PLEASE POST A CLEAN <=300K PIC IN JPG THE INSIDE OF YOUR ST
simbo
Postby simbo » Mon Feb 25, 2008 8:24 pm
HELLO PEOPLE
WHEN YOU GET A CHANCE PLEASE POST A CLEAN PHOTO OF THE PCB OF YOUR ATARI ST
REMOVE THE PSU AND THE FLOPPY DRIVE TO A BARE PCB AND PLASTICS FRAME ETC { BOTTOM END}
THERE IS SO MANY MODELS AND EVEN COUNTRY MODELS TO SEE
AND A CLEAN PICTURE WILL SORT OUT ISSUES
PROVIDED ITS REPORTED AS A LINK TO THIS TOPIC IN OTHER TOPICS
IT CAN BE REUSED AS A POINT OF REFERANCE
ILL TAKE A FEW MYSELF
AND HUNT THE FORUM FOR OTHERS
YOU CAN LOCATE THESE OFFSITE IF YOU WILL IF THEY ARE BIG AND YOU HAVE A GOOD CAMERA FINE
BUT 300K IS COOL I SUPPOSE {I CAN ALSO MIRROR THIS IN YAHOO UK {NICE PEOPLE} EASY!!!!! }
Stefan jL
Re: PLEASE POST A CLEAN <=300K PIC IN JPG THE INSIDE OF YOUR ST
Postby Stefan jL » Tue Feb 26, 2008 7:06 pm
I have an old picture i did of my 520 stfm using my old camera it's not so clean (floppy cable still there) i guess it will do for now :)
http://arcade.ym2149.com/misc/atari_st_pcb.jpg
It has been upgraded to 1mb.
Nyh
Postby Nyh » Wed Feb 27, 2008 9:58 am
Atari ST Rev D
With some addons:
20 MHz processor
Autoswitch overscan
4Mb memory
TOS 1.4/Kaos switch
HD/ED floppy
High speed serial
Hans Wessels
ppera
Postby ppera » Fri Jun 27, 2008 4:49 pm
This may help about knowing diverse revisions:
It is 520ST, Rev H . Was in machines with separated floppy and PSU. Recognizable also by on-main-board mouse and joystick connectors. No support for 2-chip TOS.
This is next version, Rev I, almost same. As I see, only difference is support for 2-chip TOS - in form of 74LS11 and some soldering pads. There is place for some IC, U201, not used here...
Mega ST, Rev 4.0 , with factory 4MB . Original ROMs are replaced with Flash EPROMs...
1040STFM C103175 REV 1.1 . 4bit RAM chips.
insanity
Postby insanity » Wed Aug 20, 2008 9:34 pm
Finally good around to this...
I'm surprised more people haven't added theirs... Yes, taking apart the ST is a pain, but I think this is a good cause!!
Come on people!! :)
520 STFM C103414-001 Rev 1.1
520 STFM C070789-001 Rev C
Hope this helps,
baz
Postby Mug UK » Wed Aug 20, 2008 9:55 pm
The one that I'm going to split into two for godstalker and Chandler will have pictures taken of it .. bear with me :)
insanity
Postby insanity » Thu Aug 21, 2008 9:58 am
Ok, I've moved these photos to the wiki... hope everyone is ok with this.
It can be found here:
wiki/index.php/Atari_ST_motherboard_revisions
The order might need to change and the text (regarding add-ons etc.) should probably be added too...
EDIT: I think the order should be based on the Cxxxxx number, not the revision... doh! :/
Please take note of the filenames used, it would be nice to keep these:
Current ones:
baz
Postby Mug UK » Thu Aug 21, 2008 12:05 pm
Nice move there insanity. Saved me from doing it :)
insanity
Postby insanity » Thu Aug 21, 2008 12:24 pm
muguk wrote:Nice move there insanity. Saved me from doing it :)
I was going to ask you to do it earlier... :P
...but you appear to have loads of stuff to do, having read these forums!!
