Frontier: Elite II on 48MHz Falcon runs too fast
All about ST/STE games
iceman
Postby iceman » Mon Oct 31, 2016 4:38 am
I remember reading back when Frontier: Elite II was released that it would use faster CPUs to produce smoother graphics. Now this definitely is the case, but the game appears to be running too fast (the music is too fast and the animations are too).
Has anyone else noticed this on their accelerated machines?
Atarian since 1989. Atari 1040STFM, 4MB 520STe with UltraSatan and Unitor N, A dodgy 1 MBSTe that bombs out after a few minutes, and a 14MB 48MHz Falcon 030 with NetUSBee and Soundpool 8 channel DAC. Plus my new MiST!
Re: Frontier: Elite II on 48MHz Falcon runs too fast
Postby AtariZoll » Mon Oct 31, 2016 9:21 am
It works 20% faster when video is at 60Hz, music playback too. I don't see any bigger speed up on TT for instance, or in emulator set to much higher clock than 48 MHz. I would say that it is well coded. What accelerator is in yr Falcon ?
I'm not against GMO, I'm against that children play with fire.
Postby shoggoth » Mon Oct 31, 2016 9:25 am
The culprit is not the faster CPU, it's the vertikal blank frequency.
iceman
Postby iceman » Fri Nov 04, 2016 10:27 pm
Thanks guys, you're legends. How do you control the vblank frequency? I'm using a VGA monitor.
Ragstaff
Postby Ragstaff » Sat Nov 05, 2016 4:42 am
Very simple, decompile the game and rewrite 3d routs ;-)
iceman
Postby iceman » Sat Nov 05, 2016 6:55 am
Thanks Ragstaff, give me a couple of hours and I'll put it up for download.
There's always one, isn't there? :lol:
Postby shoggoth » Sat Nov 05, 2016 8:23 am
I've done this once :-P
The game tick time reference is called from the VBl handler. All you need to do is to add a Timer C handler (200Hz), and call it every 4th time from there.
iceman
Postby iceman » Sat Nov 05, 2016 9:03 am
shoggoth wrote:I've done this once :-P
I might attempt it, but not with one of the most tightly coded games of all time.
Fortunately, there looks like there's a little AUTO folder program that should switch the mode from 60 to 50 Hz. I'll try that and report back when I get home on Sunday.
Postby AtariZoll » Sat Nov 05, 2016 9:05 am
Of course, that's not so simple. It may be that timer C is used by game already for some other purpose - and works not at 200Hz. Then some graphic glitches may appear when it is not tied to V-blank, so much more changes may be needed.
I just checked it - and Timer C is regular (as in TOS), so it is worth of try. I promise that will not disassemble whole game :D
It may be longest game executable - 580KB, btw.
Ah, and you can not change refresh rate to 50 Hz when in VGA mode.
Postby shoggoth » Sat Nov 05, 2016 10:43 am
AtariZoll wrote:Of course, that's not so simple. It may be that timer C is used by game already for some other purpose - and works not at 200Hz.
Of course it IS that simple. I said I've done it once. Screen flipping is not tied to the game timer in FE2.
iceman
Postby iceman » Sat Nov 05, 2016 11:02 am
AtariZoll wrote:Ah, and you can not change refresh rate to 50 Hz when in VGA mode.
Fortunately, I have a TV sat on the same desk. The only issue might be finding a good old fashioned RF cable.
Postby AtariZoll » Sat Nov 05, 2016 12:14 pm
I'm not sure what you done once - Frontier , or some other game. If it is Frontier, why not post patch here.
And if did not and if it is so simple why not doing it right this weekend ? :D
Return to “Games - General”
