machine language code
charles
Postby charles » Tue May 09, 2017 11:33 pm
its been a while..
im curious about machine language code once again .
I have a small bit of code I wish to read and decipher .
but
its in machine language ..(&H60006...etc etc etc )
my question is how to identify the commands so to exactily figure out what the machine code is computating?
charles
The radioactive half-life : )
Ragstaff
Re: machine language code
Postby Ragstaff » Wed May 10, 2017 5:44 am
Here's a page of 68k opcodes.
You will also need a memory map of the ST, there's some nice ones on the Wiki but it's down at the moment.
Of course, I'm being a little obtuse here Charles. I think you need to do more background reading on how a CPU works before posting a question like this. And perhaps at least do a "hello world" and a few things in assembler before moving on to reading machine code directly from memory.
Greenious
Postby Greenious » Wed May 10, 2017 6:56 am
Reading/writing machine code on a 8 bit CPU is hardcore. Doing it on a 16 bit CPU requires serious autism. :-D
Problem is, an 8 bit CPU only got that many possible opcodes for instructions (2^8=256), with a 16 bit CPU like the 68k, you got thousands with all the possible iterations of adressing modes and whatnot. In theory as many as 2^16=65536. With 32-bit...
But it was common for the better coders on C64 and other 8-bit computers to write directly in machine code, since an assembler would use up way to much of that valuable ram... (nowadays with emulators and PC-based development tools for the 8-bit CPU's, most do it in assembler I think)
If you got devpac, you can always put the code in dc.b statements, compile it and look at it through the debugger.
Or use a debugger and type the opcodes into memory directly.
viewtopic.php?t=5040
charles
Postby charles » Wed May 10, 2017 10:41 am
thats how I used to do it greenious !!
thanks ,,haven't coded in five years .unpractised and dull,,was unfamiliar...and even back then didn't perform too much asm.
I tried breifily loading the statements into tt-digger
but nothng came clear ...
question would you simply type
&H60080000 &H41FA &HFFF62228
&H44A10 &H6754B2BC &HFFFFFFF &H62407003
or separate each code on its own line in st digger?
Greenious
Postby Greenious » Wed May 10, 2017 7:47 pm
I would do dc.w statments in Devpack, like this:
dc.w $H600, $8000, $H600, $8000, $H600, $8000
compile and load it up in the debugger. Haven't used digger so I wouldn't know how to do...
Remember, everything needs to be word aligned. The numbers you use are off. 9 hexnumbers are a longword and a nibble... 5 hexnumbers a word and a nibble,
charles
Postby charles » Wed May 10, 2017 11:42 pm
oh don't you rush me greenious ,,,
you can be certain I will post my results
its a small 50-100 statement code segment so hold on to your hat
will return shortly .....thank you!
charles
Postby charles » Thu May 11, 2017 2:02 am
CODE LAUNCH PARTY DID NOT LEAVE THE GROUND ....DEVPAK JUST SENT A BUCH OF ERROR REPORTS
INCLUDED IS THE MACHINE CODE AT HAND .......
ITS A REATTEMPT AT DEVPAC AFTER FEW YEARS SO SIT BACK AND RELAX WHILE I READ RAGSTAFFS NIG HANDY LITTLE CHART.......
&HE389E209 &H8810007 &HB07C0003 &H67084A01
&H670408C1 &H71401 &HE09AE089 &H51C8FFE2
&H8020017 &H670408C2 &HF0802 &H1F6706
&H820080 &H80002142 &H47000 &H4E75217C
&HFFFFFFF7 &H470FF &H4E75B2BC &HFFFFFFF7
&H62167003 &H1401EE9A &HE08951C8 &HFFF8E89A
&H2820FFF &HFFFF60CE &H217C0FFF &HFFFF0004
&H70FF4E75
charles
Postby charles » Thu May 11, 2017 2:04 am
I KNOW 4E75 IS RTS OR RTE FFFF0004 THE MIDI ACIA?
lp
Postby lp » Thu May 11, 2017 6:50 am
Digger can display instruction mnemonics, no need for all the hex. lol First step might be reading digger manual.
