Easily replace st stf/m mega st ram with a 4/8mb simm
simbo
Postby simbo » Sat Jan 23, 2010 1:17 am
This is the start of a guide I am still waiting for a few things in the post tomorrow, I hope.
This Guide shows how to expand an stf/m to 4 MB using a 74pin simm,
i would use a 4mb simm i find using some types of 8mb simm or 16 youll only get 512k
when you add the switch for 1mb if you intend too something to do with RAS1 i need to experiment a little
unless someone has cured this issue in the past???
the first picture is of another stfm I have has the rom sockets under the psu,
and two rows of ram I'll do this one last as I'll make a separate guide hopefully;
with help of photo materal of other's as they do this also.
I have changed it's memory buffers already.
I feel this is a needed step to interface to the simm correctly, and aid in stopping any packet loss.
I'll expand the picture guide as I complete these steps on these two st machines of the same rev 1.1 board
one stf one stfm one has 74ls11 fitted to the roms the other not but will have as I get one.
both I'll add flash tos chips to as it's a great project for more than fun.
so I'll cleaned out its pin holes ready for the chips {Just us an LS type here is fine I feel.}.
First you need a few bits and tools:
techie_alisons memory upgrade guide
sharp side cutters.
solder irom 25watt for removing and if you have it a 17 watt for fitting using a 25 watt with care is enough.
solder 22swg lead/tin/flux core.
pair of small radio pliers.
inspection mag glass.
some twezers long and thin but stirdy.
memory and hookup bits:
A non right angle simm socket 72pin. {See links in hardware section I posted about memory and stuff and where to buy it cheap.}
A 72pin 4 or 8mb fastpage 80 ns or better simm. {Again see the links in the hardware section to a cheap ebay seller.
viewtopic.php?p=152970#p152970}
1 meter of flat gray or multicoloured ribbon cable. {I got 2m for £2 on ebay last week free post.}
1 set of tubes of epoxy glue like araldite or others. {you'll find cheaper types not as good.}
1 tube of super glue. {Use locktight stuff its better than the cheap tubes. }
{Total cost is about £11 for all of these bits.}
1 bit of wet and dry sand paper to make a key on the sim sockets glue surface.
memory buffers:
2X74HC244 {you can use F types or HCT here ACT types is'nt needed}
2X74HC373 {again you can use F types or HCT if you like}
So I've already replaced, as youll see below both buffer ics, in both machines.
Also I've take off the older ram that lives under the psu.
Also the small yellow bypass capacitors that are on the psu rail of each mem chip,
this makes more space for the simm socket to glue too.
I'll post more as I go so check back and grab the bits.
simbo
Re: Easily replace st stf/m mega st ram with a 4/8mb simm
Postby simbo » Fri Feb 05, 2010 10:58 pm
todays rev 1.1 machine
note the use of pin strips on the buffer ic needed pins
finaly triple check your work
see alisons memory upgrade details on her site
for more details
http://www.logicsays.com/atari/
i do however also replace the buffer ic's as ttl 74LS logic is not fully complient with 72 pin simms dram chips gates
simbo
Postby simbo » Sun Feb 14, 2010 9:29 pm
ive since fitted some 4mb 8 chip 70ns simms to all moded machines
and all is fine 4mb and 1mb on switch
no issues
the st menus respond faster
the two machine moded with tos1.04 and simm
and also the memory buffers are great
much sharper for sure!!!
concider replacing the memory buffers also
although its nearly as good without replacement
and i havent noticed any breaks in use,... with 74hc types used,,,
Nikolas
Postby Nikolas » Sun Jun 20, 2010 6:24 am
replacing with HC thats 74HC memory buffers it give me faster st machine? less data loss within st?
In my expirience 74LS for 74HC is improved data trafic, more acurett and better stability
If you guys expirience hardware problems.
1. Always remove chips if possible before soldering.
2. Resolder your hardware, check cables too.
3. If problem continue THEN must be faulty software.
I got 2 Atari ST
Main is stfm, with blitter, with 4 meg of ram, with 16mhz cpu + s-video and audio input to videobox, vdi out
P.S.
