Hatari 1.9 and Minix: it just works
marcello
Postby marcello » Fri Feb 26, 2016 11:10 am
I've uploaded a disk image of the Minix OS 1.5 for the Atari ready to be used for Hatari.
http://subsole.org/minix_on_the_atari_st
Seems a bit unstable, but I think it comes from Minix iteself at it was never that stable on the 68000 due to lack of real MMU
I don't see any illegal instructions or the like from the shell where I started hatari
STMint, try Unix on your 68000 Atari http://subsole.org/st_mint
tritonus
Re: Hatari 1.9 and Minix: it just works
Postby tritonus » Wed Mar 02, 2016 10:57 pm
Hi all,
I can confirm this, Minix is running wih Hatari 1.9 again.
By the way, someone interested in Minix 2.0.2 / 2.0.4 for Atari-ST?
- tritonus
marcello
Postby marcello » Sat Mar 05, 2016 8:40 am
tritonus wrote:Hi all,
- tritonus
would be nice but surely a lot of work !
BTW are you aware of 1.6.25 ?
http://www.beastielabs.net/minix.html
tritonus
Postby tritonus » Sat Mar 05, 2016 2:28 pm
The work is done, I've got 2.0.2/4 up and running.
- tritonus
marcello
Postby marcello » Sat Mar 05, 2016 5:01 pm
Yes if you have a disk image I would be intersted
If you habe a github link to the source would be nice to ? Did you test it on real hardware ? Does TCP / IP work ?
tritonus
Postby tritonus » Sun Mar 06, 2016 10:39 pm
Yes, it runs on real hardware, and yes, TCP/IP is working (via rs232).
Okay. Give me some time to prepare a disk image.
- tritonus
marcello
Postby marcello » Mon Mar 07, 2016 7:01 am
ok, thx I'd be curious
iceman
Postby iceman » Mon Mar 07, 2016 10:57 am
tritonus wrote:Yes, it runs on real hardware, and yes, TCP/IP is working (via rs232).
- tritonus
Sign me up, I'm interested in trying it on my MiST.
Atarian since 1989. Atari 1040STFM, 4MB 520STe with UltraSatan and Unitor N, A dodgy 1 MBSTe that bombs out after a few minutes, and a 14MB 48MHz Falcon 030 with NetUSBee and Soundpool 8 channel DAC. Plus my new MiST!
tritonus
Postby tritonus » Sun Mar 27, 2016 12:46 pm
A disk image is almost finished, it will be about 100MB.
How can I publish it?
- tritonus
marcello
Postby marcello » Sun Mar 27, 2016 1:06 pm
Hi Tritonus Thanks
You can put it on Dropbox, and create a shared link
Postby joska » Sun Mar 27, 2016 1:51 pm
tritonus wrote:A disk image is almost finished, it will be about 100MB.
I can host it at joska.atari.org if you like.
tritonus
Postby tritonus » Sun Mar 27, 2016 4:43 pm
I think it would be nice to put it on joska.atari.org. What do I have to do?
- tritonus
Postby joska » Sun Mar 27, 2016 5:32 pm
Pm sent.
tritonus
Postby tritonus » Wed Mar 30, 2016 8:35 pm
A disk image with Minix 2.0.2 and 2.0.4 is on joska.atari.org:
http://joska.atari.org/minix
- tritonus
rabindranath72
Postby rabindranath72 » Tue Jul 05, 2016 12:32 pm
Fantastic stuff! I don't have any Atari hardware to work with anymore, but I am interested in the converted sources if they are available in .tar format, as I still have an Amiga 1200+68030 adapter, and I am working on porting 1.6.25 to this platform. A further step might be to port 2.0.2/4.
A.
marcello
Postby marcello » Mon Aug 15, 2016 12:40 pm
Hi Tritonus
Just boot the stuff on Hatari works great ( fortunately I speak german so I could read some of the debug messages :)
BTW how did you port thje whole sutff, did you cross compile or did everything locally ?
I also noticed that Minix is quite picky about FS errors, after a hard reset of hatari, the file system was damaged and fsck failed, leaving me with an error ( cann handle V2 file systems and an unbootable system) Have you seen such a problem ?
jotego
Postby jotego » Wed Sep 28, 2016 2:24 pm
tritonus wrote:A disk image with Minix 2.0.2 and 2.0.4 is on joska.atari.org:
- tritonus
Thank you!
Having these images ready to use are a great help to newcomers like me!
Return to “Hatari”
Users browsing this forum: Bing [Bot] and 1 guest
