Teradesk Redraw Issue
jvas
Postby jvas » Tue Jan 31, 2017 5:10 pm
With the latest version of Teradesk
, I have issues with redrawing the desktop:
https://youtu.be/n9FRMO6xSZE
This is MiNT 1.19 / XaAES / NVDI / CT60.
The Thing desktop doesn't have this behavior. Any idea?
Thanks,
Jozsi
paul92706
Re: Teradesk Redraw Issue
Postby paul92706 » Tue Jan 31, 2017 10:53 pm
I haf this issue to, i just converted to Thing myself. Hey jvas i seen your stresstest video how did you get Doom and Quake to run in that hi-resolution? I only get it to output from Videl.
Postby wongck » Tue Jan 31, 2017 11:40 pm
My take is this:
This is because those are dialog boxes rather than real windows.
( i.e. dialogs boxes inside a window frame)
Any movement for real dialog boxes does not make a full screen redraw.
Change it to flying dialogs instead, sure you do not get real-time redraw with that.
Also you are moving a Teradesk object (dialog box) and the icons are under control of teradesk, so Teradesk should issue itself a redraw for the icons.
jvas
Postby jvas » Wed Feb 01, 2017 6:26 am
paul92706 wrote:I haf this issue to, i just converted to Thing myself. Hey jvas i seen your stresstest video how did you get Doom and Quake to run in that hi-resolution? I only get it to output from Videl.
I don't know what you exactly mean. They run in windows instead of fullscreen, because I set the "SDL_VIDEODRIVER" environment variable to GEM instead of XBIOS.
But none of them is quake (doom, heretic, hexen)
jvas
Postby jvas » Wed Feb 01, 2017 6:30 am
wongck wrote:My take is this:
Will do it and report it back. But if this functionality doesn't work, it should be either removed or fixed :)
Another thing: If I set the listing mode to show icons (showing icons in the directory window instead of filenames), the icons are overlaps. Looks really ugly.
Faucon2001
Postby Faucon2001 » Wed Feb 01, 2017 10:47 am
You can set the icons spacing in the desktop preferences.
Philippe
jvas
Postby jvas » Wed Feb 01, 2017 11:10 am
Faucon2001 wrote:You can set the icons spacing in the desktop preferences.
Doesn't that affect the icons in the desktop only? Does It also affect the icons in the directory window too?
Postby wongck » Wed Feb 01, 2017 11:38 am
both
jfl
Postby jfl » Wed Feb 01, 2017 12:31 pm
I don't think you're talking about the same thing. What I see in the video is a TosWin2 window being moved above a desktop background that isn't properly redrawn. Which is not normal. Is Teradesk being locked by some modal dialog?
Jean-François
GEMDict – GEMClip
jvas
Postby jvas » Wed Feb 01, 2017 12:47 pm
There is no modal dialogs.
All windows are doing the same when moving (not just TosWin2).
Postby joska » Wed Feb 01, 2017 1:05 pm
jfl wrote:What I see in the video is a TosWin2 window being moved above a desktop background that isn't properly redrawn. Which is not normal. Is Teradesk being locked by some modal dialog?
That's not relevant. The desktop is never redrawn by the application, the desktop RSC object is always redrawn by the AES itself. The only way the application can do this is by putting USERDEFs in the desktop RSC.
I don't remember if Teradesk has it's own icon redraw code. Maybe it does, to draw colour icons in TOS? If that is the case, then this redraw problem might be related to the icon spacing jvas also reported. Maybe the colour icon USERDEF only draws the part of the icon that's within the defined spacing. So maybe this problem can be fixed by simply adjusting the icon spacing to match the actual icon size.
mfro
Postby mfro » Wed Feb 01, 2017 1:35 pm
I assume you use a nonstandard (!= 32 pixel) icon size?
If yes, this is the culprit. You'll need to adapt the icon grid size in Options->Window options.
jvas
Postby jvas » Wed Feb 01, 2017 2:13 pm
mfro wrote:I assume you use a nonstandard (!= 32 pixel) icon size?
That is possibly true. I'm using this icon-set: http://firebee.org/fb-bin/news?action=f ... N&offset=0
Postby wongck » Wed Feb 01, 2017 3:33 pm
jvas wrote:There is no modal dialogs.
Then it is not right. Any other windows movement will sent redraws by the AES to other applications.
Postby wongck » Wed Feb 01, 2017 3:35 pm
mfro wrote:If yes, this is the culprit. You'll need to adapt the icon grid size in Options->Window options.
I changed the icon grid to half the default values and I get the same clipped off icons on both the desktop and windows. Icons are all smashed together anyway so it looks real bad.
So this seems the likely culprit.
Well spotted! :thumbs:
paul92706
Postby paul92706 » Thu Feb 02, 2017 5:02 am
ah ok, oh my bad i though it was doom/quake sorry! :lol:
jvas
Postby jvas » Thu Feb 02, 2017 4:46 pm
Changing height/with of grid did the trick. Strange thin: it is called ICONH and ICONW in teradesk.inf.
Users browsing this forum: paul92706 and 4 guests
