GFA Debugger - Trap#6 exception
tcat
Postby tcat » Sun Nov 27, 2016 3:33 pm
I have GFA Assembler disk, it has assembler and I also got GFA debugger to go along with it.
It works just fine, except debugger raises an exception.
I started this post here in `Application' section,
viewtopic.php?f=14&t=30764&p=306199#p306147
I have never debugged anything on ATARI, but I wish to find out the problem, I may be close as it seems the debugger fails over user defined Trap #6.
Any ideas much appreciated.
Many thanks
Tomas
tcat
Re: GFA Debugger - Trap#6 exception
Postby tcat » Tue Nov 29, 2016 8:58 am
Now I see why `GFA-DBG.PRG' bombs on start with an exeception. It simply does not have Trap#6 handler installed. I do not understand, as in the manual it declares it uses Trap#6 for internal memory access.
I coded this little routine to install a "hook" on Trap#6 to aid debugging. It is far from perfect, as it does not return in User mode, also return address is not exactly right.
However, `GFA-DBG.PRG' with this handler installed does not bomb on start any longer. I can even run "L" and "D" commands, also "QUIT". Other commands will not work as the handler provides no memory access, it only returns to the caller.
* program to install a helper for debugging:
* simply provide a ram "hook" on trap 6.
* TODO: return in User mode with USP reset
* as currently returns in Super mode
* Deduce memory access routine for `GFA-DBG.PRG'
* compiled with Atari MADMAC macro assembler
* linked with Atari ALN linker
        .include atari
        .text
        Super                   ; Macro enter Super mode
        move.l  #ntrap6,$98     ; Install Trap#6 handler
        User                    ; Macro enter User mode
        Ptermres #$180,#0       ; Macro terminate to GEM
ntrap6:                         ; Handler for Trap#6
        move.l  usp,a0          ; Save
        move.l  a0,tr6ret       ;   USP for future use
        lea     4(a0),sp        ; Fetch return address
        nop
        nop                     ; TODO some processing to happen here
        nop
        rts                     ; Return from Trap
        .bss
tr6ret: ds.l    1               ; Saved USP
        end
How can I return in User mode with correct return address?
Many thanks
Tomas
tcat
Postby tcat » Tue Nov 29, 2016 6:03 pm
I have a revised version of the Trap#6 handler routine.
I realised that `RTE' instruction should generaly be used in Trap/Exception routines, to return back, as it seems caring for switching to User mode, also resumes at address after the call.
However I needed to fetch a return address that is explicitly pushed onto the stack by `GFA-DBG.PRG'.
Code excerpt, calling to Trap#6>>>
74cb2    pea $74ccc          ; push return address
74cc6    jmp $716c8          ; calling to Trap#6 hapens here
74ccc    ...                 ; code from trap handler should return here
74cd2    rts
EDIT: comment `Ptermres'
Revised Trap#6 handler>>>
* `RAMTRAP6.S'  - Trap#6 memory handler
*  assemble & install before running `GFA-DBG.PRG'
* TODO:
* assemble with Atari MADMAC macro assembler
* link with Atari ALN linker
        .include atari
        .text
        Ptermres #$180,#0       ; Macro terminate and stay resident, $180 bytes reserved
        move.l  usp,a0          ; Save user stack
        move.l  a0,tr6ret       ;  for future use
        clr.l   -(sp)           ; 0=OK result
        move.w  #$20,-(sp)      ; Enter
        trap    #1              ;  User mode
        addq.l  #6,sp           ; Correct stack, l+w=6bytes
                                ; TODO: some memory processing here
        move.l  tr6ret,sp       ; Restore user stack
        rts                     ; Return from trap
        .bss
tr6ret: ds.l    1               ; Saved USP user stack
        end
GFA Debugger can now support "D", "L", "QUIT" commands.
I wish to disassemble `GFA-DBG.PRG' to a file.
Can anynone suggest a good disassembler outputting to a file, ideally anotating GEM/DOS calls?
Many thanks in advance.
