High CPU usage when emulation stopped
Postby ijor » Sun May 01, 2005 5:28 am
Hi Leonard,
I'm getting extremely high CPU usage when Saint is idle (emulation stopped). Is that normal?
Using latest version 1.99d, on XP SP2, windowed mode. CPU usage stays about the same if Saint is in the foreground or in the background. Changing across the different Saint Menus (Disk, Options, etc) doesn't make any difference either.
leonard
Postby leonard » Sun May 01, 2005 10:48 pm
Oh you're right, I just check it ! ( I recently change it to avoid that bad effect when saint was running, but not inside the menu screens !)
I just made a fix, just wait the next official release :-)
thanks for report !
Leonard/OXYGENE.
Return to “SainT”
