Passwort reset?
Atari Legend talk.
Moderators: Klapauzius, Moderator Team
Passwort reset?
Postby simonsunnyboy » Sat Jun 13, 2009 7:54 pm
My AL login keeps telling me "incorrect password". How can I reset this or can someone reset it for me?
techie_alison
Re: Passwort reset?
Postby techie_alison » Sat Jun 13, 2009 9:21 pm
Is it something I can do?
I think I only have Admin access to this one. I don't know if it's the same panel.
If I don't answer or appear to have forgotton then email again, I'm scatty! :)
http://www.logicsays.com/ = Updated Site
http://www.logicsays.com/index1 = Older Site (with more Atari)
Re: Passwort reset?
Postby simonsunnyboy » Sat Jun 13, 2009 9:46 pm
Well you can try, my AL login is the same as here at AF, simonsunnyboy :)
techie_alison
Re: Passwort reset?
Postby techie_alison » Sat Jun 13, 2009 11:39 pm
I think I should wait for SilverSurfer to drop in.
There's bits of the server which I have access to, but it's only on this one where I'm confident in doing things. The AL one is a different control panel.
Hang in there Simon. :)
Re: Passwort reset?
Postby simonsunnyboy » Sun Jun 14, 2009 7:36 am
To make sure, I'm talking about my login for www.atarilegend.com, www.atari-forum.com is working fine. Otherwise I couldn't post this ;)
Re: Passwort reset?
Postby Mug UK » Sun Jun 14, 2009 12:00 pm
Not one Aly has access to - just clicked on the reset button Simon so I'm guessing it's going to ask you to pick another one when you next login.
Re: Passwort reset?
Postby simonsunnyboy » Sun Jun 14, 2009 2:51 pm
No question - if I leave the passwort field empty, i get "You didn't fill in a required field."
If I try my old password, it says "Incorrect password". I'm stuck :(
The GUI lacks a button for the "forgot my passwort" thing like all other system have. Too bad it is so late that I discover this. But in the past i never had problems....
Return to “Atari Legend Forum”
