Anybody running ARANYM under FreeBSD?
fmh
Postby fmh » Fri Aug 15, 2014 12:30 am
I just recently dedicated a PC to GhostBSD Ver 4. This is FreeBSD with Mate Desktop. It's a lightweight desktop FreeBSD. There is Hatari for FreeBSD but no ARANYM. There was an old FreeBSD Port of ARANYM 0.7.0 that is real old but I can not get it to compile. I have not attempted to compile the latest 0.9.16 yet as the FreeBSD Port should be much easier to compile. Is there any ARANYM users under FreeBSD? If so can I get the binary from you or your assistance in compiling ARANYM?
Atari Gamer
FireBee
ragnar76
Re: Anybody running ARANYM under FreeBSD?
Postby ragnar76 » Fri Aug 15, 2014 5:52 am
hey,
building aranym for *bsd should be very similar to the linux one.
I guess you have to install the SDL1-devel packages first. Don't ask me for their names. I'm on debian linux
create a builddir and get the sources
mkdir build
cd builddir
git clone git://git.code.sf.net/p/aranym/code aranym-code
configure and build
./configure --prefix=/usr
make depend
make
install it
sudo make install
bye
ragnar
fmh
Postby fmh » Wed Jul 08, 2015 6:04 pm
I get as far as the Configure and Build portion.
At the statement ./configure --prefix=/usr
I get the following error
fish: Unknown command './configure'
Atari Gamer
FireBee
helmut
Postby helmut » Wed Jul 08, 2015 9:11 pm
Either configure needs to be executable (chmod +x configure) or you should use another shell (try e.g. dash ./configure). But I did not try it myself on FreeBSD as I don't have it.
Postby Eero Tamminen » Wed Jul 08, 2015 9:28 pm
Pre-generated "configure" scripts are typically included only in release source tar-balls. If you take source directly from repository, you need to generate that yourself with autotools (i.e. you need automake/autoconf/libtool etc).
Most projects include script for this, normally it's called "autogen.sh", also in Aranym: http://sourceforge.net/p/aranym/code/ci/master/tree/