charles
Postby charles » Thu May 11, 2017 10:39 am
I know , its hex im trying to convert back to asm
BenOVR
Postby BenOVR » Thu May 11, 2017 11:50 am
Start:
             bra.s    L01000A                       ; 6008
             ori.b    #$0,d0                        ; 0000-0000
             lea      $fffe(pc),a0                  ; 41FA-FFF6
L01000A:
             move.l   $4(a0),d1                     ; 2228-0004
             tst.b    (a0)                          ; 4A10
             beq.s    L010066                       ; 6754
             cmp.l    #$fffffff,d1                  ; B2BC-0FFFFFFF
             bhi.s    L01005A                       ; 6240
             moveq    #$3,d0                        ; 7003
L01001C:
             lsl.l    #1,d1                         ; E389
             lsr.b    #1,d1                         ; E209
             bclr     #$7,d1                        ; 0881-0007
             cmp.w    #$3,d0                        ; B07C-0003
             beq.s    L010032                       ; 6708
             tst.b    d1                            ; 4A01
             beq.s    L010032                       ; 6704
             bset     #$7,d1                        ; 08C1-0007
L010032:
             move.b   d1,d2                         ; 1401
             ror.l    #8,d2                         ; E09A
             lsr.l    #8,d1                         ; E089
             dbf      d0,L01001C                    ; 51C8-FFE2
             btst     #$17,d2                       ; 0802-0017
             beq.s    L010046                       ; 6704
             bset     #$f,d2                        ; 08C2-000F
L010046:
             btst     #$1f,d2                       ; 0802-001F
             beq.s    L010052                       ; 6706
             ori.l    #$808000,d2                   ; 0082-00808000
L010052:
             move.l   d2,$4(a0)                     ; 2142-0004
             moveq    #$0,d0                        ; 7000
             rts                                    ; 4E75
L01005A:
             move.l   #-$9,$4(a0)                   ; 217C-FFFFFFF7-0004
             moveq    #-$1,d0                       ; 70FF
             rts                                    ; 4E75
L010066:
             cmp.l    #-$9,d1                       ; B2BC-FFFFFFF7
             bhi.s    L010084                       ; 6216
             moveq    #$3,d0                        ; 7003
L010070:
             move.b   d1,d2                         ; 1401
             ror.l    #7,d2                         ; EE9A
             lsr.l    #8,d1                         ; E089
             dbf      d0,L010070                    ; 51C8-FFF8
             ror.l    #4,d2                         ; E89A
             andi.l   #$fffffff,d2                  ; 0282-0FFFFFFF
             bra.s    L010052                       ; 60CE
L010084:
             move.l   #$fffffff,$4(a0)              ; 217C-0FFFFFFF-0004
             rts                                    ; 4E75
lp
Postby lp » Thu May 11, 2017 12:12 pm
charles wrote:I know , its hex im trying to convert back to asm
No, you don't know. instruction mnemonics = asm as you call it
Digger can easily output the listing above that someone else has so graciously done for you.
BenOVR
Postby BenOVR » Thu May 11, 2017 12:21 pm
Basically you can use any assembler/disassembler to do it.
Just transform the hexa data to a form your assembler understand. Assemble the thing. Then use the disassembler to get the assembler listing.
For instance I used vasm to assemble to binary the hexa sequence after converting it to the proper motorola syntax (dc.l $60080000 ...). Then I used sourcer68 my own disassembler to get the listing.
On the Atari I would have use GENST and MONST as they are the tool I know the best. And for such a simple thing to disassemble monst would have done the work just fine.
charles
Postby charles » Thu May 11, 2017 10:59 pm
thanks benovr
here is what happened last night for the hour or so I had to try:
yes i was off to a rough start ,,,
forgot to indent or "tab" the devpak listing so I received errors
and forgot that
hex &hxx under devpak
is $XX
sooner or later !!!
...first time after five years , stuff doesn't come back quickily
im not sure if anybody here knows what this is ,
but the source code just calls it a vlq ,,
short for variable length quanity
I know in basic I can write one that's about five or six lines of code
was curious..(and still am ) at what all these extra command/functions are
within this chunky packed code...
this is wiki on v.l.q.
https://en.wikipedia.org/wiki/Variable-length_quantity
charles
Postby charles » Thu May 11, 2017 11:06 pm
o.t.
who did the art for the gfa basic on your avatar lonny?
cool!!
that's how signals are transported to satellite..in little packets
charles
Postby charles » Thu May 11, 2017 11:15 pm
benovr
the code ,
I have a question
the statement
appears to me I would enter in devpak as two dc.w statements
do I type in ?
DC.W $51c8,$FFF8
or
is it a long
DC.L $51c8fff8
different in appearance than a code like
ror.l #7,d2 ; EE9A
which would be
dc.w $ee9a
charles
Postby charles » Fri May 12, 2017 12:12 am
nemonics are really drifting ,,, easily identifying the way they forged is difficult
BenOVR
Postby BenOVR » Fri May 12, 2017 12:15 am
As M68k memory order is big endian
   dc.b $51,$C8,$FF,$F8
   dc.w $51C8,$FFF8
   dc.l $51C8FFF8
are exactly the same byte sequence in memory.
My disassembler splits the opcode to help understand how it's encoded.
