Last version of Logic Audio Falcon?
Knezzen
Postby Knezzen » Tue Jan 28, 2014 2:40 pm
Hi!
Im searching for the last version of Logic Audio Falcon. I have version 1.0 (IIRC) but have seen LAF 2.0 mentioned somewhere.
I have the LOG-3 dongle/MIDI-interface, so im not looking for any cracked version (if there exists one).
I tried to find a mirror of emagics old FTP server but couldn't find anything at all.
Marcer
Atarilegend
Atarilegend
Re: Last version of Logic Audio Falcon?
Postby Marcer » Tue Jan 28, 2014 3:55 pm
not sure if its Falcon version.. or ST version
here is Logic 2.5. it do need a dongel
- FTP... Ask for info
- Paradize (Chip Music)
- Elite (Atari Softs)
- The Legion (Demos)
- Alive Maggie Team
_/|\_YM-RockerZ_/|\_
Marcer
Atarilegend
Atarilegend
Postby Marcer » Tue Jan 28, 2014 4:07 pm
Logic Audio Falcon v2.01.. also need dongel
- Alive Maggie Team
Crash
Postby Crash » Fri Jan 31, 2014 10:15 pm
I was always hoping to find someone that could remove the dongle limitation from 2.5. I wanted to use it on at TT, and have several dongles btw, but due to timing differences it would rarely pass the copy protection check on most TTs. I think I only found one TT that would run Logic some of the time. It was soooooooooo much easier to use on a 19 inch high resolution screen.
Knezzen
Postby Knezzen » Sat Feb 01, 2014 5:43 pm
Crash wrote:I was always hoping to find someone that could remove the dongle limitation from 2.5. I wanted to use it on at TT, and have several dongles btw, but due to timing differences it would rarely pass the copy protection check on most TTs. I think I only found one TT that would run Logic some of the time. It was soooooooooo much easier to use on a 19 inch high resolution screen.
Strange. I have actually tested my LOG3 with two different TT's and haven't had any trouble at all with it. Rock solid on both of them.
BTW, using Logic 2.5 on the Falcon with SuperVidel is even sexier than it is on the TT ;)
Guest
Postby Guest » Sat Feb 01, 2014 11:10 pm
you can use a blowup adapter {66mhz TTL clock to the videl chips ext clock in from the video port}
strange it doesnt work on your TT
... works aok on this one
the last version i am sure i remember was 2.5.3
hightechjim
Postby hightechjim » Sun Sep 21, 2014 12:53 am
did anyone ever find Logic Audio Falcon? I sure would love a copy to finish my retro studio setup. If you know, would please email me at:
New Sound STudio
newsoundstudio@msn.com
edingacic
Postby edingacic » Fri Oct 27, 2017 1:57 pm
I am also having trouble with my TT030 sometimes I am able to pass dongle check and when it runs 2.5 is most unstable. It is strange because I have opened it and it says TT/F on the PCB and I have Log3. Anyone have this 2.5.3 version?
crashman
Postby crashman » Sat Oct 28, 2017 10:18 am
Hi everyone.
having a little bit of time, yesterday I tried to run Logic 2.5 in my TT with Log3 dongle, as i saw a post here and in a Facebook group from Edin Gadic,
where he explains that he has problems running it.
I managed to come by with 3 Log3 dongles.
I've opened them and I found that 2 were marked as Version F and one as version TT/F
On my first try, none were running, all has those kind of error:
I've tried from v.1.7 to 2.5, even Logic Audio.
Talking with Edin from what he has read, someone told about different TT timings.
So in my total ignorance in electronic details, I tried to add something between the Log3 and the TT.
Now that I think of it, if the timings on the TT needed the dongle to be faster, I was going the wrong way...
But well, let's stick on what I did.
I put a Key-Expander between the two,that expander has a white button.
I had to take out the Log3 PCB as the case didn't fit on the expander.
Switched for Slot 3 on Key-Expander, and tried to run the soft.
No luck at all.
Every version failed.
Then I thought: "haven't I a second Key-Expander?"
So here I am, putting two Key-Expanders between the Log3 and the TT.
Trying it again.
Ver 1.7 fails. It hangs, but no "key not found" error.
Ver 2.01 fails The same. It hangs, but no "key not found" error.
Logic Audio fails. Same "not a Falcon" and the audio error from before.
Ver 2.5 IT WORKS!!!
Well, perhaps it was luck, as Edin stated than he can sometimes run v1.7
I've tried around 10 times, always turning the TT On and Off, and every time it worked.
This was the F version.
On the first tries, I was changing the Slot number on the Key-Expander, but after 3 or 4 trys, I forget to do it.
So to my surprise, it was working, even without the correct Slot selected!
Then I tried the TT/F version of the Log3 dongle.
It also worked!
I tried the GM_Demo.log file that come with the software, and it worked perfectly.
The I tried the third Log3 ... no luck here.
The second F version, denies to run.
I've tried that dongle on an STE, and it worked flawlessly.
Then I try to run one of the working Log3 with only one Key-Expander, this time the one that has the black button.
And it worked.
Don't know why, as it seems it they have the same PCB.
Finally I've tried the other only thing that could seat between the Log3 and the TT, an Unitor-2 cartridge.
But no luck here.
As we were talking i saw that Edin has a Midex+, he tried that, but no luck also. That with the correct slot selected with the Cubase software.
I have no more TT's for trying, so well, here it ends my research for now.
I got them working, well, some of them, but Edin hasn't, so not all the happy that I could be.
Regards.
