Midres 60Hz pixel timing
RA_pdx
Postby RA_pdx » Tue Feb 11, 2014 8:42 pm
It seems that the pixel timing in 60Hz midres is not accurate. Everything is shifted by three pixels compared with a 1040STE and a MegaSTE. You can see this while using sync stuff and color stripes.
I can provide a test program if you need.
>> > raZen/Paradox < <<
Atari 1040STE, TOS 2.06, 4MB, MC68010, IDE 8GB SSD, Gigafile
Re: Midres 60Hz pixel timing
Postby Eero Tamminen » Wed Feb 12, 2014 8:36 pm
RA_pdx wrote:It seems that the pixel timing in 60Hz midres is not accurate. Everything is shifted by three pixels compared with a 1040STE and a MegaSTE. You can see this while using sync stuff and color stripes.
Nicolas is the one that needs to look at this, but test program makes things always easier. First to verify that the problem can be reproduced. :-)
RA_pdx
Postby RA_pdx » Thu Feb 13, 2014 8:38 am
Thanks, Eero. I will write him a PM with the test program tonight.
>> > raZen/Paradox < <<
Return to “Hatari”
