Alternate TT hi/VGA adapter
CodeKiller
Postby CodeKiller » Sun Jul 24, 2016 4:06 pm
I have made a few devices for the Atari TT to connect to a regular VGA monitor.
- has a switch to change between standard color-VGA or the mono high-rez (the computer restarts after switching).
- needs only 5V DC though a standard mini-B USB connector (easy to use with phone charger)
- compact and boxed (inside there are some bodge, but not visible from outside)
- high-rez mode has Horizontal-fix; standard VGA mode does not affected by it.
- fully tested
- only 50€ a piece :) (+6€ shipping)
Re: Alternate TT hi/VGA adapter
Postby shoggoth » Sun Jul 24, 2016 6:43 pm
Nice! Picture quality looks good too (no ghosting) :)
Postby Cyprian » Sun Jul 24, 2016 7:10 pm
CodeKiller wrote:I have made a few devices for the Atari TT to connect to a regular VGA monitor.
- fully tested
one device pls.
EmpireAndrew
Postby EmpireAndrew » Sun Jul 24, 2016 7:33 pm
I'd like one how do I order?
1977 VCS Heavy Sixxer (Boxed)
1993 Atari Falcon030, 14MB, Int 8GB HDD, TOS 4.04 -> Atari PTC1426 Color CRT Monitor
Amiga, Mac, DOS, SGI, Sun, NeXTStation, PDA's and more!
CodeKiller
Postby CodeKiller » Sun Jul 24, 2016 8:09 pm
Video quality mostly depends on your monitor of choice (for some CRTs it may have low output current(?) -- darker screen), if pixel-accurate mode not available at least the moire patterns have to dealt with (maybe some VGA cables can cause ghosting, but not sure..)
The pic has been taken from a monitor of a friend -- my samsung tv/monitor makes that checkerboard flat gray after fiddling with the setting, but still clearly readable.
I have 7 pieces to sell, please PM me if you'd like one.
jvas
Postby jvas » Tue Jul 26, 2016 12:23 pm
I have one and it works great! Thanks CodeKiller!
CodeKiller
Postby CodeKiller » Fri Aug 05, 2016 1:49 pm
5 pieces are still available -- PM if interested!
Bama
Postby Bama » Fri Aug 05, 2016 2:58 pm
PM sent.
BAMA
EmpireAndrew
Postby EmpireAndrew » Wed Aug 10, 2016 11:20 pm
I can confirm it works...
(turn on HD in the youtube settings cogwheel below):
TT High on standard LCD
tenox
Postby tenox » Thu Aug 11, 2016 8:55 am
Nice!
EmpireAndrew
Postby EmpireAndrew » Thu Aug 18, 2016 1:50 am
Hmm, well mine has just died I think...
I bought a new monitor and tried plugging it in via the adapter and while it continues to work fine in anything up to ST High or TT medium, the TT high mode is not working any more.
The display is mono, but the resolution doesn't change from TT medium, and the monitor display is massively distorted.
I plugged the previous working in TT high monitor back in and same issue...
I think one of the connectors on the adapter is slightly loose now. It was always a tight fit on the cable so you had to push quite hard when plugging it in, but I wasn't careful about it (forgot!) when plugging the 2nd monitor in.
I suspect something is disconnected inside...
CodeKiller
Postby CodeKiller » Thu Aug 18, 2016 7:41 am
I'm sorry to hear that!
I think it may be a problem with the power connector. Can you wiggle it a little? If that's not helps, could you send a picture of the inside (focusing on the usb connector)?
--Wait a bit-- if the ST/medium modes works fine, then that can't be power problem
"The display is mono, but the resolution doesn't change from TT medium," -- so it means the monitor still get 640x480 mode (by H/V sync signals) but the actual pixels are monochrome (maybe garbage)? In that case the mode select (pin9 to TT) may be not connected.
Do you plug it directly to the TT and then whatever cable to your VGA monitor or the adapter sits between two cables? (b/c standard VGA cables may lack pin9 altogether)
EmpireAndrew
Postby EmpireAndrew » Thu Aug 18, 2016 11:30 am
OK, the plot thickens...
Good detective work!
I didn't know some cables don''t have pin 9 (every day is an education!) so I switched back to the original monitors VGA cable as well (I was using original monitor with new VGA cable after new monitor failed to work I switched the monitor back but not the cable) and now the monitor is reporting 1280x960 at 72khz and 72hz. (it was reporting 640x480 at something like 31KHz etc). So that's an improvement, the monitor is at least being told the correct info. But now the display is black basically. Still works in TT-Medium/ST-High though.
CodeKiller
Postby CodeKiller » Thu Aug 18, 2016 11:41 am
Could you send a picture of the screen? (in medium and in hi-rez too)
Have you tried to plug the adapter directly to the atari TT?
(does your monitor has a voltage-range selection? tried to change it? (if i remember correctly, there may be 1Vpp and 0.7Vpp options))
EmpireAndrew
Postby EmpireAndrew » Thu Aug 18, 2016 12:29 pm
It's plugged directly into the back of the TT.
I don't recall seeing a voltage adjustment on either of my monitors.
I'll video it when I get home from work.
It was working with this monitor, cable and USB power cable and power adapter. It only stopped when I unplugged it and plugged in the new monitor. I'm suspecting a loose conn crook inside it, most likely at a socket. I'll photo the inside too.
panderpaw
Postby panderpaw » Wed Aug 24, 2016 6:43 pm
Is still possible to order one?
CodeKiller
Postby CodeKiller » Thu Aug 25, 2016 1:06 pm
panderpaw wrote:Is still possible to order one?
Yes, the last one is still available, please PM me.
vhenares
Postby vhenares » Wed Sep 07, 2016 7:03 am
Thank you
CodeKiller
Postby CodeKiller » Wed Sep 07, 2016 7:54 am
Sorry, just sold the last one.
But if there are 3-4 more people interested, I can order parts for another batch and build them.
nobox
Postby nobox » Wed Sep 07, 2016 8:01 am
I am interested, too.
vido
Postby vido » Wed Sep 07, 2016 8:19 am
And me too!
Mark_G
Postby Mark_G » Wed Sep 07, 2016 8:42 am
I'm also interested.
CodeKiller
Postby CodeKiller » Wed Sep 07, 2016 10:24 am
Ok, then i will order parts :)
It will take for 1-2 months however..
DOB
Postby DOB » Wed Oct 26, 2016 5:11 pm
I'm interested. Keep us posted on your progress with the next batch.
Cheers,
dOb
Mark_G
Postby Mark_G » Wed Oct 26, 2016 9:25 pm
Any progress ?
