Atari-Forum on CAB
News, updates, like or dislike
TheNameOfTheGame
Atari-Forum on CAB
Postby TheNameOfTheGame » Fri Jan 31, 2014 4:05 am
Is there a low-bandwidth version of the forums to login with CAB?
When I use my 4MB Ste with CAB it always runs out of memory and crashes at the Board Index.
I have pictures turned off and monochrome set. But still it runs out of memory.
TheNameOfTheGame
Re: Atari-Forum on CAB
Postby TheNameOfTheGame » Fri Jan 31, 2014 4:35 am
Ok, I reduced my NVDI caches and after loading Magic and Jinnee I have ~1700KB free from my 4MB and now I can load the forums without crashing. :D (barely hahaha)
So now when I go to login, it fails and says "transaction failed"
Is this because I don't have the ssl overlay? Or something else?
I am trying to get to grips with this so I appreciate any help.
paul92706
Postby paul92706 » Fri Jan 31, 2014 5:07 am
TheNameOfTheGame wrote:Is there a low-bandwidth version of the forums to login with CAB?
Hi there, i also had a few memory issues with CAB, i switched off to Highwire and it runs nicely!
TheNameOfTheGame
Postby TheNameOfTheGame » Fri Jan 31, 2014 5:21 am
Well rIght now I am trying to understand cab. I will be sure and try highwire after I learn all about cab :)
Using Magxnet 1.4.2b and the cab.ovl from the magxnet root folder I can connect to internet sites (google, atari forum, etc) with cab but as I mentioned I have a problem logging in to atari forum.
I then tried the overlay from the magxnet "misc" folder but it won't connect at all. I am not sure what this overlay is.
Then I downloaded the SSL cab overlay at http://freemint.de/en/?net and tried it but I get a "file not found" error when I try to load a web page.
So I am left with the default overlay from the magxnet distribution. Is there any reason I can't log in to the forums with this?
Postby Dal » Fri Jan 31, 2014 7:13 am
Are cookies enabled? Authentication fundamentally works by associating a session with a user.
viking272
Postby viking272 » Fri Jan 31, 2014 7:20 am
Maybe try on another phpBB forum site that is very plain /out the box?
This will test if the problem is native to these sites or its the rich content on AF?
TheNameOfTheGame
Postby TheNameOfTheGame » Fri Jan 31, 2014 1:49 pm
Dal wrote:Are cookies enabled? Authentication fundamentally works by associating a session with a user.
Yes, cookies are enabled.
calimero
Postby calimero » Fri Jan 31, 2014 4:59 pm
does phpBB have mobile version?
Hippy Dave
Postby Hippy Dave » Fri Jan 31, 2014 10:17 pm
I use Seamonkey (similar to Firefox) on a PC and do not need cookies when logging in to atari-forum. I consider this a plus for atari-form and the software it runs on.
TheNameOfTheGame
Postby TheNameOfTheGame » Sat Feb 01, 2014 3:12 am
I logged into atari-forum from my STe :)
I installed the magxnet Stik gateway Glue_Stik and switched out the magxnet cab.ovl with the Stik one and it worked!
But it does use more memory than the IConnect gateway (which I disabled) so I am treading on thin ice with regards to memory with it.
But all is not perfect because when I try to post a message it says "transaction failed". I wish I knew what is causing it.
But it is progress so I am encouraged. Plus the telnet client for Stik is smooth. I checked out darkforce-bbs and it worked great.
christos
Postby christos » Sat Feb 01, 2014 10:02 am
CAB and Highwire are not suited anymore for the more modern websites. I would use a text based browser like lynx on the ST. If you turn off pictures and you can't load the css, what's the point of using a graphical browser?
There is definitely a mint port of lynx, I wonder if someone can port it to TOS/Magic as well.
My Atari blog
TheNameOfTheGame
Postby TheNameOfTheGame » Sat Feb 01, 2014 5:48 pm
Ah well the point of the exercise is just to do it :D I have fun trying to get all this working! I left Atari around 1995 and went PC (ugh) so some of this software I never got to try!
I have my PC for modern computing. I am not leaving it. But, I have my Atari room set up for fun! 8-Bit and 16-Bit eras. I enjoy pushing the old hardware and seeing what it can do.
When I set my falcon/ct60 up I am definitely going to run MiNT. But for my lowly(ha) 4mb STe, I just want to see what I can get it to do! :cheers:
Thank God for Atari-Forum! Without the resources and help I get here I would never have gotten my Atari back to where it is!
kristjanga
Postby kristjanga » Mon Feb 03, 2014 6:57 am
please give us a video of your STe browsing the internet :)
Return to “Website Discussions”
