PH PDF Maker beta 3
PH PDF Maker beta 3
Postby wongck » Thu May 05, 2016 3:12 pm
PH PDF Maker beta 3a is available for download from PHSW site.
Beta 3a:
Corrects misalignment of numeral in spreadsheet cell of Atari Works.
Some minor bugs fixes.
New Features in beta 3:
  1. Works with NVDI 3, 4, 5 & SpeedoGDos 5.0c, 5.7. See notes in ZIP file for details. (NVDI 5 is still clipping)
  2. True Colour 24-bits graphics support for real life colour reproduction in PDF.
  3. Selectable output resolution up to 300 dots per inch.
  4. Select from 12 standard PDF paper sizes for your PDF output.
  5. Compressed PDF for smaller file size.
  6. Secured PDF support with password encryption and read/open password.
  7. Protected PDF support by restriction control for copy, printing and editing.
Features from previous version:
  1. Creates PDF file simply by printing from an application via normal GDOS printer settings.
  2. Support VDI output function for graphics text, outline text, circle, polyline, rectangle and coloured filled area (closed poly line).
  3. Support Generalized Drawing Primitives (GDP) bar, arc, pieslice, circle, arc and ellipse.
  4. Support text effects such as bold, italic, outline, underline, rotation, colour, font scaling, superscript and subscript.
  5. Support VDI colour mapping for supported graphics objects, lines, texts and filled objects.
  6. Support TrueType fonts for nice font face output.
  7. Support Latin accents as defined by standard Atari character set (i.e. via keyboard).
Go to Probe House Software Atari software download page.
Enjoy.
TheNameOfTheGame
Re: PH PDF Maker beta 3
Postby TheNameOfTheGame » Thu May 05, 2016 3:59 pm
Nice work! :cheers: Sorry to hear NVDI 5 is still clipping text.
gstoll here on the forums has looked at the NVDI sources (see this page at the bottom: http://toshyp.atari.org/en/010005.html). Maybe he can offer some advice on the problem or look at the sources again if Oliver Buchmann will allow it to shed more light on the issue.
OL
Postby OL » Thu May 05, 2016 4:03 pm
You are an incredible guy
Thanks so much for your work
Olivier
wongck wrote:PH PDF Maker beta 3 is available for download from PHSW site.
Enjoy.
OL
Playmobil
Postby Playmobil » Thu May 05, 2016 4:25 pm
Great Job man !
Faucon2001
Postby Faucon2001 » Thu May 05, 2016 5:28 pm
Wow, genial. I have to test it !
Philippe
Postby wongck » Thu May 05, 2016 11:02 pm
Thanks, hope it is useful for at least one person. Overall it was enjoyment for me to do this.
One thing to note - true colour graphics takes obscene amount of memory and cpu cycles (depending on standard or device VDI format). So just be vary of the JPG you add into Papyrus or the size of the IMG you add to Atari Works.
Postby Dal » Thu May 05, 2016 11:14 pm
Wow - great job!
Faucon2001
Postby Faucon2001 » Fri May 06, 2016 12:07 am
Just a quick feedback, with no luck. It crashes under Aranym+TOS4.04 + SPDGDOS 5.0c when I try to print with Works and Phpdf.prg refuses to launch. What is the difference between the softs in main folder and the ones in the 68000 folder: I have tried both and had the same result ?
May be also something to do with my working TOS setup which has suffered a lot recently? I'll try to build a new one and see.
Philippe
kni
Postby kni » Fri May 06, 2016 5:07 am
wow ! great! good work !
some Falcons, some STe's, some ST's, some STacy's, some Jaguars, some Lynx's and one TT :mrgreen:
kni
Postby wongck » Fri May 06, 2016 5:11 am
Faucon2001 wrote:What is the difference between the softs in main folder and the ones in the 68000 folder: I have tried both and had the same result ?
The one outside the folders are 68020-060 builds. I will make a note of this in the doc.
