Help Compiling/running STSpeech.s
aag
Postby aag » Fri Jul 06, 2012 9:45 pm
I'm a real novice at 68k but I stumpled across the source code for STSpeech in the below post and thought I'd have a go at compiling it/see how it worked :-
viewtopic.php?f=16&t=2254&start=25
post by by earx » Sat Aug 19, 2006 12:30 pm - towards the bottom.
I've got devpac3 (located from https://sites.google.com/site/stessenti ... ent/devpac), runing on STeem (under an xp laptop,). (The Steem config 4mb ram, tos 2.06 (uk) - 8mhz ).
It took a while to find the options->prefernces to up the editor/buffer from 60000 to 200000 so that I could even load STSPEECH.S in the first place.
I went to options, control - format atari executable and set an output of c:\out.tos
Then program assemble - the code builds ok.
I then close devpack, run out.tos - I get the welcome scren and prompt - but then if I type any text - I get bombs!!!! (And I don't have the know how (yet) on how to debug it).
Am I doing anything wrong???? (I know the pureC/godlib needed steem with tos 2.06) - just wondering if its me, config or if there's something amiss in the actual source?
Thanks in advance!
Andy
aag
Re: Help Compiling/running STSpeech.s
Postby aag » Sat Jul 07, 2012 6:17 pm
I've done a bit of debugging - SMC (self modify code?) is defined as 0
I think its bombing in
L31cc:
  move.l   (a0)+,wave_params
  move.w   (a0)+,wave_params+4
wave_params:
wave_a_step:
   ds.b   1
I'm still reading the devpac manual on debugging.
Any help gratefully received!
Klapauzius
The Klaz
The Klaz
Postby Klapauzius » Sat Jul 07, 2012 6:27 pm
try to insert an EVEN directive in front of the definition of wave_params near the end of the source file.
The label wave_params may not be word aligned, so a move.l to this address would crash.
USE_PITC
  DC.B      'M',$00,$00
 BSS
        EVEN
wave_params:
wave_a_step:
   ds.b   1
http://www.klapauzius.net
aag
Postby aag » Sat Jul 07, 2012 10:41 pm
Thanks for the suggestion
If I add the EVEN where you suggested
 BSS
EVEN
wave_params:
wave_a_step:
   ds.b   1
wave_a_amp:
   ds.b   1
wave_b_step:
   ds.b   1
it still crashes (see the even1.png) - but the debugger is referencing a EVEN label???
The devpac manual seems to say to place the even after the label, so I tried
 BSS
wave_params:EVEN
wave_a_step:EVEN
   ds.b   1
wave_a_amp:EVEN
   ds.b   1
wave_b_step:EVEN
   ds.b   1
wave_b_amp:EVEN
   ds.b   1
wave_c_step:EVEN
   ds.b   1
wave_c_amp:EVEN
   ds.b   1
wave_pos:EVEN
wave_a_pos: EVEN
   ds.b   1
wave_b_pos:EVEN
   ds.b   1
wave_c_pos:EVEN
   ds.b   1         A,B,C positions
hiss_params:EVEN
hiss_a_step:EVEN
   ds.b   1
hiss_a_amp:EVEN
   ds.b   1
hiss_b_step:EVEN
   ds.b   1
hiss_b_amp:EVEN
   ds.b   1
hiss_a_pos:EVEN
   ds.b   1
hiss_b_pos:EVEN
   ds.b   1
L00E3:EVEN
  DS.B      1
L00E4:EVEN
  DS.B      256
PHOBUFF:EVEN
  DS.B      257
L00E6:EVEN
  DS.W      1
L00E7:EVEN
  DS.B      256
ZUEND: END
But it still crashes (see even2.png).
Any other suggetsions?? Thanks
Klapauzius
The Klaz
The Klaz
Postby Klapauzius » Sun Jul 08, 2012 6:56 am
Seems that A0 points to an odd address. A move.l will cause a crash in this case.
Try to replace these two lines:
with something like that:
      movem.l    d0/a1,-(a7)
      lea        wave_params(pc),a1
      moveq      #5,d0
Lcop1:
      move.b   (a0)+,(a1)+
      dbra       d0,Lcop1
      movem.l    (a7)+,d0/a1
aag
Postby aag » Tue Jul 10, 2012 8:07 pm
Yes that code change works!
Thanks a lot!
Andy
Nyh
Postby Nyh » Wed Jul 11, 2012 9:25 am
The original code reads:
L31cc:
  addq.l     #1,a0
I think the addq.l makes a BIG difference in the bombing department.
Hans Wessels
Return to “680x0”
