Atari TT motherboard revisions: differences?
qq1975b
Postby qq1975b » Tue Feb 03, 2015 2:40 pm
I have two Atari TT each like each one of this link: http://www.mr2.net/marknias/atari_tt030.html
Both revisions are VERY different. Are they any known functional/technical differences between them? I mean relevant and compatibility/performance differences?
The one that is earlier revision gives me some problems with the same SCSI HDD that is fitted on the newer revision TT. It doesn't recognizes well the HDD when the other doesn't have any problem with it.
Trying to learn...
qq1975b
Re: Atari TT motherboard revisions: differences?
Postby qq1975b » Sat Feb 07, 2015 10:13 am
mmmm...on this earlier TT motherboard revision I have only made work a 50 PIN SCSI disc...no way to make work a 68 pin device.
An 80 pin HDD with adapter is not well detected: Loads HDDRIVER from itself but doesn't show any HDD attached :? :? :? Does anybody has similar issues with an early TT motherboard revision?
Trying to learn...
qq1975b
Postby qq1975b » Sat Feb 07, 2015 11:06 am
I am specially worried about the new CosmosEX with SCSI interface.... :(
Trying to learn...
qq1975b
Postby qq1975b » Mon Feb 09, 2015 12:21 pm
I have tried some SCSI HDD of 50 and 80 pin (with adapter) and I could only make work one old 50 pin SCSI HDD of 48MB :(
All the others didn't work properly...Sometimes the 9.1 GB 80 pin SCSI HDD that works perfect on my other Atari TT rev.K here it is detected...and sometimes is not detected... When detected it shows random partition numbers but in any case is useless because you can access to the partitions data. :(
Trying to learn...
Guest
Postby Guest » Mon Feb 09, 2015 2:31 pm
you need to add the revc board scsi patch its something to do with the vme bus
i have a few pics of where to add the kinar wires and connects
some pins to cut and raise
no components
also change the clock a little to better time the scsi bus
ill look out the rev c board scsi patch details for you
rev a had just a 68030 running at 16mhz no pal chips {beside the mpu}
then rev b was the same but had a better clock setup
and you can by this time add the 32mhz mpu daughter board it has the pal ics added to it
rev c came with a gold top mpu mounted to the pcb and the pal chips also on the pcb
all three revisions suffered from the scsi issue with ahdi etc
you can read about it on DEVDOCS there youll find all the service release details
{well some of them}
as i say i made up a photo set for the upgrade of the machine you have
revc
rev d-k has the scsi patch built to the tracks
qq1975b
Postby qq1975b » Mon Feb 09, 2015 3:17 pm
Thanks Sim :)
Mine is 32MHZ CPU.
Trying to learn...
Guest
Postby Guest » Tue Feb 10, 2015 12:35 am
yes
your machine is a REV C but hasnt had the scsi mod done to it
ill look now and find some pics for you
will take a day or two
you need also too be very precise
Guest
Postby Guest » Thu Feb 19, 2015 6:35 pm
i dont see three red resistor packs at the rear of the scsi socket fitted
you need them if you use one drive only
and you also need them if you use only the internal or only the external sockets
if you use both you dont need them but it wont really complain if they are there
so fit them and try again
first and last device terminated
so this terminates the controller end
and enable termination on the drive
this is the problem
frank.lukas
Postby frank.lukas » Thu Feb 19, 2015 7:58 pm
68 pin SCSI Harddisks work well with the right Adapter, but not all Drives, I had some fujitsu drives that will not work at all. Some Seagate and IBM work well. 80pin SCSI drives are tricky. The unused 8bit from the 16bit SCSI bus must be terminated by a 50/68 or 50/80 pin SCSI Adapter or the whole 16bit SCSI bus must be terminated ...
qq1975b
Postby qq1975b » Thu Feb 19, 2015 10:38 pm
On the later model motherboard SCSI was fine. All 80 pin hdd work well. The problem is the earlier rev one....no way to make them work ok. :(
Trying to learn...
Guest
Postby Guest » Thu Feb 19, 2015 11:16 pm
you posted a pic of some other board
does your TT machine with issues
have the three resistor packs mouned behind your scsi socket
if you have these packs in place
and you have issues
esp as you cant see to access any wide drives .. its plug in and ok... and not plug and play
you need to add the same scsi chip as a falcon has the -2 type or a TT rev perhaps j-K same ic
this gives access better perhaps propper access to scsi 2 {wide}
i have i think 3 that are aok {maybe 2 are good }
check the resistor packs are correct and mounted correctly the right way round etc
i can help its the same number as most 'logics ics' but has a little failt -2 on it in falcons
some old scsi isa card have the wide chip if they have a wide port
my falcon has one and my rev j TT has one . -2c sometimes has a c on the TT not digin out the falcon
there is a post far back by mr atari about it he had a few of them also ... the -2 type or 2c whatever
but the falcon handles scsi 2 and 3 far better
so your TT can to .. by adding the plug in chip
i bet you feel good now you know you dont need to solder scrap in
L53C80JC2 {the dash two }
53C80 or some other pre nambular addin
the JC2 is the bit... in the falcon
qq1975b
Postby qq1975b » Fri Feb 20, 2015 7:34 am
Yes...I am relieved that I don't have to solder anything :lol:
I will check it this afternoon! Thanks!
Trying to learn...
qq1975b
Postby qq1975b » Fri Feb 20, 2015 8:32 pm
It seems that the LOGIC chip is the same but there are not the resistors pack. Which ones are they, please? I will get them then
Later revision TT motherboard:
Earlier revision TT motherboard:
In this revision I don't see the back jumpers either...
Trying to learn...
