MyAES
paul92706
MyAES
Postby paul92706 » Tue Jan 17, 2017 9:32 pm
Hi guy's i wanted to know do you any of you expierience window drag lagg while in desktop? I am using Mint 1-19/ MyAes.94 and my system is a Falcon/CT63/CTPCI/Radeon. I am expierienceing window drag lagg when i move a window around the screen in the desktop, seem's like it not as smooth like XaAES. I have no problems with silky smooth dragging of windows using XxAES! maybe there's a setting in MyAes i need to adjust? thanks guy's
OL
Re: MyAES
Postby OL » Wed Jan 18, 2017 6:23 am
paul92706 wrote:Hi guy's i wanted to know do you any of you expierience window drag lagg while in desktop? I am using Mint 1-19/ MyAes.94 and my system is a Falcon/CT63/CTPCI/Radeon. I am expierienceing window drag lagg when i move a window around the screen in the desktop, seem's like it not as smooth like XaAES. I have no problems with silky smooth dragging of windows using XxAES! maybe there's a setting in MyAes i need to adjust? thanks guy's
The fix is simple, use the official 0.96 patch2 (with full 0.96) version it work fine in this configuration you are around 6 years late!
I have also a 0.97 on my desk but unstable on Firebee so for the moment not realeased
http:myaes.lutece.net
OL
paul92706
Re: MyAES
Postby paul92706 » Wed Jan 18, 2017 4:53 pm
Thanks OL, wow .97! Hope that will be released soon. Keep up the good work OL!!
jury
Re: MyAES
Postby jury » Thu Jan 19, 2017 7:03 am
OL wrote:I have also a 0.97 on my desk but unstable on Firebee so for the moment not realeased
You can always release it now, with a note that its not for Firebee and relaease the Firebee version when it will be ready! :)
Especially that soon I'm planning to set MyAES on my new Falcon installation, so why go with the old 0.96? ;)
vido
Re: MyAES
Postby vido » Thu Jan 19, 2017 7:10 am
jury wrote:You can always release it now, with a note that its not for Firebee and relaease the Firebee version when it will be ready! :)
After 0.97 there will br 0.98, ... release. So you will have a parctise for the next releases ;)
paul92706
Re: MyAES
Postby paul92706 » Thu Jan 19, 2017 11:26 pm
Anyone having problems with Mint/MyAES .96 and ScummVW? I am getting a bus error, but with Mint/XaAes no problem. Anyone have similar problems!
OL
Re: MyAES
Postby OL » Sat Jan 21, 2017 12:36 pm
paul92706 wrote:Anyone having problems with Mint/MyAES .96 and ScummVW? I am getting a bus error, but with Mint/XaAes no problem. Anyone have similar problems!
Do you use the version that you can find here?
http://ol.lutece.net/
Olivier
OL
OL
Re: MyAES
Postby OL » Sat Jan 21, 2017 12:38 pm
Probably not, if it not work on firebee should have a more complex issue somewhere, I have done so many change to work on 68000 and ST resolution, that probably this version is not enough tested.
Olivier
OL
OL
Re: MyAES
Postby OL » Sat Jan 21, 2017 12:44 pm
You are true, it's already more than 6 month I should release it and I have near not progressed.
If someone want test it really on 68K computer you can take the 68000 version put in minimal Hatari multitask configuration, that I have promoted here:
http://www.atari-forum.com/viewtopic.php?f=51&t=29989
just extract myaes68k.prg file and replace in 0.96 should work, there is not a lot of difference of speed between 68060 version and 68000 version.
Olivier
OL
paul92706
Re: MyAES
Postby paul92706 » Sat Jan 21, 2017 9:03 pm
Olivier
yes i installed the version from your website.
OL
Re: MyAES
Postby OL » Sun Jan 22, 2017 12:36 pm
Olivier
This is with an old SDL lib, to work you should add environment variable:
SDL_VIDEODRIVER=gem
you can add it in mint.cnf adding:
setenv SDL_VIDEODRIVER gem
or in my aes.cnf
export SDL_VIDEODRIVER=gem
If it not solve the issue I don't know it work fine for me and SDL work nicely on CT60 + Radeon with gem driver
Olivier
OL
paul92706
Re: MyAES
Postby paul92706 » Sun Jan 22, 2017 5:51 pm
Hi, OL
looks like i don't have the SDL-libs were can i download this at?
jury
Re: MyAES
Postby jury » Sun Jan 22, 2017 6:02 pm
You do not need any SDL-libs unless you will want to code SDL stuff. All SDL libs are linked into an executable, so all you need is just run it :) ( after setting the SDL_VIDEODRIVER variable as Olivier pointed )
OL wrote:Probably not, if it not work on firebee should have a more complex issue somewhere, I have done so many change to work on 68000 and ST resolution, that probably this version is not enough tested.
OK, I will install this old 0.96 then :) ( and wait for 97 patiently )
paul92706
Re: MyAES
Postby paul92706 » Tue Jan 24, 2017 6:17 am
[quote="jury"]You do not need any SDL-libs unless you will want to code SDL stuff. All SDL libs are linked into an executable, so all you need is just run it :) ( after setting the SDL_VIDEODRIVER variable as Olivier pointed )
hi jury, yes i have SDL_VIDEODRIVER in myaes.cnf! i still have problem. strange
jury
Re: MyAES
Postby jury » Tue Jan 24, 2017 11:26 am
Is this SDL_VIDEODRIVER pointing to "=gem" or "=xbios"?
I will try to swap my Super Videl to CTPCI with Radeon this weekend and see if I have this issue also.
paul92706
Re: MyAES
Postby paul92706 » Tue Jan 24, 2017 7:14 pm
i have this listed on MYAES.CNF:
thanks jury! :cheers:
OL
Re: MyAES
Postby OL » Sun Jan 29, 2017 4:49 pm
jury wrote:You do not need any SDL-libs unless you will want to code SDL stuff. All SDL libs are linked into an executable, so all you need is just run it :) ( after setting the SDL_VIDEODRIVER variable as Olivier pointed )
Yes it is better to be patient, I can reproduce some issue here so really something is wrong in this test version, I'm currently looking at it.
Olivier
OL
OL
Re: MyAES
Postby OL » Sat Feb 04, 2017 10:42 pm
you can find beta version here, wait for some answer but fix some big issues.
http://myaes.lutece.net/telechargement/ ... _beta1.zip
Olivier
Olivier
OL