Faucon2001 wrote:May be also something to do with my working TOS setup which has suffered a lot recently? I'll try to build a new one and see.
As for the crashing, especially phpdf.prg, it should not as it defaults to some settings if there is no phpdff.dat file.
I just tested phpdf.prg with a old data file, and yes it does bombs out.
So please remove the old file for now, I will fix this bug over the weekend.
Postby wongck » Fri May 06, 2016 2:48 pm
The bug fix was easier than I reckon. So it is fixed and uploaded to my site.
Thanks for reporting.
gstoll
Postby gstoll » Sat May 07, 2016 6:20 am
TheNameOfTheGame wrote:gstoll here on the forums has looked at the NVDI sources (see this page at the bottom: http://toshyp.atari.org/en/010005.html).
This passage is from Rolf Kotzian the first author from the tos.hyp. I never see the sourcecode from MagiC or NVDI.
Gerhard
TheNameOfTheGame
Postby TheNameOfTheGame » Sat May 07, 2016 3:58 pm
Ah thanks Gerhard...I didn't know that history :cheers:
Maybe someone could contact Rolf to ask then?
Postby joska » Wed May 11, 2016 7:23 pm
I haven't tested it yet, as all my "high-end" Ataris are shelved ATM. But I think this is a supercool project, and also a very important one for us "serious" Atari-users.
PeterS
Postby PeterS » Mon May 16, 2016 8:54 pm
It's a genius idea, a pity more apps don't have better printer dialogues.
I installed and set assign.sys to use device 71 but couldn't get any pdf to generate from Everest (it lets you set the device). I also tried device 23. There is no c:\phpdffnt.dat either.
I don't think it's detecting the nvdi fonts which are installed in c:\btfonts and c:\ttfonts
Log file:
a V_OPENWORK Speedo v0 0 fonts 0dpi
VQ_EXTEND 1 c5=[0]
a Pline done = 0
a V_UPDATEWORK
a V_CLEARWORK
a Pline done = 0
a V_UPDATEWORK
a V_CLEARWORK
a Pline done = 0
a V_UPDATEWORK
a V_CLEARWORK
a Pline done = 0
a V_UPDATEWORK
a V_CLEARWORK
a Pline done = 0
a V_UPDATEWORK
a V_CLEARWORK
a V_CLOSEWORK
VQ_EXTEND 1 c5=[0]
VQ_EXTEND 1 c5=[1]
VQ_SCRINFO i0=[2] c5=[1]
VQ_EXTEND 1 c5=[1]
a WRITE_MODE 1
a MARKER_TYPE 1 but set to 1 (dot)
a MARKER_COLOR 1
a V_CLOSEWORK
Postby wongck » Mon May 16, 2016 11:01 pm
From the logfile, You are using NVDI and the phpdf.acc is saying you are using Speedo.
Can you run phpdf.prg and see if the phpdff.log along with phpdffnt.dat are both generated ?
I think even if you get the phpdffnt.dat, there will not be any TTF fonts detected, as it just looks into c:\btfonts only.
So you may need to move your TTF into the c:\btfonts.
phpdf will read the font folder information from NVDI.INF file.
PeterS
Postby PeterS » Tue May 17, 2016 7:43 pm
I re-ran phpdf but these are the only files created on C:\
PHPDF.IDX
PHPDF.LOG
PHPDFF.LOG
In nvdi.cnf I have 2 font paths:
FIFPATH = C:\BTFONTS\
FONTPATH = C:\BTFONTS\
FONTPATH = C:\TTFONTS\
Postby wongck » Tue May 17, 2016 11:03 pm
And what does PHPDFF.LOG says ?
How many fonts do you have in your c:\btfonts ?
I did not know that you can have multiple FONTPATH statements in the NVDI.INF file.
PHPDF.PRG only reads the 1st one, my guess is that it does not contain any trutype fonts.
Postby wongck » Wed May 18, 2016 1:58 pm
Just a note, there is space for only 64 fonts... that's total fonts in the system.