My english may not be correct
simbo
Postby simbo » Wed Jul 14, 2010 10:41 pm
you dont have to change them i just do i find in practice there is little change
only the current the machine uses changes
ls or hc/t is just as good
however i use 74HCT myself when i can find them
hc type high speed cmos i agree isnt the best its just what i had
hct is far better
or leave them alone and just add the jumpers to there pins
it just makes the simm more compatable in terms of voltage levels TTL / CMOSTTL to the mmu
sim-os
Postby sim-os » Thu Aug 12, 2010 8:37 am
hi simbo,nice guide ,have a some questions..
on ST board has already 74XX chips?,and if yes.. is important to change the default 74XX chips with others? (i have a lot 74LS.. :) )
on alison site guide i thing she is do-not use the connection on MMU chip [pin64]?
at last your pic,s is nice but no so helpful,maybe one more analytic connection diagram is more useful ,(your cable have multi colors lines,but is double..) :wink:
Anemos
Postby Anemos » Thu Aug 12, 2010 1:44 pm
@simbo,excellent mod! :cheers:
What,s on gaming? dos games or game then need 1 or 4 mb?
If you can make one list with pins directions-connection, Ram to Atari board ,that gones very helpful . :cheers:
Atari 1040 STE - 4mb - TOS 1.62
Atari 1040 STF - 1mb - TOS 1.00
simbo
Postby simbo » Thu Aug 12, 2010 4:25 pm
hi
adding the switch is simple
there is normaly mad 1-8 you need to use mad {memory address} 9 it is not normaly connected
on the glue chip is st machines
you add a 33 ohm resistor and a single pole switch
switch one way it connects and yields 4MB addressing
switch the other and 1MB normal memory level is attained for some games as you know dont like 4mb
as for a list of pins if you read techie_alisons guide they are there
youll note some address pins need to connect together
i dont suppose she will mind if its here if she does im sure she can just delete it
499
Postby 499 » Thu Jun 26, 2014 9:24 pm
simbo, can you better show which wires connect to which pins on the memory buffers? Maybe show all connections to the motherboard in one list?
brownb2
Postby brownb2 » Wed Sep 17, 2014 1:18 am
Can somebody restore the photos on this page? I was looking to possibly do this upgrade but not without photos! :)
Amiga A600 (0.72 MIPS) - 2MB Chip 4MB PCMCIA Fast, RTC, 512MB CF HD
Amiga A1200 (7.36 MIPS) - 2MB Chip 8MB Fast, MTEC Viper 68030@42MHz MMU, 68882 FPU, RTC, 1GB CF HD
Atari 520 STFM (0.9 MIPS est.) 1MB, Multiface ST.
ZX Spectrum +2A (0.24 MIPS) - 128KB, Custom 3'5 External Floppy.
ZX Spectrum +3 (0.24 MIPS) - 128KB, DivIDE+ 64MB CF HD, Multiface 3.
Postby Dal » Wed Sep 17, 2014 1:11 pm
I'm on it...
Postby Dal » Wed Sep 17, 2014 9:16 pm
BOOM! They are back.
Sorry it took a while. :angel:
Giants
Postby Giants » Fri Nov 21, 2014 7:50 am
Blup
Several years after :)
I find some errors in the guide v1.02 and v1.03
After the SImm description, I see
>*40 connections to be made
But I found only 39
(D0 to D7) : 8
(D8 to D15) : 8
(RAS and CAS) : 6
(A0 to A9) : 10
WE : 1
GND and +5V : 6
(8 + 8 + 9 +10 +1 + 6) = 39
I missed one ?
And, this is very important. In the section 6 (connecting your SIMM socket to ..)
I See on your document :
R59 > RAS0
R60 > CAS0L
R61 > CAS1L ---> I think it's wrong but the good connexion is : R61 > CAS0H isn't it ?
R71 > CAS1H
R72 > CAS1L
R73 > RAS1
But, for even with modification ,it's don't work on my STF, maybe my memory is not good..
as I have no SIMM 72 pin connectors, I connect directly the SIMM it's complicated to test other SIMM memory.
UPDATE : Hoo, I See it's my first post here, sorry about that.
I just discover maybe (i'm sure in fact), I forget to Link in my SIMM memory a lot of pin like ::
Pin2 and Pin3 (D0 and D16)
Pin4 and Pin5 (D1 and D17)
For me, all this pin (D16, D17...)is connect to nothing so... -_-'
Return to “Guides”
