Can you map a joypad button to a keyboard key?
GrethTom
Postby GrethTom » Sat Mar 26, 2016 5:15 pm
Hi all, in Hatari, can you map a joypad button to a keyboard key? I know spacebar is already hard coded and works well. Here would be my perfect setup on my 360 controller if its possible:
Select button = Esc
Start button = F12
Checked the manual and cannot find anything specific.
GrethTom
Re: Can you map a joypad button to a keyboard key?
Postby GrethTom » Sun Apr 10, 2016 10:50 am
For anyone interested, after a bit of playing I got it working. I will go through the steps used on the RetroPie and hopefully it may be useful to someone. This link was a good starting point: http://blog.petrockblock.com/forums/top ... re-button/
First download source files for hatari:
cd RetroPie-Setup
sudo ./retropie_packages.sh hatari sources
then go to:
sudo nano /home/pi/RetroPie-Setup/tmp/build/hatari/src/joy.c
Within line 200 section:
static bool Joy_ReadJoystick(int nSdlJoyID, JOYREADING *pJoyReading)
Add the following for F12 on Start button (on XBOX 360 controller):
   if (SDL_JoystickGetButton(sdlJoystick[nSdlJoyID], 9))
      Dialog_DoProperty();
Add the following for Escape key on Select button (on XBOX 360 controller):
   if (SDL_JoystickGetButton(sdlJoystick[nSdlJoyID], 8))
      sdlevent.type = SDL_KEYDOWN;
      sdlevent.key.keysym.sym = SDLK_ESCAPE;
      sdlevent.key.keysym.mod = KMOD_NONE;
      SDL_PushEvent(&sdlevent);
      sdlevent.type = SDL_KEYUP;
Once done, save the file then we have to build hatari:
sudo ./retropie_packages.sh hatari build
and finally
cd /home/pi/RetroPie-Setup/tmp/build/hatari
sudo make install
Make sure you reboot and should be good.
coverilla
Postby coverilla » Thu Feb 02, 2017 8:59 am
Thanks for your guide
During the build there were some errors:
/home/pi/RetroPie-Setup/tmp/build/hatari/src/joy.c:218:3: error: ‘sdlevent’ undeclared (first use in this function)
at first sdlevent.type should be sdlEvent.type
secondly you are missing variable declaration:
Behind the:
You should insert:
        SDL_Event sdlEvent;
after these changes build was successful.
Return to “Hatari”
