How does this code work ?!?
vodkasoda
Postby vodkasoda » Fri Apr 26, 2013 1:39 pm
I don't understand why/how this code works, how can the IF statement not have a condition on it ?!?
If Injured%(Team%,Plr%)
  @Control.(Cond$)
  @Pr.("  [*Still out for "+Str$(Injured%(Team%,Plr%))+" games*]")
Endif
The statement will only print out if the value of Injured%(Team%,Plr%) is > 0, so is there an implied "not zero" on a statement like this ?!?
Re: How does this code work ?!?
Postby shoggoth » Fri Apr 26, 2013 3:33 pm
It tests for a non-zero value.
vodkasoda
Postby vodkasoda » Fri Apr 26, 2013 3:58 pm
shoggoth wrote:It tests for a non-zero value.
Thanks you, I guessed that's what it must be, but it just looks so odd !!!
Does it work the same for a non-numeric variable, so something like IF A$ would trigger if A$ wasn't empty ?
lp
Postby lp » Fri Apr 26, 2013 7:44 pm
I assume you didn't try it? Reason I say that is the editor won't accept "IF a$". :wink:
You can probably do this though:
IF LEN(A$)
  ' blah
ENDIF
Postby simonsunnyboy » Fri Apr 26, 2013 8:03 pm
Or the more understandable version:
IF a$<>""
  ' do something
ENDIF
vodkasoda
Postby vodkasoda » Wed May 08, 2013 11:45 am
lp wrote:I assume you didn't try it? Reason I say that is the editor won't accept "IF a$". :wink:
IF LEN(A$)
  ' blah
ENDIF
No, lp, I didn't try it, it was just a thought that went through my head when getting the previous reply ...
vodkasoda
Postby vodkasoda » Wed May 08, 2013 11:46 am
simonsunnyboy wrote:Or the more understandable version:
IF a$<>""
  ' do something
ENDIF
Which makes perfect sense and is totally readable & understandable :)
Return to “GFA BASIC”
