Help wth APPL_WRITE to send WM_REDRAW message
TheNameOfTheGame
Postby TheNameOfTheGame » Sat Oct 07, 2017 5:27 pm
Does anyone have a code example to send a WM_REDRAW message via the APPL_WRITE function? I can't seem to find any examples. :?:
mfro
Re: Help wth APPL_WRITE to send WM_REDRAW message
Postby mfro » Sat Oct 07, 2017 6:03 pm
TheNameOfTheGame
Postby TheNameOfTheGame » Sat Oct 07, 2017 6:09 pm
Thanks! :cheers:
TheNameOfTheGame
Postby TheNameOfTheGame » Sat Oct 07, 2017 7:25 pm
Ok, I implemented it in the WM_DNLINE case of WM_ARROWED message. But I get a bus error when I run the program and press the down arrow box.
Should I not send a WM_REDRAW message for the down arrow and just jump to the redraw code instead? It doesn't appear like the WM_ARROWED message causes a redraw on it's own.
I'm slowly learning GEM using PureC so I'm not sure I'm approaching this the right way. Any suggestions is appreciated!
One other thing. I put a printf in the case statement and it prints twice for every down arrow press and I'm not sure why. Is there something that should be done to prevent this double click issue?
            case WM_ARROWED:
               switch ( msg_buf[4] ) {
                  case WA_UPPAGE:
                  break;
                  case WA_DNPAGE:
                  break;
                  case WA_UPLINE:
                  break;
                  case WA_DNLINE:
                     rows_offset += 1;
                     printf("DNLINE");
                     msg_buf[0] = WM_REDRAW;
                     msg_buf[1] = phys_handle;
                     msg_buf[2] = 0;
                     msg_buf[3] = win_handle;
                     msg_buf[4] = wrkx;
                     msg_buf[5] = wrky;
                     msg_buf[6] = wrkw;
                     msg_buf[7] = wrkh;
                     appl_write( phys_handle, sizeof(msg_buf), msg_buf );
                  break;
*Edit* I think I see one problem. I'm passing the phys_handle instead of the app_id. I think I need APPL_FIND to get the app_id. :?:
charles
Postby charles » Sat Oct 07, 2017 10:49 pm
just a small weary word ,
if you deal with window events and event multi
the system sends out a redraw command automatically to draw your desktop .....
im being vague , but someone here can elaborate....or you will prob encounter by ones self
The radioactive half-life : )
Postby wongck » Sat Oct 07, 2017 11:36 pm
TheNameOfTheGame wrote:I'm slowly learning GEM using PureC so I'm not sure I'm approaching this the right way. Any suggestions is appreciated!
Think this doc here explains the GEM windowing including scrolling.
Postby wongck » Sat Oct 07, 2017 11:55 pm
TheNameOfTheGame wrote:One other thing. I put a printf in the case statement and it prints twice for every down arrow press and I'm not sure why. Is there something that should be done to prevent this double click issue?
Which TOS re you using ?
You may have found the WM_ARROWED bug, where 2 such message are sent.
Read it here (it's German, so Chrome is your friend and search for ARROWFIX).
TheNameOfTheGame
Postby TheNameOfTheGame » Sun Oct 08, 2017 12:11 am
Wow, I am using TOS 2.06. Never knew about that bug so thanks. 8O
I scrapped the idea above and called the redraw code after processing the UPLINE/DNLINE event. So I have the up/down arrows working now other than the 2 messages being sent. :cheers:
Last edited by TheNameOfTheGame on Sun Oct 08, 2017 12:24 am, edited 1 time in total.
charles
Postby charles » Sun Oct 08, 2017 12:14 am
can u isolate the arrow click and see if it triggers a redraw from the tos?
TheNameOfTheGame
Postby TheNameOfTheGame » Sun Oct 08, 2017 12:24 am
charles wrote:can u isolate the arrow click and see if it triggers a redraw from the tos?
I did but it doesn't trigger a redraw like some of the other events. I think because depending on where the slider is it may not need a redraw so it is left to the program to decide. At least that's what I'm thinking.
TheNameOfTheGame
Postby TheNameOfTheGame » Sun Oct 08, 2017 12:29 am
nvm, found arrfix15.zip. :cheers:
Postby wongck » Sun Oct 08, 2017 1:03 am
WM_ARROWED or any received MSG does not trigger any auto redraw.
You have to do it your yourself, reason being that AES do not know what you want to do when your appl receive that message.
You may need to calculate what is to be drawn, or you may ignore it ( last line or top line for example).
Postby wongck » Sun Oct 08, 2017 1:11 am
mfro wrote:http://atariforge.org/gf/project/libcmini/scmsvn/?action=browse&path=%2Ftrunk%2Fbench%2Fsources%2Fwindow.c&revision=212&view=markup
at the very end.
Very nice indeed mfro.
I wanted to implement call back for my window management as I am using one big if then else loop.
And you have an example here.
Why did I not see it when I used your libcmini years ago ??
mfro
Postby mfro » Sun Oct 08, 2017 8:10 am
at the very end.
Thank you.
But honour to whom honour is due: this is just a (rather weak and quickly nailed together) rip-off of the "Geiß-Brother's" object oriented approach from their book "vom Anfänger zum GEM-Profi" that I still consider one of the best books ever written about clean GEM programming on the ST. Unfortunately, it was only available in German, AFAIK.
You can see their approach (and it should be easy to extract a window-handling skeleton) to the full extent in Phoenix (the database application) that recently made it to GitHub: https://github.com/freemint/phoenix
Postby wongck » Sun Oct 08, 2017 9:53 am
mfro wrote:You can see their approach (and it should be easy to extract a window-handling skeleton) to the full extent in Phoenix (the database application) that recently made it to GitHub: https://github.com/freemint/phoenix
Thank you for pointing me to the right direction :)
Return to “C / PASCAL etc.”
