Question about using File Selector
TheNameOfTheGame
Postby TheNameOfTheGame » Fri Oct 13, 2017 5:10 pm
I'm trying to get the return path from the file selector and add the filename to it so I can open the file.
I set up the path before calling the file selector, but when I return the path still has the wilcards at the end which I need to strip to replace with the filename.
Can someone give me an example of how to do this?
I was thinking of somehow using strrchr to get the last position with the '\' character and putting a NULL character there but I can't understand the syntax to do it.
Here is what I have so far.
                        path[0] = Dgetdrv() + 65;
                        path[1] = ':';
                        Dgetpath( &path[2], 0 );
                        strcat( path, "\\*.*" );
                        /* TOS 1.04 and above */
                        result = fsel_exinput( path, name, &button, "Select file to open" );
                        if( result ) {
                           if( button == 1 ) {
   **** Here is where I need to strip the wildcards/filetype specification off of path  ******
                              Dsetpath( &path[2] );
                              strcat( path, "\\" );
                              strcat( path, name );
                              printf("\n%s %s", path, name);
                           else {
                              form_alert( 1, "[1][Error - Not enough RAM?][OK]" );
                              exit_flag = 1;
                              break;
TheNameOfTheGame
Re: Question about using File Selector
Postby TheNameOfTheGame » Fri Oct 13, 2017 5:51 pm
Think I got it...this seems to work:
                              s = strrchr( path, '\\' );
                              strcpy( s, "\0");
where s is a char *
Postby czietz » Fri Oct 13, 2017 5:54 pm
It's inefficient to use strcpy here, since all that you want to do is...
*(strrchr(path,'\\')) = 0;
jfl
Postby jfl » Fri Oct 13, 2017 6:10 pm
TheNameOfTheGame wrote:Think I got it...this seems to work:
                              strcpy( s, "\0");
where s is a char *
You can avoid the call to srtcpy with:
*s = '\0';
And don't forget to check the return value of the strrchr call.
Jean-François
GEMDict – GEMClip
TheNameOfTheGame
Postby TheNameOfTheGame » Fri Oct 13, 2017 6:35 pm
czietz wrote:It's inefficient to use strcpy here, since all that you want to do is...
Yes, thank you that works well. But not for the case of root drive, since Dsetpath won't work then.
So I had to add a check with strchr in to the code:
                              if( strchr(path, '\\') == 0 ) {
                                 path[2] = '\\';
                                 path[3] = '\0';
                              else {
jfl wrote:And don't forget to check the return value of the strrchr call.
Could you explain why? In case the user mangles the path specification and leaves out any '\'s'?
*edit* yeesh, the user can edit the directory line and totally screw up the path and the file selector still returns with button 1 and a mangled path string. 8O
TheNameOfTheGame
Postby TheNameOfTheGame » Fri Oct 13, 2017 7:26 pm
Went with jfl's code so I could check the return value of strrchar in case the directory path has no '\' in it and avoid a bus error.
                              if( s != NULL ) {
                                 *s = '\0';
                                 if( strchr(path, '\\') == NULL ) {
                                    path[2] = '\\';
                                    path[3] = '\0';
                                 else {
                              else
                                 form_alert( 1, "[1][File path error][OK]" );
*Edit* Looks like Dsetpath has validation built-in so if the path is mangled it won't set it. That'll work and then obviously the Fopen will fail and I can catch that.
I think this will do. Does anyone see any other problems?
TheNameOfTheGame
Postby TheNameOfTheGame » Fri Oct 13, 2017 8:12 pm
Last thing is to set the new drive spec if valid.
Set up a variable for the bit mask of available drives:
long drives;
Get the bit mask of available drives:
drives = Dsetdrv(Dgetdrv());
Check after file selector returns if drive specification is valid:
if(((drives) >> (path[0] - 65)) & 1)
       Dsetdrv( path[0] - 65);
So the whole routine is now:
                     case MAIN_MENU_OPEN:
                        path[1] = ':';
                        if( result ) {
                           if( button == 1 ) {
                              if( s != NULL ) {
                                 *s = '\0';
                                    path[2] = '\\';
                                    path[3] = '\0';
                                 else {
                              else
                        else {
                           exit_flag = 1;
                        break;
Then I can attempt to open the file.
charles
Postby charles » Fri Oct 13, 2017 10:33 pm
as far as I can recall you need to merge four strings together
and be on a 64 byte max vector
merge drive+path+filename+extention
a: + \xxx\xxx\xx\ + filename + extention
but like I mentioned it cant exceed a certain length...
atari compendium
dgetpath dgetdrive dpathconfig dsetpath dsetdrive fsel_input/fsel_exinput
The radioactive half-life : )
Return to “C / PASCAL etc.”
