Help opening a window in Pure C
TheNameOfTheGame
Postby TheNameOfTheGame » Thu Oct 05, 2017 6:26 pm
I am trying for the first time to program Gem in Pure C and my program is hanging at v_opnwk. :?
Can someone check this short code out an tell me what I am doing wrong? Thanks for any help!
TEST.PRJ
TEST.PRG
PCSTART.O         ;PC-Startup-Code
TEST.C            ;Main program
PCSTDLIB.LIB
PCTOSLIB.LIB
PCGEMLIB.LIB
TEST.C
#include <tos.h>
#include <aes.h>
#include <vdi.h>
int work_in[11], work_out[57];
void event_loop ( void );
void main( int argc, char *argv[], char *envp[] ) {
   int i, x, app_handle, win_handle;
   int fullx, fully, fullw, fullh;
   char *win_text;
   /* application init */
   appl_init();
   /* open vwork */
   app_handle = graf_handle( &x, &x, &x, &x );
   work_in[0] = 2 + Getrez();
   for (i = 1; i < 10; work_in[i++] = 1);
   work_in[10] = 2;
   v_opnwk( work_in, &app_handle, work_out );  /* Hanging Here!  */
   /* setup window */
   wind_get ( 0, WF_WORKXYWH, &fullx, &fully, &fullw, &fullh );
   win_handle = wind_create( NAME|CLOSER, fullx, fully, fullw, fullh );
   wind_set( win_handle, WF_NAME, "Example", 0, 0);
   wind_open( win_handle, fullx, fully, 300, 200);
   win_text = "Hello World!" ;
   /* draw window text */
   v_gtext( app_handle, 10, 60, win_text );
   /* process events */
   event_loop();
   /* close window and exit program */
   wind_close( win_handle );
   wind_delete( win_handle );
   rsrc_free();
   v_clsvwk( app_handle );
   appl_exit();
void event_loop(  void ) {
   int msg_buf[8];
   do {
         evnt_mesag ( msg_buf );
   } while ( msg_buf[0] != WM_CLOSED );
Re: Help opening a window in Pure C
Postby czietz » Thu Oct 05, 2017 7:26 pm
v_opnvwk! You cannot open a physical workstation for the screen, it's already open by the AES. You need a virtual workstation.
http://cd.textfiles.com/ataricompendium ... /CHAP7.HTM
Didn't have a look through the rest of the code...
TheNameOfTheGame
Postby TheNameOfTheGame » Thu Oct 05, 2017 8:02 pm
Ok thanks. I'm following Peter Lane's AHCC guide so I knew I did something wrong. :lol:
Thanks for the link, I'll read it.
*Edit* Yep, I made a typo..I was using v_opnwk instead of v_opnvwk... :?
*Edit 2* Success! Thanks, that fixed it! :cheers:
Postby wongck » Thu Oct 05, 2017 11:43 pm
Here's a bit of information by Dr CoolZic
viewtopic.php?t=14954
These will start your creative juice flowing.
TheNameOfTheGame
Postby TheNameOfTheGame » Thu Oct 05, 2017 11:56 pm
Thanks, I'm working through Peter Lane's guide now and adjusting it from AHCC to PureC. Last time I programmed GEM was over 20 years ago and that was in machine code. :lol:
It's starting to come back to me though. I'll go through the thread you linked. It seems like it will be very helpful! :cheers:
TheNameOfTheGame
Postby TheNameOfTheGame » Fri Oct 06, 2017 1:04 pm
nvm...I found the answer in the Compendium! :cheers:
TheNameOfTheGame
Postby TheNameOfTheGame » Tue Oct 10, 2017 12:09 am
After a couple days getting back into GEM, I have a functional window which can be moved around, resized, use the sliders, etc.
I was working with Peter Lane's AHCC guide, but I am using PureC so it required some changes. Also I made it simpler than Peter's. All the code is in one file. I attached the code and project file here if anyone wants to look at it. It is just a proof of concept as I am learning to program GEM in C and is not optimized.
However, there is one question I have. Printing the text in the window is by "v_gtext". However, I have to add some fudge factors to it to get the text in the work area of the window.
      v_gtext( phys_handle, wrkx - (cols_offset * charw), wrky - 4 + (charh * ( i + 1 )), win_text[i + rows_offset] );
I am getting wrkx and wrky from:
   wind_get( win_handle, WF_WORKXYWH, &wrkx, &wrky, &wrkw, &wrkh );
But if I don't add the fudge factor, wrky - 4 + charh * ( i + 1 ) it prints the first line under the info line. I have to start the first line basically 1 extra line down from wrky.
Without the other fudge factor wrky - 4 + charh * ( i + 1 ) it prints 4 pixel lines down from the bottom of the info bar.
With Fudge Factors__________________________________________Without Fudge Factor 1
Image Image
Anyone know why that is?
TEST.zip
Postby wongck » Tue Oct 10, 2017 11:01 am
Looks correct to me. It's your text alignment.
So if you write at 0,0 ( or your top left corner work space) then your last row of pixel of your text will be at row 0.
Take a look at vst_alignment(), if it makes sense to you.
TheNameOfTheGame
Postby TheNameOfTheGame » Tue Oct 10, 2017 2:48 pm
Ah, thanks. I looked at vst_alignment and see what you are saying.
That makes much more sense now. :D
Return to “C / PASCAL etc.”
