What's this Falcon board?
Re: What's this Falcon board?
Postby Lynxman » Sun Feb 19, 2017 11:05 am
catmando wrote:
joska wrote:It can only be used with 1Mb or 4Mb in the normal RAM slot. It offers 4Mb or 8Mb of "alt-RAM".
What happens if you have 14mb in the normal ram slot?
The Falcon Magnum needs a driver to work.
I tried what happen if 14MB and Magnum is installed.
As long as the Magnum driver is not loaded the Falcon works. I tried only GEM and started some small programs, no big testing.
If driver is loaded it will not work.
Postby Rustynutt » Fri Apr 21, 2017 8:05 pm
An assembly programmer (sorry to forget your name but thanks for the help) sent me code to compile an org that told TOS where TT ram was located and amount on a Mighty Sonic years ago. Prolly basically the same. In this card, address was same as TT. Purpose was to discover basically what NVDI did all along :)