Tomas
Postby simonsunnyboy » Tue Nov 29, 2016 6:05 pm
EasyRider was once recommended as a decent disassembler on the ST to me. It works quite well.
tcat
Postby tcat » Thu Dec 01, 2016 12:03 pm
Hi Simone,
Many thanks.
`EasyRider' is excellent. I have disassembled GFA-Debugger with it. Just looking into the code, I do not see the logic yet as Trap#6 seems never installed.
The code makes calls to Malloc/Mfree at various places. At start it requests $2000 bytes, then it smashes register D0, that has the memory base just allocated, with a flag $3F. Than it calls Trap#6 and stores D0=$3F as a reference to this memory block.
Based on this, updated Trap#6 handler here>>>
* TODO:
* assembled with Atari MADMAC macro assembler
        .include atari
        .text
                                ;  $180 bytes reserved
                                ;  0=OK result
        move.l  a0,-(sp)        ; Save A0
        move.l  usp,a0          ;  user stack
        move.l  a0,tr6ret
        cmp.l   #$3f,d0         ; Flag 3F?
        beq.b   flag3f
        bra.b   usr             ; No, Goto user mode
flag3f: move.l  d1,d0           ; Yes, Restore D0 Malloc/Mfree base
usr:    clr.l   -(sp)           ; 0=Keep D0
        trap    #1              ;  user mode
        movea.l (sp)+,a0        ; Restore A0
        movea.l tr6ret,sp       ; Restore user stack
        .bss
tr6ret: ds.l    1
        end
I also attach GFA-Debugger disassembly, so anyone can follow what I am up to. Any tips are greatly appreciated.
With `RAMTRAP6' installed, GFA-Debugger can intercept all commands as per the user manual, however does not recognise parameters.
gfa-dbg.q.zip
Could it be that the code is obfuscated as part of some s/w protection?
Tomas
tcat
Postby tcat » Fri Dec 02, 2016 3:10 pm
I am not able to make much progress, but I have a new observation. I tried to also debug `GFA-DBGA.PRG' which is a companion resident debugger version. And I was surprised to see a TRAP#6 handler installed.
This gave me a new hope, so I also disassembled `GFA-DBGA.PRG', now trying to compare the results.
I am lead to beleive the codes should be almost identical except a few initial branches, in fact they differ a lot more.
Conclusion>>>
`GFA-DBG.PRG' - transient version does not install TRAP#6
`GFA-DBGA.PRG' - resident version DOES install trap handler
Tomas
tcat
Postby tcat » Sat Dec 03, 2016 8:58 pm
Comparing both disassemblies further, proved that binaries are corrupt. Furtunately each binary seems corrupt at different place, as the codes are almost identical I can try to patch good parts between them.
Resident debugger version seems corrupt only in one part, while transient one quite many.
I enclose disassembly of `GFA-DBGA.PRG' too, so anyone can follow.
gfa-dbga.q.zip
I will then try to re-assemble modified source, what could also come in handy, some kind of monitor program that would allow modifing code while debuging it.
Any good monitor programs to recommend?
BTW, this seems TRAP#6 handler>>>
L00D6:DC.B      ' O\',$88,'#',$C8
      DC.L      L097E
      DC.B      'Ns'
      DC.L      L00ED
      DC.B      'Debugger'
L00D7:JMP       (A0)
L00D8:BSR.S     L00DF
L00D9:BSR.S     L00DF
L00DA:BSR.S     L00DF
L00DB:BSR.S     L00DF
L00DC:BSR.S     L00DF
L00DD:BSR.S     L00DF
L00DE:BSR.S     L00DF
      NOP
L00DF:MOVEM.L   A0-A6/D0-D7,L08D2
      MOVE.L    (A7)+,D6
      SUBI.L    #L00D9,D6
      MOVE.W    L08D8,L08DA
      MOVE.W    (A7)+,L08D8
      RTE
Many thanks.
Tomas
tcat
Postby tcat » Fri Dec 09, 2016 8:48 pm
I have patched by hand a portion of `gfa-dbga.q' disassembly, that required some 352 label relocations.
