STE / STE detect using "Lower byte of the video counter"
Maartau
Postby Maartau » Fri Jun 02, 2017 2:57 pm
Hi :D ,
Here's an excerpt of code found in DBA mag, it's done by Jedi/Sector One/The Heavy Killers.
Can someone done a test on STF and STE, I have no access to my cumputers ATM.
Cheers for your help 8) .
* STE or STFM ? Dats ye question... *
* Code: Jedi/Sector One/The Heavy Killers *
clr.l -(sp)
move #$20,-(sp)
trap #1 Supervisor mode
move.l d0,2(sp) Save user stack
move #37,-(sp)
trap #14 Wait the beginning of the next VBL
addq.l #2,sp
lea $ffff8209.w,a0 Lower byte of the video counter
moveq #74,d0 Randomized value
move.b d0,(a0) Write it
cmp.b (a0),d0 Equality test
bne.s stfm Failed ? => it's a STFM
st ste_flag Otherwise, it's a STE
stfm trap #1 User mode
addq.l #6,sp
...insert the rest of your sourcecode here...
ste_flag dc.b 0
ste_flag if filled with the byte $FF if the computer is a STE, and null
if it isn't the case...
Edit : just noticed the word "cumputer" :lol:...
Re: STE / STE detect using "Lower byte of the video counter"
Postby AtariZoll » Fri Jun 02, 2017 3:02 pm
This is known difference between ST and STE (pls. correct title) . There are some other ways to detect is it STE or just ST.
Greenious
Postby Greenious » Fri Jun 02, 2017 3:12 pm
Depending on TOS version, you can always check the cookiejar.
viewtopic.php?t=5040
Maartau
Postby Maartau » Fri Jun 02, 2017 3:17 pm
Peter : I have this source since a moment on my HD but no access to real HW, I was wondering if it worked.
Of course, I use other ways to detect STE/ST, it was just curiousity :) .
Greenious
Postby Greenious » Fri Jun 02, 2017 3:35 pm
Maartau wrote:Of course, I use other ways to detect STE/ST, it was just curiousity :) .
I'm curious aswell as to how many different ways you can reliably identify the machine. So don't quit on my account.
But hijacking the buserror vector and poke around at select memorylocations is one way.
Also a way to find undocumented memory locations, and I know there are some. On both STE & F030... I'm not sure about the ST though.
I did that by scanning all hw address space and simply saving any address that didn't generate a buserror.
Never got around to analyze it though, and I'm pretty certain none is of practical use, except perhaps for the config solderpad/dipswitch in STE that should be mapped in memoryspace but afaik never been nailed down to an actual address. I also suspect the STE got the Mega STE RTC mapped in memory aswell, and there is probably suitable signals to easily retrofit a compatible RTC in all STEs. etc
Postby czietz » Fri Jun 02, 2017 4:28 pm
TOS 2.06 decides STE/ST this way:
   dbasell     equ   $ffff820d   ; addr of low byte of this reg
   dbasel      equ   $ffff8203   ; display base low
   color0      equ   $ffff8240   ; color palette #0
* We detect ST-vs-STe by seeing if the high 7 bits of dbasell are RAM.
* If so then we're an STe.
   move.b #$5a,dbasell    ; see if dbasell is RAM
   tst.b   dbasel         ; read another register to destroy
                          ; capacitance effects; dbasel is 00.
   move.b   dbasell,d0    ; read; don't say cmp.b because that
                          ; would put $5a on the bus.
   cmp.b   #$5a,d0        ; NOW cmp.b
   bne   memST
   clr.b   dbasell        ; try the test again using zero
   tst.w   color0         ; color0 is $FFF
   tst.b   dbasell        ; read back - should be zero.
   bne   memST
; OK, dbasell holds its value: you're an STe.
memST:   [...]            ; for ST
Greenious wrote:except perhaps for the config solderpad/dipswitch in STE that should be mapped in memoryspace but afaik never been nailed down to an actual address
I think it is quite well known -- for example from the STE schematic -- that these are accessed in the high byte of $FF9200. Note that you have to use a word access move.w to read them, move.b won't work.
Greenious wrote:I also suspect the STE got the Mega STE RTC mapped in memory aswell
There's nothing to suspect, STE and MegaSTE share the same GSTMCU, so both generate the required signals for the RTC.
EDIT: Typo fixed dbasell vs. dbasel in the code above.
Maartau
Postby Maartau » Fri Jun 02, 2017 4:44 pm
Greenious wrote:I'm curious aswell as to how many different ways you can reliably identify the machine. So don't quit on my account.
That was one question of the moment, got methods from here & there.
Hum... That's all in mess in my sources, and I'm interested by rebuidling a shell to ID computers.
Anyway, seriously interested by this topic 8) .
Postby troed » Fri Jun 02, 2017 6:15 pm
My way is the most reliable ;) The same code that detects which wakestate an ST is in can detect whether the GLUE/GSTMCU is STE or ST. Basically the "heart" of the machine.
https://github.com/troed/WSDETECT
/Troed
FedePede04
Postby FedePede04 » Fri Jun 02, 2017 6:46 pm
to see if the shifter is one from a STE write a color greater then $777 to $ff8240 or one of the other color reg. and read it back, if it still the same then it is an STE shifter.
FedePede04
Postby FedePede04 » Fri Jun 02, 2017 6:49 pm
I did not see this code example, but it does what i describe.
i had a discussion with npomarede long ago, and he told me that the shifter of the ST did not save the hole word only up to value $777, so i you write a number that is greater, and ask for it again when it would not be the same.
czietz wrote:TOS 2.06 decides STE/ST this way:
   dbasel      equ   $ffff820d   ; addr of low byte of this reg
   bne   memST
   bne   memST
Greenious
Re: ST / STE detection, "Lower byte of the video counter"
Postby Greenious » Fri Jun 02, 2017 7:03 pm
Actually it's not a given. the Mega STE FPU for example, relies on external logic to generate dtack/CS. I admit I haven't looked at the schematics, but it is a solution they might have chosen for the RTC aswell. Anyway, it's mostly from a curiosity standpoint more than anything else.
Oh, another thing, any objections to me adjusting the topic a bit to reflect the direction this discussion has taken?
Return to “680x0”
