SINCE NO THREADS EXIST ABOUT WINDTAB
charles
Postby charles » Mon Sep 18, 2017 1:03 am
WHY DOES THIS LISTING RUN FINE ONCE IN THE EDITOR THEN WHEN NO EDITS MADE NOT EXECUTE A SECONF TIME
IS IT THE WINDTABS FAULT .....OR MINE ,,,LOL?
SAVE "b:\fentre2.gfa"
LIST "b:\fentre2.lst"
KILL "*.BAK"
DEFINT "a-z"
DIM buffer&(7)  ! buffer for 8 messages (evnt_mesag)
DIM opened(1)
'  Initialize table:
WINDTAB(1,1)=&X111111    ! attributes
WINDTAB(1,2)=20    ! coords window 1
WINDTAB(1,3)=20
WINDTAB(1,4)=200
WINDTAB(1,5)=120
WINDTAB(2,1)=&X111111    !attributes
WINDTAB(2,2)=50    ! coords window 2
WINDTAB(2,3)=50
WINDTAB(2,4)=200
WINDTAB(2,5)=120
ap_id=APPL_INIT()
'  Detect desktop size (work area)
VOID WIND_GET(0,4,x_desk,y_desk,w_desk,h_desk)
WORD{WINDTAB+52}=x_desk
WORD{WINDTAB+54}=y_desk
WORD{WINDTAB+56}=w_desk
WORD{WINDTAB+58}=h_desk
IF FN create_windows
  VOID FORM_ALERT(1,"[3][Its not possible | window id handle failure!][OK]")
ELSE
  ' Parameter lines for title and info:
  t1$="Window 1"+CHR$(0)
  i1$="Just a note:"+CHR$(0)
  t2$="Window 2"+CHR$(0)
  i2$="Just another note:"+CHR$(0)
  ' next command likes a value stored in a Low and High ( DIV 2^16 et MOD 2^16)
  ' title: function# 2
  ' info:  function# 3
  VOID WIND_SET(WINDTAB(1,0),2,WORD(SWAP(V:t1$)),WORD(V:t1$),0,0)
  VOID WIND_SET(WINDTAB(1,0),3,WORD(SWAP(V:i1$)),WORD(V:i1$),0,0)
  VOID WIND_SET(WINDTAB(2,0),2,WORD(SWAP(V:t2$)),WORD(V:t2$),0,0)
  VOID WIND_SET(WINDTAB(2,0),3,WORD(SWAP(V:i2$)),WORD(V:i2$),0,0)
  ' open windows:
  FOR i=0 TO 1
    VOID WIND_OPEN(WINDTAB(i+1,0),WINDTAB(i+1,2),WINDTAB(i+1,3),WINDTAB(i+1,4),WINDTAB(i+1,5))
    opened(i)=1
    output_text(i)
  NEXT i
  REPEAT
    ' Event message:
    VOID EVNT_MESAG(V:buffer&(0))
    w=0
    WHILE NOT (buffer&(3)=WINDTAB(w+1,0) OR w=2)
      PRINT w
      INC w
    WEND
    IF window<2                    ! Which window (1 ou 2)?
