A fullscreen that doesn't work on SainT
unseenmenace
Postby unseenmenace » Fri Jan 28, 2005 4:31 pm
I don't know if you knew this already but I just discovered a fullscreen screen that doesn't work at all on SainT. The screen is "The Best Part Of Creation" from "Punish Your Machine" by the Delta Force. I'm guessing the problem is simply that you haven't looked into fullscreen code in medium resolution since most games and demo's are exclusively low res.
UNSEEN MENACE
Lynx 2 and Jaguar with JagCD
leonard
Postby leonard » Fri Jan 28, 2005 10:13 pm
Oh thanks for that !
I just debug it and I find the problem. That screen use a "self upper border" test method before the show. The way it check upper border didn't work with SainT. I just fixed my video register read routine, and it works !
That screen will work in the next SainT release !
Leonard/OXYGENE.
Gunstick
Postby Gunstick » Sun Jan 30, 2005 8:51 am
leonard wrote:Oh thanks for that !
now I would like to know with what sort of upper border testing method they came up in their twisted minds?
Georges
leonard
Postby leonard » Sun Jan 30, 2005 2:13 pm
Before the screen, they just set a HBL routine to increase a counter each line. Then, they set a VBL wich set 60Hz mode, and wait the video counter to start
wait: move.b $ffff8209.w,d0
beq.s wait
then they read the HBL counter: they have the HBL line where upper border shoud be remove. After that the screen use that var. In SainT 1.99, a nasty bug make the screen begin at line 63 even if the screen is set to 60hz, so the next screen was goosed up.
Please note next SainT will be the only one to display the *complete* screen ( real 800 pixels large, you can read ALL the displayed text :-)) Look at the "Read this text" line at the bottom right of the screen I've attached to that post).
Leonard/OXYGENE.
leonard
Postby leonard » Sun Jan 30, 2005 2:15 pm
hummm *fuc ?!ù* forum ! My attachement seems corrupted. Here is another try inside a ZIP file, should work better.
Leonard/OXYGENE.
Return to “SainT”
