GameBaseST archive download problems
Moderators: Goldrunner, SkylineDave, Moderator Team
unseenmenace
Postby unseenmenace » Sun Jan 15, 2006 9:56 pm
How many of you have had trouble downloading the multi-part zip of the archive from my website? It seems that somehow the .zip and .z02 files have got corrupted and they won't download properly. I have PM'd Silver Surfer who uploaded the multi-part zip for me in the first place but if he doen't have it any more then I'll re-zip and re-upload the whole thing from the working files on my hard drive. One way or another I'll get it sorted.
UNSEEN MENACE
Lynx 2 and Jaguar with JagCD
Goldrunner
Guardian of the PaST
Postby Goldrunner » Mon Jan 16, 2006 9:00 pm
Hi Unseen
Part 0 and Part 1 are downloading with exactly the same file name, which is GBST v1.2b Archive. zip. This means Part 0 is overwritten if the user saves to the same location for each file (which is probably everyone) making the archive useless. Part 1 should be downloaded as GBST v1.2b Archive. z01.
unseenmenace
Postby unseenmenace » Mon Jan 16, 2006 10:08 pm
Someone else reported this behaviour a while back but I have been unable to reproduce it. Have you tried refreshing the page in case its using an old one from the cache? I know some people had managed to download the multi-part archive from my site before. The problem I'm encountering now is simply that the part 0 (.zip) and part 2 (.z02) get approx half way through downloading and then get a file error. Part 1 (.z01) downloads perfectly ok for me and with the correct filename.
EDIT:-
Just tried downloading part 0 again and it worked fine. Which is odd since I haven't changed anything. I'll try parts 1 and 2 as well and let you kknow what happens.
UNSEEN MENACE
Goldrunner
Postby Goldrunner » Mon Jan 16, 2006 10:15 pm
Refreshed it but the same happens :!: Oddly when you run the mouse pointer over Part 1 it correctly says GBST v1.2b Archive. z01 in the bottom status bar of IE, but when you try and download Part 1 it's back to GBST v1.2b Archive. zip
unseenmenace
Postby unseenmenace » Mon Jan 16, 2006 10:56 pm
Have you tried a different browser? I have successfully downloaded parts 0 to 6 so far this evening (using Firefox) and fingers crossed it'll extract correctly. I still don't get how come you can't get part 1. I'll keep you posted.
UNSEEN MENACE
unseenmenace
Postby unseenmenace » Tue Jan 17, 2006 11:17 am
OK, I managed to download the whole archive and then tried to extract it and got an error. Then I looked at the parts and noticed one (.z09) was only 9MB instead of 48MB. I redownloaded it and this time I got all 48000KB. This time it extracted perfectly giving a single 1.1GB zip file which I then successfully tested in Winzip. I can only assume this is down to problems with my hosting causing downloads to stop prematurely. Make sure all parts of the multi-part zip are exactly 48000KB apart from part 0 (.zip) which should be 46492KB. As for the problem you've been having getting sent the wrong file for part 1, I still can't replicate this and I've got no idea whats going on :?
UNSEEN MENACE
Goldrunner
Postby Goldrunner » Thu Jan 19, 2006 11:24 am
Hi Unseen
This is incredably strange, I have just tried downloading Part 1 from work and got the same GBST v1.2b Archive. zip instead of GBST v1.2b Archive. z01. I suspect that this may be down to Internet Explorer which are the latest versions of both my home and work computers. I am also running XP Pro on both machines, will try a different browser sometime tonight to see if it still happens!
unseenmenace
Postby unseenmenace » Thu Jan 19, 2006 4:03 pm
Solved it. Not my fault thank f&^%. Read the following link for an explanation of an annoying "feature" (read BUG!!!!) of Internet Explorer:-
http://www.ericsson.com/mobilityworld/sub/open/technologies/parlay/docs/parlay_cd
Rename the file with the extension .z01 and then re-download the first part (.zip) and it should all work fine :)
UNSEEN MENACE
Goldrunner
Postby Goldrunner » Thu Jan 19, 2006 4:14 pm
Begining to think I'd lost the plot somewhere, don't you just love Microsoft :roll: Maybe it would be a good idea to add a note about this on your site :!:
Postby Mug UK » Thu Jan 19, 2006 4:16 pm
Or distribute it on DVD .. much easier :)
nobogod
Postby nobogod » Thu Jan 19, 2006 6:23 pm
I just can't believe that some people still use ie.
But, please, don't take it personally :)
Goldrunner
Postby Goldrunner » Thu Jan 19, 2006 7:50 pm
Me, take it personally :cry:
unseenmenace
Postby unseenmenace » Fri Jan 20, 2006 1:31 am
Goldrunner wrote:Maybe it would be a good idea to add a note about this on your site :!:
Done
http://www.unseenmenace.net/gamebasest
UNSEEN MENACE
Goldrunner
Postby Goldrunner » Fri Jan 20, 2006 11:16 am
That should clear everything up for the poor people who still use IE, I may finally change my browser this coming weekend once and for all. BTW, well done tracking down the problem it could not have been easy!
unseenmenace
Postby unseenmenace » Fri Jan 20, 2006 12:49 pm
Actually it wasn't hard to figure out what it was doing as every file is exactly 48000KB apart from part 0 (.zip), so when I tried to download part 1 (.z01) it seemed to save part 0 but I noticed it was exactly 48000KB instead of 46492KB so I figured it must just be naming it wrong. A file comparison with the original part 1 (.z01) confirmed that they were the same file so I did a bit of googling and found out about this wonderful "feature". 8O
UNSEEN MENACE
keili
Postby keili » Fri Jan 20, 2006 1:24 pm
The right name was displayed, if you've moved the mouse over the link.
.zip appears after selecting 'Save as...'. I had no idea why, so i didn't post a comment. And i already have the complete archive, no download needed here.
TI 99/4A, C64, 800XL, 260ST, 520ST, 520ST+, 1040ST, 1040 STE, Mega ST1, Mega ST2, Mega STe, Apple IIsi