      IF buffer&(0)=20             ! Message Redraw
        GOSUB redraw(w)
      ELSE IF buffer&(0)=21        ! Window-Topped
        VOID WIND_SET(WINDTAB(w+1,0),10,0,0,0,0)
      ELSE IF buffer&(0)=23        ! La boŒte plein ‚cran a ‚t‚ cliqu‚e
        WINDTAB(w+1,2)=WORD{WINDTAB+52}+2             ! Amener la window … sa taille maximale
        WINDTAB(w+1,3)=WORD{WINDTAB+54}+2
        WINDTAB(w+1,4)=WORD{WINDTAB+56}-6
        WINDTAB(w+1,5)=WORD{WINDTAB+58}-6
        VOID WIND_SET(WINDTAB(w+1,0),5,WINDTAB(w+1,2),WINDTAB(w+1,3),WINDTAB(w+1,4),WINDTAB(w+1,5))
      ELSE IF buffer&(0)=27        ! BoŒte de taille
        WINDTAB(w+1,4)=buffer&(6)           ! Lire la taille dans le message
        WINDTAB(w+1,5)=buffer&(7)
      ELSE IF buffer&(0)=28        ! BoŒte de d‚placement
        WINDTAB(w+1,2)=buffer&(4)           ! x et y sont inchang‚s
        WINDTAB(w+1,3)=buffer&(5)
      ELSE IF buffer&(0)=22        ! BoŒte de fermeture
        VOID WIND_CLOSE(WINDTAB(w+1,0))
        VOID WIND_DELETE(WINDTAB(w+1,0))
        opened(w)=0
      ENDIF
    ENDIF
  UNTIL NOT ((opened(0)=1) OR (opened(1)=1))
ENDIF
VOID APPL_EXIT()
END
> PROCEDURE output_text(w)
  ' Afficher le contenu de la window
  ' dŠs le lancement du programme
  ' Passer la taille de la zone de travail:
  VOID WIND_CALC(1,WINDTAB(w+1,1),WINDTAB(w+1,2),WINDTAB(w+1,3),WINDTAB(w+1,4),WINDTAB(w+1,5),x,y,w,h)
  x2=x+w-1
  y2=y+h-1
  CLIP x,y TO x2,y2
  draw_text(x,y,x2,y2,x,y)
  CLIP OFF
RETURN
> PROCEDURE draw_text(x1,y1,x2,y2,x,y)
  ' Parameter:
  '    x1,y1,x2,y1 est le rectangle qui doit ˆtre redessin‚,
  '   donc effac‚. x,y est l'angle sup‚rieur gauche du texte.
  '   x,y ne sont pas forc‚ment identiques … x1,y1 !!!  '
  ' D‚sactiver la souris, qui ne sert qu'… nous gˆner  '
  HIDEM
  ' Effacer la zone de travail:
  BOUNDARY 0
  DEFFILL 0
  PBOX x1,y1,x2,y2
  BOUNDARY 1
  '  Text:  '
  TEXT x+8,y+14,"Hello! This is a Atari window!"
  TEXT x+8,y+30,"A moveable ,resizable window."
  TEXT x+8,y+46,"Quit: Window closer!"
  SHOWM
RETURN
> FUNCTION create_windows
FOR i=0 TO 1
  WINDTAB(i+1,0)=WIND_CREATE(WINDTAB(i+1,1),WORD{WINDTAB+52},WORD{WINDTAB+54},WORD{WINDTAB+56},WORD{WINDTAB+58})
NEXT i
RETURN (WINDTAB(1,0)<0) AND (WINDTAB(2,0)<0)
ENDFUNC
> PROCEDURE redraw(w)
' Recalculate work space:
VOID WIND_CALC(1,WINDTAB(w+1,1),WINDTAB(w+1,2),WINDTAB(w+1,3),WINDTAB(w+1,4),WINDTAB(w+1,5),ax,ay,aw,ah)
VOID WIND_UPDATE(1)
VOID WIND_GET(WINDTAB(w+1,0),11,rx,ry,rw,rh)  ! 11->premier rectangle  '
WHILE rw>0                         ! tant que le rectangle a une largeur
  IF RC_INTERSECT(buffer&(4),buffer&(5),buffer&(6),buffer&(7),rx,ry,rw,rh)
    rx2=rx+rw-1
    ry2=ry+rh-1
    CLIP rx,ry TO rx2,ry2
    GOSUB draw_text(rx,ry,rx2,ry2,ax,ay)
  ENDIF
  VOID WIND_GET(WINDTAB(w+1,0),12,rx,ry,rw,rh) ! 12->rectangle suivant
WEND
CLIP OFF
VOID WIND_UPDATE(0)
RETURN
The radioactive half-life : )
charles
Re: SINCE NO THREADS EXIST ABOUT WINDTAB
Postby charles » Mon Sep 18, 2017 1:40 am
BUT if I change the gfa command WINDTAB to an array wintab&(x,x)
it has changed and can be run over and over with out freezing gfa .....
is this because windtab might be connected to the GB intout and this address is changing within gfa?
