well. I have some other set up things I need to do in the meantime.
Postby AtariZoll » Mon Jan 30, 2017 11:29 am
It was tested in big part on STE with 4MB RAM. RAM size should be not problem - those bad codes were fixed, or whole system sets environment for game as there is only 512KB or 1MB if game needs that much.
Considering age of machines, I expect that there will be more and more problems. This is typical case - when some SW runs, some not - so degradation of components.
Indeed, replacing electrolytic capacitors is what should be done when some electronic is 25 or more years old.
leech
Postby leech » Thu Feb 02, 2017 7:07 am
I did replace the PSU and installed the Fast TOS switcher from Exxos, but it still crashes. I still need to test it on Hatari and see if it does it there. Tried with 1.06, 1.62 and 2.06 TOS, only worked on 3.06 on the TT030. I could try it on my Mega STe that has 2.06 as well.
Any other capacitors inside the 1040STe?
dlfrsilver
Postby dlfrsilver » Thu Feb 02, 2017 1:53 pm
There are 2 big ones on the motherboard, that you can change and recapp.
leech
Postby leech » Tue Feb 07, 2017 6:13 am
Thanks, hopefully I can get some time tomorrow to check them out.
Return to “Games - Compatibility Issues etc.”
