<Omikron Basic> How do I test if a bit is set on screen?
Omikronman
Postby Omikronman » Thu Feb 04, 2010 8:24 am
Hello!
First of all I am happy to see that the forums are back online! Today I like to improve my coding skills. My question is, how do I test if a bit is set at the position x,y on the screen at ST-HIGH? I know about the POINT command, but I like to find a faster way. Any ideas?
Tnx, Omi
BoNuS
Re: How do I test if a bit is set on screen?
Postby BoNuS » Thu Feb 04, 2010 8:37 am
In GFA basic there is a command calld PTST.
I think you can use that.
A%=PTST(X,Y), AFAIK its much faster then POINT.
http://bonus.home.xs4all.nl/
2 x Falcon 030 - a mint Atari TT - Mega STE - 2x STE - 1x Mega 2 - 2x STFM - 1 x STF - 3x SC1224 - 2x SM124 - 1x SM125 2x Portofolio+interface
- 3x 1435 monitor - 1 x Ult.Ripper cardridge - Mega 1,2,and 4 ( just to much Atari stuff)
Omikronman
Re: <Omikron Basic> How do I test if a bit is set on screen?
Postby Omikronman » Thu Feb 04, 2010 8:42 am
Oh, I had forgotten to say that I try to do it with Omikron.Basic (unfortunately there isn´t a Omikron.Basic section in the forums so I did my thread into "other basic". Maybe some sort of PEEK command would work, but I don´t know how.
Nyh
Postby Nyh » Thu Feb 04, 2010 8:55 am
Omikronman wrote:Hello!
The hard way to find out is:
peek(lpeek($44e)+y*80+x\8) and (1 shl(7-(x and 7)))
If this is not zero the pixel is set.
Hans Wessels
Omikronman
Postby Omikronman » Thu Feb 04, 2010 9:03 am
Ah, tnx! I will play around with that and do some tests!
BoNuS
Postby BoNuS » Thu Feb 04, 2010 9:40 am
Omikronman wrote:Oh, I had forgotten to say that I try to do it with Omikron.Basic (unfortunately there isn´t a Omikron.Basic section in the forums so I did my thread into "other basic". Maybe some sort of PEEK command would work, but I don´t know how.
Could have guest that with a name as omikronman :)
For Omikron no one better than Nyh
Omikronman
Postby Omikronman » Thu Feb 04, 2010 9:44 am
Tnx anyway BoNus ^^.
I played around with it and I need some advice. I loose time when using
because I need in addition to that line a IF ... THEN ... statement to get results of 0 or 1 dependend of the pixel (IF peek ... >0 then result=1). I am not good in maths, but is it possible perhaps to modify the line to get results of 0 and 1?
Tnx, Omi :)
Nyh
Postby Nyh » Thu Feb 04, 2010 11:42 am
Omikronman wrote:Tnx anyway BoNus ^^.
(peek(lpeek($44e)+y*80+x\8) shr(7-(x and 7))) and 1
Not tested but it should work...
Hans Wessels
Omikronman
Postby Omikronman » Thu Feb 04, 2010 12:35 pm
Tnx, I will play around with it. =) Omi
lp
Postby lp » Thu Feb 04, 2010 3:21 pm
Take the screen address and pre-calculate a table to the start of each scan line, so the Y is an offset into the table. This will reduce the math and speed it up. :wink:
Likewise tables can be made for the X as well, to figure out the byte offset and the bit and avoid the math.
Omikronman
Postby Omikronman » Fri Feb 05, 2010 4:13 am
Thx! With your tips I was able to improve the performance of my ASCII-art program. A picture can now be calculated up to 35 % faster by testing the pixles more quickly.
Postby rockyone » Sat Feb 12, 2011 8:21 pm
Peut on voir ascii art
Omikronman
Postby Omikronman » Sat Feb 12, 2011 8:25 pm
charles
Postby charles » Sun Feb 13, 2011 1:17 am
in gfa basic i used set bits on a monochrome screen
by finding the screen address
then poking/peeking at the 32000 byte buffer
this seems to only work on mono chrome since color uses some bizzare resolution and format for the color pallette
charles
atari is my lifestyle,not a hobby.
HOLD ON ! ! !,
Im printing unreadable characters ...!
lp
Postby lp » Sun Feb 13, 2011 1:32 am
charles wrote:this seems to only work on mono chrome since color uses some bizzare resolution and format for the color pallette
Its not bizarre, its called interleaved bit planes and its well documented in almost every ST programming book I've ever picked up.
Anyway, nice video. :wink:
Postby simonsunnyboy » Sun Feb 13, 2011 9:14 am
Well it would require reading documentation again :roll:
charles
Postby charles » Sun Feb 13, 2011 3:43 pm
it always requires reading document again!
charles
HOLD ON ! ! !,
Return to “Other BASIC”
