Converting 4 chars to a unsigned long?
TheNameOfTheGame
Postby TheNameOfTheGame » Sun Oct 15, 2017 12:43 am
I am trying to read the program header and get the length for the code section.
I can open the file and read the 4 bytes in ok, but when I try to calculate ph_tlen I get a wild number. Can someone point out my error?
               unsigned long ph_tlen;
               unsigned char read_buf[4];
               Fread( file_handle, 4, read_buf );
               ****** This prints out the correct values ******
               printf("\nrb0 %d rb1 %d rb2 %d rb3 %d", read_buf[0], read_buf[1], read_buf[2], read_buf[3]);
               ****** Here is where I am trying to convert the 4 bytes into a unsigned long ******
               ph_tlen = (read_buf[0] << 24) | (read_buf[1] << 16) | (read_buf[2] << 8) | read_buf[3];
               ****** This prints out an inaccurate number ******
               printf(" tlen %lu", ph_tlen);
TheNameOfTheGame
Re: Converting 4 chars to a unsigned long?
Postby TheNameOfTheGame » Sun Oct 15, 2017 1:25 am
Eh, figured it out after all. :lol:
Had to change:
To:
ph_tlen = ((unsigned long) read_buf[0] << 24) | ((unsigned long ) read_buf[1] << 16) | ((unsigned long ) read_buf[2] << 8) | ((unsigned long) read_buf[3];
I thought since ph_tlen was an unsigned long and read_buf was unsigned char, PureC would convert the unsigned chars to unsigned long during the operation.
I guess not. Don't really understand why it works that way. :?: :?:
Postby mikro » Sun Oct 15, 2017 2:21 am
No need to do that as complex as that. What about:
Fread( file_handle, sizeof(ph_tlen), &ph_tlen );
TheNameOfTheGame
Postby TheNameOfTheGame » Sun Oct 15, 2017 2:57 am
mikro wrote:No need to do that as complex as that. What about:
Wow, thanks. :cheers:
I had no idea that would work. I love C, there are so many ways to do the same thing. Of course I'm trying to find the most efficient. Much appreciated!
mfro
Postby mfro » Sun Oct 15, 2017 6:00 am
As to why this didn't work:
This is one of the trickier parts of C you need to get used to. What you got fooled by is called integral promotion. In C, all arithmetic operations on types smaller than int are enforced to be calculated on integer types only. Whenever you do a calculation on a char value, that value first gets implicitly converted to a signed integer before evaluation. So, in your first example, read_buf[x] is neither an unsigned char nor an unsigned long, but a signed int. Finally, the end result is truncated to the target type. That's why you suddenly had signed types in between while the original type was unsigned. Read more about this here. Note that gcc, for example, would have emitted a (cryptic, on first sight, but correct if you know the rules) warning that you shifted wider than the int type would allow.
charles
Postby charles » Sun Oct 15, 2017 11:11 am
does c have a cvl command?
The radioactive half-life : )
charles
Postby charles » Sun Oct 15, 2017 11:14 am
or
bmove
the four bytes to the address of variable ph_tlen?
I have no experience in 'c' language however
just thinking what basic permits
TheNameOfTheGame
Postby TheNameOfTheGame » Sun Oct 15, 2017 12:26 pm
mfro wrote:As to why this didn't work:
Thanks for the explanation!
I could see what was happening, but didn't realize why. I was thinking it would use the type of the Lvalue destination for promotion.
Now I know better. :cheers:
Postby mikro » Sun Oct 15, 2017 10:37 pm
Don't worry, many, many great programmers (and me :D) do this kind of mistake from time to time. I haven't looked deeper as of why there isn't a preceding rule like "if it's unsigned, stay unsigned no matter what" but I'm pretty sure wise men and women from the C committee had their reasons. :-P
Postby wongck » Sun Oct 15, 2017 11:40 pm
C is very flexible, you can make your 4 bytes into long, short, char or a new type with 3 bytes in size.
Just that you need to know what you are doing.... and that's the pit fall as well ( :wink: you thought you know what you are doing).
Return to “C / PASCAL etc.”