Besides, I want to learn more about wikis... :wink:
baz
insanity
Postby insanity » Thu Oct 23, 2008 11:37 am
:megaphone: We still need those photos of your ST motherboards! :megaphone:
We have quite a few on the wiki, but more are needed:
We don't even have an STE yet!! Rubbish! :lol:
Please make sure Revision numbers are visible!!
Thanks :cheers:
baz
Shredder11
Postby Shredder11 » Thu Oct 23, 2008 12:32 pm
I wish I had a better camera as I want to add one of my 4160 STe machines to the mix. I've recently taken a cluster of close-up photos with my PDA 1.3Mpix camera with very mixed results. I can post them here or wait until I have a better camera next year... :oops:
ppera
Postby ppera » Thu Oct 23, 2008 12:53 pm
I will shot mine STE and Mega STE soon... How many STE revisons were made?
Shredder11
Postby Shredder11 » Thu Oct 23, 2008 1:12 pm
On one of the photos I took the other week, it shows 'CA4003290- _ _ _ _ _ REV _ _ _ _ _'
insanity
Postby insanity » Thu Oct 23, 2008 7:44 pm
Shredder11 wrote:On one of the photos I took the other week, it shows 'CA4003290- _ _ _ _ _ REV _ _ _ _ _'
Like this?
http://jeanfrancoisdelnero.free.fr/yaqu ... rboard.jpg
Maybe there aren't that many STE revisions... will have to wait and see! :)
baz
Shredder11
Postby Shredder11 » Fri Oct 24, 2008 12:59 pm
I have three STe computers but will need to open the others up to find out the revision numbers. I'm not in a hurry to do this at the moment as I feel like a dose of flu is coming on. I've just started a new job too after being on the dole a year... :cry:
accxess
Postby accxess » Fri Oct 24, 2008 1:07 pm
Just a small friendly advice :), If you own a scanner, put the ST in the scanner, I did this with my MSX, all I had to do was to scan it twice and put the images together with photshop. Perfect sharpness and no distortion in the pix. :)
/Tobias
There is NO need for more than 16 colors
Desty
Postby Desty » Sat Oct 25, 2008 1:45 pm
I've got two 4mb STEs but I don't know where the other one is.. also feeling a bit lazy to open the one up, but I might do this weekend.
tá'n poc ar buile!
ppera
Postby ppera » Sun Oct 26, 2008 10:01 am
Here are pics of STE and Mega STE boards. Not the best ones, as there is no sun, and my artificial light is even worse.
And no PCB version markings on boards...
Small board at top, right is HD floppy circuit. There is IDE IF too, with experimental hot-swap support, therefore so many chips soldered.
ACSI-SCSI adapter is modded, and supports drives over 1GB.
firyembers
Postby firyembers » Wed Jan 07, 2009 9:27 am
Here is one of the Ataris I have,a 520STM
insanity
Postby insanity » Wed Jan 07, 2009 10:25 pm
Have added to:
Thanks guys!
Anyone else?
push2fit
Postby push2fit » Mon Mar 16, 2009 10:08 pm
This one is in one of my Ataris:
1040STF C070789-001 Rev.B
push2fit
Postby push2fit » Wed Mar 18, 2009 4:37 pm
Here Two others:
1040STF C103175 Rev.1(.0)
1040STF C070859-001 Rev.??
Hope, it helps.
insanity
Postby insanity » Wed Apr 01, 2009 2:16 pm
Thanks push2fit, added to:
As always... Anyone else?
baz
Decky
Postby Decky » Sun Jun 07, 2009 11:18 pm
Here is a photo my my motherboard before I done a TOS 2.06 upgrade
Atari STe 4Mb with TOS 1.62 / 2.06 Switchable, thanks to Techie Alison. UltraSatan, CosmosEx, Gotek
insanity
Postby insanity » Mon Jun 08, 2009 1:53 pm
Return to “Guides”
