Commandline --fast-forward
Postby Cyprian » Fri Oct 11, 2013 1:08 pm
when I start Hatari with that command line, FastForward and FrameSkip works as expected:
hatari.exe --fast-forward 1 --frameskips 5
in case of that command line FastForward and FrameSkip doesn't work
hatari.exe --fast-forward 1 --frameskips 5 -c ..\Hatari\cfgSTE.cfg -W
Do you have any ideas?
Re: Commandline --fast-forward
Postby Eero Tamminen » Fri Oct 11, 2013 9:04 pm
Is the fast forward disabled in the config file you give after the --fast-forward option?
I.e. does it work, if you give the config file as first option?
Postby Cyprian » Fri Oct 11, 2013 11:31 pm
Eero Tamminen wrote:Is the fast forward disabled in the config file you give after the --fast-forward option?
fast forward isn't disabled in the config file and it works when there is no other parameters in the command line.
Eero Tamminen wrote:I.e. does it work, if you give the config file as first option?
ok, that was a good hint.
I've tried a different sequences of commands and finally ended up with working one:
hatari.exe --parse Profiler_App_Load.ini -c ..\Hatari\cfgSTE.cfg --fast-forward 1 --frameskips 5 -W ..\..\_Twardziel\STray01\stray.tos
Postby Eero Tamminen » Sat Oct 12, 2013 8:43 am
Fast forward option can be specified on:
- command line
- configuration file
- debugger (script)
- remote API
Fast forward is affected also by frame skip option as that limits how many consecutive vsyncs can be ignored by fast-forwarding. Nothing else can affect it as can be seen from Hatari sources by grepping for "FastForward" and code around lines checking/setting that.
Does the debugger script specify anything about fast forward? Or does the debugger script or config file specify smaller frame skips value?
Return to “Hatari”
