Embedding images into wiki problems
Check out the Atari Forum Wiki
catmando
Postby catmando » Wed Jul 20, 2011 4:44 pm
Have successfully uploaded a bunch of images to the wiki, however I am struggling to embed them into an update I've done on the discovery cartridge, I'm using the correct [[Image:Example.jpg]] method and correct file name but they just appear as listed files within the post and they don't even link to the pictures? Any ideas?
Atari STFM
Re: Embedding images into wiki problems
Postby Dal » Wed Jul 20, 2011 4:49 pm
Try:
[[File:Example.jpg]]
catmando
Postby catmando » Wed Jul 20, 2011 4:57 pm
Dal wrote:Try:
Nope that don't work either, same issue
Atari STFM
catmando
Postby catmando » Wed Jul 20, 2011 5:46 pm
Solved it, wasn't bloody using UPPERCASE for the file extension, doh!
Atari STFM
catmando
Postby catmando » Wed Jul 20, 2011 10:55 pm
catmando wrote:Solved it, wasn't bloody using UPPERCASE for the file extension, doh!
Well I thought it was solved, there seems to be something weird going on with the case of the file extension when a file gets uploaded, all the pictures I've uploaded have had lower case file extensions, yet when they appear in the upload list it seems to be jumping around between upper and lower case which causes a hassle when you come to name the picture within the wiki image tag. Also I've noticed with the larger image files say 3mb or above do not load onto the screen when you select them from the upload list, I was trying to find a way to delete or replace them but since you can't see the image it makes it impossible to update it.
Atari STFM
catmando
Postby catmando » Thu Jul 21, 2011 12:22 pm
Forget this, just noticed it's the program I'm using to scale down the images from the digital camera that was changing the file extension case, doh!
catmando wrote: Also I've noticed with the larger image files say 3mb or above do not load onto the screen when you select them from the upload list, I was trying to find a way to delete or replace them but since you can't see the image it makes it impossible to update it.
This bit still stands though
Atari STFM
Return to “Wiki Discussions”