Postby AtariZoll » Fri May 12, 2017 8:42 am
Well, this sentence describes perfectly this really pointless thread :D
I think Charles, that you should get some Altair prehistoric computer, from seventies of previous century + where binary/hex input was the only way.
With some more modern computer, and it includes those released years before Atari ST people using assemblers for that task. Furthermore, assembler does much more - it calculates addresses, makes relocation table, checks for errors. Then there is lot of options - so many things. Of course we can not go in all it here, that's long story.
I do frequently some simple code changes/patches in game adaptations - like unlimited lives, inserting code for exiting from game, saving gamestate and like. In such cases I usually use direct machine code, just because all it is in my head, and there are some 10 instructions involved.
Like:
  lea  address,a1
  lea  rdLoc+gamex-rmdc.w,a0
  move.w  #$4EF8,(a1)+
  move.w  a0,(a1)
$4EF8 is short jump in lowest 32KB space.
But if there is need for something what I don't know, instead of looking is some tables for machine code, I just use mnemonics this way:
   lea  patch(pc),a0
   lea  dest,a1
   moveq  #4,d1   * for 10 bytes
 .cop  move.w (a0)+,(a1)+
   dbf  d1,.cop
 * continuing launch here ,,,,
patch  clr,l  d0
   move.l  #value,d1
   rts
charles
Postby charles » Mon Aug 13, 2018 9:37 pm
hi
thought I was getting somewhere with a disassembler routine I wrote
I tried reassembling
most my code I write is functioning from data lines
and as a word
this wont take
&HB03C
I use a word array
and try reading values into it
but once it encounters this line of code it croaks
saying not word
how can I get around this ??
and what really is happening ,,,does the atai just store stuff as 8bit ithought it was a 16/32 bit ????
Charles
mlynn1974
Postby mlynn1974 » Tue Aug 14, 2018 9:39 pm
Hi Charles,
Are you writing a disassembler?
The standard notation for hexadecimal encoding in Hisoft Devpac is to prefix with $ not &H
I think the &H notation was popular with Atari BASIC (8-bit) and to a lesser extent GFA BASIC. I never used K-Seka.
B03C 0000 disassembles to CMP.B #0,D0
so the prefix $B03C is cmp.b d0 and the next word indicates the immediate word 0.
B03C 0001 disassembles to CMP.B #1,D0
so the prefix $B03C is cmp.b d0 and the next word indicates the immediate word 1.
B23C 0000 disassembles to CMP.B #0,D1
so the prefix $B03C is cmp.b d1 and the next word indicates the immediate word 0.
The 68000 pads out most opcodes to 2 bytes so it is reading from 16 bit aligned words.
The instructions are bitfielded to indicate the instruction part, the addressing mode, the source and destination operands.
A really amazing book you should try to find is MC68000 Assembly Language Programming by Brian Bramen:
https://www.amazon.co.uk/MC68000-Assemb ... ds=mc68000
You shouldn't need to pay more than a few pounds if you can find one in a second hand book shop (not Amazon). I got my copy in a second hand book store for £1 many years ago. It is the book that contains the clock cycle sheet I got a photo copy of from Neilly when I was at college.
Regards,
Michael.
charles
Postby charles » Tue Aug 14, 2018 9:53 pm
thanks micheal
well I have a small "ripper" disassembler written
however Theres a lot to conform to with these data types
youre right the line of code was cmp.b and the second word part was #247
but this is a multi applicable thread because im intergrating machine code with gfa basic
im trying to gain understanding if machine code is in memory as byte ....word or long
gfa permnits variables byte 0 to 255
word-32768 to 32767
and long really big 4 bit -2147cxcxcxcx to 2147xcxcxcxcx I forgot this was off top of my head
but when I read $B03C its larger than gfa word
causing editor to crash ....
so whats best way to read lines of machine code into array ?
ill check that book out think I might own a copy already
charles
Postby charles » Tue Aug 14, 2018 10:03 pm
I hate putting mach code into a string$
so I place into array or malloc memory
Postby rockyone » Tue Aug 14, 2018 10:44 pm
Charles:but when I read $B03C its larger than gfa word causing editor to crash ....
I did not look in the GFA command.
but I guess you have:
A% = LOW ($B03C)
PRINT A% and $FFFF, $BO3C, "It's magic !!" ' :mrgreen:
charles
Postby charles » Tue Aug 14, 2018 11:04 pm
good one rockyone !!
the combination of commands truly amaze me ....
this might work , but the attempt of my effort is to put &HB03C into a word value
which in gfa is a& a two byte integer
A% is a 4 byte long interger
ill try . might be some convinceing
Return to “680x0”