Guest
Postby Guest » Sat Feb 21, 2015 6:09 am
hi
the res packs are 220/330 R 8 pin pin 8 + pin 1 -
they are arranged like this
8----/\/\/\/\....2
1..../\/\/\/\....2
8----/\/\/\/\....3
1..../\/\/\/\....3
8----/\/\/\/\....4
1..../\/\/\/\....4
8----/\/\/\/\....5
1..../\/\/\/\....5
8----/\/\/\/\....6
1..../\/\/\/\....6
8----/\/\/\/\....7
1..../\/\/\/\....7
https://www.google.co.uk/search?q=Thick ... 7gbn6IHIDw
here is a google search
youll find that jameco has them http://www.jameco.com/1/1/6729-4308r-10 ... 30ohm.html
or farnel etc
ebay i cant find any suitable ....
i did find this passthru terminator http://www.ebay.co.uk/itm/Active-50pin- ... 463509794e
but i think the main TT problem is you need to supply active termination voltage to the cable
this is i think why most of the drives you tried didnt work
as they require power to allow there termination to work correctly
and your other machine works ok because the controller is terminated
perhaps the drive you use has passive term... this applies to you frank also
this is prob why some drives you tried didnt work
so your ending up with no termination at all with your earlier machine
and no packs and no term power
check that the TMPWR pin 26 line on the scsi ribbon is being supplied with 5v active termination power
looking at the TT schematic pin 26 floats in all revisions... this is wrong
you need to modify the flat scsi cable or the machine
find its wire 26 and cut it then on the drive side you need to connect +5v via a diode and a fuse
or you can modify the socket adding the fuse and diode under the TT pcb to pin 26 scsi
to a +5v vcc source {like pin8 of any of the res packs}
use some sleaving to cover the mod and avoid shorting to the coating on the plastic base
as its conductive and also ground ....however usually there is a base card... to cover it {a must}
if you do this more types of drive will work {ones with no passive termination}
or ones that actually require this voltage
i recon any TT user should do this mod to there internal scsi socket
the falcon uses a diode and a 1amp fuse like this
vcc--->|---fuse---->> active term power
the diode is a 1n4001 1amp 50v piv
the fuse you can use a 1amp circuit protector {to92 package}
http://www.ebay.co.uk/itm/ICP-N25-Inter ... 3aa0c45cc3
youll get one far cheeper and faster from the local TV repair guy
as for the controller the one in the falcon has a 2 stamped on it in lite white.. ink
{not part of the chips numbers}
if you can fit the one from the falcon to the TT then perhaps again yet more drives become avalible
its a different ic revision to support scsi 2 more fully ?? or the chip is aok at certain data rates ..clocks
i made a little mod picture
qq1975b
Postby qq1975b » Sat Feb 21, 2015 11:00 am
I have pulled out the network resistors from the working TT and nows it has the same issue as the non working one. I will fit them on the other TT when I get home to have lunch. If it doesn't work I will try the mod.
These are the resistors...what differences are between the red and the black one? Can they been found in Aliexpress.com?
Trying to learn...
Guest
Postby Guest » Sat Feb 21, 2015 12:01 pm
same resistor
im sure it will work
i would do the mod to both tt machines infact all TT machines
then the internal port will work better with later drives
qq1975b
Postby qq1975b » Sat Feb 21, 2015 12:40 pm
with the resistors the HDD is working fine! :D
I only need to find some network resistors :p
Trying to learn...
qq1975b
Postby qq1975b » Sat Feb 21, 2015 12:50 pm
Trying to learn...
Guest
Postby Guest » Sat Feb 21, 2015 1:26 pm
qq1975b wrote:Will these work ok, please?
http://www.ebay.com/itm/200-pcs-RKL8B-2 ... 1c33606abb
hahahahahahahaha 200 pieces??? lol for 12 bucks
thats a bargain ..!! 197 spares
qq1975b
Postby qq1975b » Sat Feb 21, 2015 1:50 pm
didn't found any seller selling less :P
I'll get them then ;)
thanks Sim
Trying to learn...
Guest
Postby Guest » Sat Feb 21, 2015 2:34 pm
wait ill find you 3
mouser has them
http://www.mouser.es/Search/Refine.aspx?N=663897
so youll get them locally
http://www.mouser.es/Passive-Components ... ahZ1yzs1c5
will cost you like 10 euros tops !! they are around 70 euro cents each
perhaps you can take a bus and go get them or order on the phone or the net...
Contact Mouser (Barcelona) +34 93 6455263
qq1975b
Postby qq1975b » Sat Feb 21, 2015 3:39 pm
I have sent them an email to know if I can pick the items up instead of shipping them. They are near Barcelona and near where I work :thumbs:
Trying to learn...
qq1975b
Postby qq1975b » Sun Feb 22, 2015 11:14 am
I didn't see this topic that explains the same problem...sorry :(
Here it is to avoid other people make the same mistake: viewtopic.php?f=27&t=25478&p=268906#p268906
Trying to learn...
qq1975b
Postby qq1975b » Sun Feb 22, 2015 11:19 am
Going back to the topic subject....the two TT motherboards look very very different. All chips organisation is different. Was the rev A-C so bad that they had to change everything? Or was due only to the cost of each motherboard? (A-C was very expensive?)
No noticable or practical changes/differences between both motherboard designs?
Trying to learn...
Guest
Postby Guest » Sun Feb 22, 2015 9:45 pm
one thing i noticed with frank lukas rev d board he sent me to fix the scsi
was that one of the diodes on the battery supply to nvram had been shorted out
removed
this is to boost the voltage avalible by .6v to the nvram
so you can use a 2X1.5v cells 3v not 3.6 as the old cell was etc.
so doing this mod you can add modern 3v lithium {two 1.5vs}
