ADebog (1.0/2.11/2.13) not running under Hatari
Maartau
Postby Maartau » Wed Dec 07, 2016 3:02 pm
Hi everyone,
I can't use ADebog 1.0/2.11/2.13 in Falcon Mode under Hatari : it loads but when entering an address, it hangs :shrug: .
Anyone knows how to solve it ?
npomarede
Re: ADebog (1.0/2.11/2.13) not running under Hatari
Postby npomarede » Wed Dec 07, 2016 3:34 pm
I never tried this, but I guess 68030 emulation is not complete yet to support some low level cpu operations done by ADebog ; you can try changing "cycle exact" on/off or "mmu emulation" on/off, but not sure it will solve your problem.
Just to be sure : do these versions of Adebog work on a real Falcon ?
Nicolas
frost
Postby frost » Wed Dec 07, 2016 3:38 pm
Adebug 2.13 works for sure on a real Falcon, but Adebug 1.0 may not work at all.
My blog, mostly about Atari and demo stuff.
npomarede
Postby npomarede » Wed Dec 07, 2016 3:59 pm
I just tried adebug 2.13 reloaded http://files.dhs.nu/files_coding/adb_2_13.zip and I was able to change window's start address using 'a' and adebog didn't hang.
In my case, CPU is set to cycle accurate 68030 and MMU is disabled ; when adebog starts it issues some MMU commands, which are ignored when MMU is disabled, so maybe MMU emulation in Falcon mode is not complete yet and gives some error in the case of Adebog when MMU is enabled.
Nicolas
Postby Eero Tamminen » Wed Dec 07, 2016 7:00 pm
Maartau wrote:I can't use ADebog 1.0/2.11/2.13 in Falcon Mode under Hatari : it loads but when entering an address, it hangs :shrug: .
Which Hatari version you're using?
Maartau
Postby Maartau » Wed Dec 07, 2016 9:03 pm
:oops: ...forget to write : Hatari 2.0.0
Maartau
Postby Maartau » Wed Dec 07, 2016 9:13 pm
:D Thanks Nicolas :D ! :D
I tried with your options : and yes it works now :D ! :D !
I'm totally newbie with Hatari, now I must see how to define the Keyboard mapping :)
npomarede
Postby npomarede » Wed Dec 07, 2016 9:28 pm
Note that it also worked when I tried later with MMU enabled too, so I'm not sure what was wrong in your settings.
Return to “Hatari”
