Deluxe Paint PI1 Bug
Postby simonsunnyboy » Mon Mar 16, 2009 9:04 pm
Can anyone confirm this bug in Deluxe Paint with loading PI1 files?
Works ok for theose which are 32066 bytes long but not for the old standard 32034 sized ones. It loads the picture but does not load the palette for the latter ones....is there a workaround or patch?
ppera
Re: Deluxe Paint PI1 Bug
Postby ppera » Tue Mar 17, 2009 2:36 pm
Workaround: correct short ones with some good Hex/file editor :D
Of course, in case of many files is better to write some simple proggy for batch conversion. Just needs to add some zeros to correct place.
Postby Mug UK » Tue Mar 17, 2009 5:20 pm
Vague recollection of a patch being released to DP to fix this -or- it was a homebrew TRAP #1 hack that fooled Dpaint into 'finding' the extra bytes that were required.
Will have a dig around - could also be my complete and utter imagination playing tricks on me!
Return to “Discussion”
