Saint 2.12
leglod
Saint 2.12
Postby leglod » Tue Nov 25, 2008 6:41 pm
Hello , Saint 2.12 is out "est sortie" :)
http://leonard.oxg.free.fr/
2.12
+ Added Video Sync support in windowed mode
* Graphic glitch bug fix when writing to the screen with HW split screen (STE)
* Fix VSYNC wait in windowed mode (new directx driver behavior)
* Bug fix for STE video line width register (FF820F)
* Bug fix for loading if you remove/replace a disk during loading
* Bug fix in sound debug viewer (mono and stereo!)
* Removed D3DENUM_WHQL_LEVEL flag to prevent DirectX to acceed Internet (firewall popup with some new NVidia drivers)
Grilichili bruit de crayon sur papier.
Les dinosaures de la micro :) ... Mini-Z ...
ryo
Re: Saint 2.12
Postby ryo » Wed Nov 26, 2008 7:09 pm
Hello, since some versions, the software will crash when changing selection of repertoire. What to do?
Thank you.
carmel_andrews
Re: Saint 2.12
Postby carmel_andrews » Wed Nov 26, 2008 9:19 pm
issue with saint version mentioned in thread title
it (the emulator) doesn't allow you to select any tos's other then the built in tos (1.02) which is no good if you want to use later tos's and ste tos's
is this a bug or is this intentional
st dragon
Re: Saint 2.12
Postby st dragon » Fri Nov 28, 2008 11:28 pm
carmel_andrews wrote:issue with saint version mentioned in thread title
i have no problem with 1.0 (uk)
ryo
Re: Saint 2.12
Postby ryo » Sun Jan 11, 2009 4:55 pm
I installed the saint on a usb stick to use on my eeepc. the program crashes. Is this normal?
Thank you.
Return to “SainT”