I just tried with 100 fonts and PHPDF.PRG choked and save zero fonts.
Postby wongck » Wed May 18, 2016 3:20 pm
PeterS wrote:In nvdi.cnf I have 2 font paths:
So a quick fix by adding a TTF folder configuration in PHPDF.PRG, please select your 2nd C:\TTFONTS folder.
I also fix the more than 64 fonts, and the limitation is now PHPDF will only look at the 1st 64 TTF, even if you have 200 other fonts.
Download this version from the usual place.
PeterS
Postby PeterS » Thu May 19, 2016 7:31 pm
BT_Fonts contains folder totalling 40 fonts. TT_Fonts contains folders of 86 fonts.
I don't know how many FontPaths NVDI allows but I originally created 2 and then edited nvdi.inf to add the second path.
Thanks for the quick updates. I will give it a go.
The log file is as:
VQ_EXTEND 1 c5=[0]
a Pline done = 0
a V_UPDATEWORK
a V_CLEARWORK
a Pline done = 0
a V_UPDATEWORK
a V_CLEARWORK
a Pline done = 0
a V_UPDATEWORK
a V_CLEARWORK
a Pline done = 0
a V_UPDATEWORK
a V_CLEARWORK
a Pline done = 0
a V_UPDATEWORK
a V_CLEARWORK
a V_CLOSEWORK
VQ_EXTEND 1 c5=[0]
VQ_EXTEND 1 c5=[1]
VQ_EXTEND 1 c5=[1]
a WRITE_MODE 1
a MARKER_COLOR 1
a V_CLOSEWORK
Postby wongck » Fri May 20, 2016 8:08 am
Sorry i was asking for the logfile created by phpdf.prg called phpdff.log but I think it does not make one for you as it was not working 9probabgly due to too many fonts).
PeterS
Postby PeterS » Fri May 20, 2016 8:26 pm
Sorry, I should have realised there should be 2 log files.
I installed the new version and had some success, the fonts are loaded (below). I tried to print from Everest but Everest crashed out. On the second attempt the Milan hung so I had to reboot.
Nvdi v503
the font path = [C:\TTFONTS\]
number of scr fonts = [108]
Too many fonts [Penoir Normal]
Too many fonts [Playbill]
Too many fonts [QTButlerCaps]
Too many fonts [QTChaplin]
Too many fonts [QTVanGogh]
Too many fonts [Revenue Normal]
Too many fonts [Serpentine Bold]
Too many fonts [Stensil Normal]
Too many fonts [Symbol]
Too many fonts [Tarunda Normal]
Too many fonts [Tengwar Quenya]
Too many fonts [TiffBlack]
Too many fonts [Times New Roman]
Too many fonts [Times New Roman Bold]
Too many fonts [Times New Roman Bold Italic]
Too many fonts [Times New Roman Italic]
Too many fonts [Titanic Normal]
Too many fonts [TitanicOutline Normal]
Too many fonts [Toto Normal]
Too many fonts [Umpa Normal]
Too many fonts [Wingdings]
index=[ 1] ID=[1] [6x6 system font] TTF path=[*]
index=[ 2] ID=[5000] [Aapex] TTF path=[aapex.ttf]
index=[ 3] ID=[23686] [Aarcover (Plain):001.001] TTF path=[cap_____.ttf]
index=[ 4] ID=[9165] [Advertiser Normal] TTF path=[advert.ttf]
etc.
Postby wongck » Sat May 21, 2016 12:03 am
Yes, there are 2 log files
phpdf.log for the generation of pdf file - this one you should look at if it hangs/crashes for clues.
phpdff.log for the fonts information. At the end of the logfile, it reports number of font file found OK, and number not found.
Did it crash or freeze?
If you're using TOS, it should say run out of pool memory or something like that. Just means there's not enough ram to produce the pdf.
In my own testing, I found that NVDI 5 tends to produce more crashes than the older versions.
