TOS compliant reboot from C
Badwolf
Postby Badwolf » Thu May 25, 2017 1:18 pm
Hi all,
I'm a bit of a lurker, so apologies for the question out of the blue. I fancied doing a bit of Atari programming as I never really got around to it back in the 90s!
I've put together a AUTO program to set my Falcon's NVRAM, time/date etc. since the battery died, but it needs a reboot after changing the values and I can't for the life of me figure out how to do that legally in C (I'm using both Pure and GCC).
There's a Shutdown() command for MiNT, but I was hoping there was a TOS-legal way to do this. I assume it'd involve typdefing a function to a pointer location and calling it, but I've not had a lot of luck.
Would anyone be willing to point me in the right direction?
Thanks,
BW.
Greenious
Re: TOS compliant reboot from C
Postby Greenious » Thu May 25, 2017 1:24 pm
Well, the easiest way is to grab the values off the reset vector, set ssp and jump to TOS...
Vector 0 (address $0) is SSP at boot.
Vector 1 (address $4) is TOS starting address.
That would basically do a warm reset.
viewtopic.php?t=5040
Arne
Postby Arne » Thu May 25, 2017 1:43 pm
typedef void (*tFunction)(void);
static const      kWarmStartAddress_U32 = 0xE00000ul;
tFunction         JumpToTOS;
uint32_t         myJumpAddress_U32;
myJumpAddress_U32 = (*(volatile uint32_t*) (kWarmStartAddress_U32 + sizeof(uint32_t)));   /* slot #0 is occupied by SSP   */
JumpToTOS = (tFunction) myJumpAddress_U32;
JumpToTOS();
Badwolf
Postby Badwolf » Thu May 25, 2017 2:08 pm
Thanks guys,
This is actually pretty close to what I've been trying so I'll give it another crack tonight with Arne's code when I can get my hands on a vanilla TOS machine.
Cheers! :-)
BW.
Postby simonsunnyboy » Thu May 25, 2017 5:38 pm
IIRC there is a BIOS compliant way without having to explicitly access system adresses.
use the BIOS call to read the exception vectors for the reset and then use Supexec() from XBIOS to actually call it.
ThorstenOtto
Postby ThorstenOtto » Fri May 26, 2017 2:48 am
There a 2 shortcomings in Arne's example: you have to use Supexec() to execute the function, otherwise it will just give you 8 bombs for a privilege violation. Also, you should use the value from address 0x4, which is a mirror of the ROM. You don't have to worry about the value at address 0x0 (the initial SSP), since it is also mirrored from the ROM and contains a branch instruction instead of something useful, so TOS ignores it and sets up a stack of its own.
Badwolf
Postby Badwolf » Fri May 26, 2017 10:02 am
Sheepish confession time: I wasn't calling Super() [or Supexec()] :oops:
Thanks all for the hints [esp. Simonsunnyboy who mentioned Supexec() which gave me the forehead-slap moment].
This is what I'm using now. I'm curious that if there is an even more BIOS-friendly way to do it, that'd be ace.
(This is the Pure C version, the MiNT/gcc version will probably use OSHEADER and int32_ts instead)
#include <tos.h>
long get_os_start() {
        SYSHDR *sysbase;
        sysbase = *( (SYSHDR**)(0x4f2L) );
        return sysbase->os_start;
int main() {
        long os_start;
        os_start = Supexec( get_os_start );
        Supexec( os_start );
        return 255;
Return to “C / PASCAL etc.”
