Hatari debugging with DRI symbols, ignore .a files
Postby simonsunnyboy » Sun Nov 12, 2017 12:32 pm
I was debugging a program with DRI symbols compiled with gcc.
I get the following symbol load output for the Hatari debugger:
NOTE: ignored 3 globally defined equated values.
NOTE: ignored 843 unnamed / local symbols (= name starts with '.L').
NOTE: ignored 19 object file names (= name has '/' or ends in '.o').
WARNING: symbols '_spw_text' & 'liblinkfile.a' have the same 0x11016 address.
WARNING: symbols '_DBG_AddTrace' & 'libnatfeats_debug.a' have the same 0x111d2 address.
WARNING: addresses 0xe646 & 0xe794 have the same '_DB_SearchNextEntryByS' name.
Loaded 155 symbols from '/home/marndt/Projects/Atari/harddisk_menu/example_hd/AUTO/hdmenu.prg'.
Hatari should ignore the .a symbols as well if they only mark start of linked static libraries. This would reduce warning output.
Re: Hatari debugging with DRI symbols, ignore .a files
Postby Eero Tamminen » Sun Nov 12, 2017 11:42 pm
Commited support for that to Hatari:
https://hg.tuxfamily.org/mercurialroot/ ... 16337fa53e
Please test!
Postby simonsunnyboy » Fri Nov 17, 2017 5:32 pm
I tried the new feature and it seems to be working. Thank you! I only get an "ignored" message now.
Postby Eero Tamminen » Fri Nov 17, 2017 8:36 pm
Thanks for feedback! :-)
Btw. Which GCC version you're using? My ancient sparemint version of GCC adds just *.o symbols to the binary, not *.a ones...
Postby simonsunnyboy » Sat Nov 18, 2017 10:24 am
Host: gcc version 6.3.0 20170406 (Ubuntu 6.3.0-12ubuntu2)
Atari target: gcc version 4.6.4 (MiNT 20170417) (GCC)
The latter as provided by Vincent's Ubuntu packages for 17.04
Return to “Hatari”
Users browsing this forum: davemacblack and 2 guests