SAVE "b:\fentre3.gfa"
LIST "b:\fentre3.lst"
KILL "*.BAK"
DEFINT "a-z"
DIM opened(1)
DIM wintab&(4,33)
'  Initialize table:
wintab&(1,1)=&X111111    ! attributes
wintab&(1,2)=20    ! coords window 1
wintab&(1,3)=20
wintab&(1,4)=200
wintab&(1,5)=120
wintab&(2,1)=&X111111    !attributes
wintab&(2,2)=50    ! coords window 2
wintab&(2,3)=50
wintab&(2,4)=200
wintab&(2,5)=120
ap_id=APPL_INIT()
VOID WIND_GET(0,4,wintab&(0,26),wintab&(0,27),wintab&(0,28),wintab&(0,29))
ELSE
  ' info:  function# 3
  VOID WIND_SET(wintab&(1,0),2,WORD(SWAP(V:t1$)),WORD(V:t1$),0,0)
  VOID WIND_SET(wintab&(1,0),3,WORD(SWAP(V:i1$)),WORD(V:i1$),0,0)
  VOID WIND_SET(wintab&(2,0),2,WORD(SWAP(V:t2$)),WORD(V:t2$),0,0)
  VOID WIND_SET(wintab&(2,0),3,WORD(SWAP(V:i2$)),WORD(V:i2$),0,0)
  ' open windows:
  FOR i=0 TO 1
    VOID WIND_OPEN(wintab&(i+1,0),wintab&(i+1,2),wintab&(i+1,3),wintab&(i+1,4),wintab&(i+1,5))
    opened(i)=1
    output_text(i)
  NEXT i
  REPEAT
    ' Event message:
    w=0
    WHILE NOT (buffer&(3)=wintab&(w+1,0) OR w=2)
      PRINT w
      INC w
    WEND
        GOSUB redraw(w)
        VOID WIND_SET(wintab&(w+1,0),10,0,0,0,0)
        wintab&(w+1,2)=wintab&(0,26)+2             ! Amener la window … sa taille maximale
        wintab&(w+1,3)=wintab&(0,27)+2
        wintab&(w+1,4)=wintab&(0,28)-6
        wintab&(w+1,5)=wintab&(0,29)-6
        VOID WIND_SET(wintab&(w+1,0),5,wintab&(w+1,2),wintab&(w+1,3),wintab&(w+1,4),wintab&(w+1,5))
        wintab&(w+1,4)=buffer&(6)           ! Lire la taille dans le message
        wintab&(w+1,5)=buffer&(7)
        wintab&(w+1,2)=buffer&(4)           ! x et y sont inchang‚s
        wintab&(w+1,3)=buffer&(5)
        VOID WIND_CLOSE(wintab&(w+1,0))
        VOID WIND_DELETE(wintab&(w+1,0))
        opened(w)=0
      ENDIF
    ENDIF
ENDIF
VOID APPL_EXIT()
END
  VOID WIND_CALC(1,wintab&(w+1,1),wintab&(w+1,2),wintab&(w+1,3),wintab&(w+1,4),wintab&(w+1,5),x,y,w,h)
  x2=x+w-1
  y2=y+h-1
  CLIP x,y TO x2,y2
  CLIP OFF
RETURN
  ' Parameter:
  HIDEM
  BOUNDARY 0
  DEFFILL 0
  PBOX x1,y1,x2,y2
  BOUNDARY 1
  '  Text:  '
  SHOWM
RETURN
  FOR i=0 TO 1
    wintab&(i+1,0)=WIND_CREATE(wintab&(i+1,1),wintab&(0,26),wintab&(0,27),wintab&(0,28),wintab&(0,29))
  NEXT i
  RETURN (wintab&(1,0)<0) AND (wintab&(2,0)<0)
ENDFUNC
PROCEDURE redraw(w)
  VOID WIND_CALC(1,wintab&(w+1,1),wintab&(w+1,2),wintab&(w+1,3),wintab&(w+1,4),wintab&(w+1,5),ax,ay,aw,ah)
  VOID WIND_UPDATE(1)
  VOID WIND_GET(wintab&(w+1,0),11,rx,ry,rw,rh)  ! 11->premier rectangle  '
      rx2=rx+rw-1
      ry2=ry+rh-1
    ENDIF
    VOID WIND_GET(wintab&(w+1,0),12,rx,ry,rw,rh) ! 12->rectangle suivant
  WEND
  CLIP OFF
  VOID WIND_UPDATE(0)
RETURN
Return to “GFA BASIC”