That is just a first try, and now I wish to re-assemble back to the executable, so I can test further.
I use ER Macro Assembler found on the `EasyRider' disk, altough assembly gives no errors, I am not getting any program generated.
Perhaps I am just missing some command line option?
Can anyone please help, perhaps if there is a `handbuch' available somewhere?
Many thanks.
Tomas
tcat
Postby tcat » Wed Dec 14, 2016 10:49 am
I discovered that my copy of ER Assembler is also corrupt, what a bad luck. Although it does assemble example code provided on the disk, it does not generate executable either.
The advantage of ER Assembler probably is, it can process output from ER Disassembler directly without need of any code reformatting.
So I took `CONVERT.PRG' tool recommended here at the forum, reformatted assembly listing, and assembled using GFA-Assembler.
The binary has the size of 66750 bytes, exactly same as the corrupt original, a promissing indication, that I may be close.
Indeed, resident debugger now seems to process all commands as per manual.
Although it does things, it may not be perfect, as I did not relocate symbols around some vectors, I believe might be jump tables. Simply I do not know what to do about them, they look like this.
L0824:DC.L      L052A
      DC.L      L052C
      DC.L      L0528
      DC.L      L052D
      DC.L      L0544
      DC.L      L0535
      DC.L      L0537
      DC.L      L0486
L0825:DC.L      L0580
      DC.L      L056E
      DC.L      L056F
      DC.L      L0570
      DC.L      L0571
      DC.L      L0572
      DC.L      L0573
      DC.L      L0574
      DC.L      L0580
      DC.L      L0580
EDIT Jan-12'17, as of today all pathed references reclocated in jump tables as well
Tomas
tcat
Postby tcat » Mon Dec 19, 2016 11:18 am
I am attaching GFA-Assembler updated image.
gfa_assembleur2.st
image 724K contains:
assemble.ec*   contenu.txt*  gfa-asm.inf*   kompat.mon*    printer.hex*
assemble.key*  convert.prg*  gfa-asm.prg*   make_hex.is*
atari.is*      demo.txt*     gfa-dbga.prg*  make_hex.ttp*
call_deb.prg*  desktop.inf*  gfa-dbg.prg*   printer.cfg*
329K used
Updated contents:
`gfa-dbga.prg' - patched, tested, TODO relocate a few jumps in a table
`call_deb.prg' - reassembled, recoded, corrected
`convert.prg' - reassembled, recoded, corrected
`contentu.txt' - updated
NOTE
`gfa-dbg.prg' - remains as is from the original, has more problems, needs more work to do
Original (corrupt) image can be found here:
http://atariforce.free.fr/stapps1u.htm
Manuals:
http://dev-docs.atariforge.org/files/GFA_Assembler.pdf
http://dev-docs.atariforge.org/files/GFA_Debugger.pdf
You may test and help to improve further.
Tomas
tcat
Postby tcat » Sun Jan 08, 2017 9:54 am
I have now patched `gfa-dbg.prg', transient debugger version, resutling in the binary size same as corrupt original.
This is possibly best I could do just by patching between two code variants, and without any reengineering skills.
EDIT image update Jan-12'17
Please find updated image, which is almost restored to the original version.
gfa_assembleur2.st
NOTE
`gfa-dbga.prg' - 1 patch with relocations
`gfa-dbg.prg' - 3 patches with relocations
Both variants tested, generally supporting all commands.
Inline assembly works, (nice feature to modify just debugged code), trap catching and monitoring works.
Direct assembly execution using `!' e.g. "! moveq #1,d0", works so far only in `gfa-dbga.prg', as `!' is not recognised in `gfa-dbg.prg'. (perhaps easy to fix)
Command `is' does not work properly, is difficult for me to fix. It dumps code and convert into `'tokenised' GFA .is format.
I will try to also share commented disassembly, so anyone with more skills than me may follow, and possibly help.
EDIT sharing now
gfa-dbga-1.zip
gfa-dbg-2.zip
NOTE it seems that debugger can now debug itself :-)
Tomas
Return to “680x0”
