Falcon Soundlifter
xfalcon
Falcon Soundlifter
Postby xfalcon » Wed Oct 20, 2010 4:03 pm
I have a falcon with a soundlifter bild in. The Soundlifter replace the on board sound sythem.
The soundlifter has two inputs.You can choose the inputs with a little software. I'm looking for this tool, but I can't find anywhere.
any ideas?
thanks
chris
Falcon030 14 MB+Dayna Port::MegaSt4+Hydra, Overscan & UltraSatanDisk
simbo
Re: Falcon Soundlifter
Postby simbo » Wed Oct 20, 2010 10:43 pm
if you can take some pictures of it perhaps the control system it uses can be ascertained
more fully
it maybe is just a byte or two to the right controller
to switch the usual control pins softhard maker use on the falcon
for hardware control
ill look through my software and see if i can find the acc
nativ
Postby nativ » Thu Oct 21, 2010 8:02 am
I don't know whether
Iphegny ? Will recognise the board? That's the only soud routing software I know of!
Regards
xfalcon
Postby xfalcon » Thu Oct 21, 2010 8:23 am
Here is a picture of the hardware
http://forum.atari-home.de/index.php?ac ... iew;id=201
An a description, but only in german.
http://www.stcarchiv.de/stc1994/11_falconhardware.php
@nativ
Iphegny is a tool for the DSP, right? Iphegny don't recognise the board. It can't use for soundlifter.
simbo
Postby simbo » Thu Oct 21, 2010 11:09 pm
Two of the sensitivity separately adjustable input pairs can be selectively used, the signal from the Yamaha sound chip, which has a blokkiert has input so far has been specially designed and located on the mini-jack output. Auf diese Art bleibt auch bei Benutzung von zB Cubase Audio der Tastaturklick auf Wunsch erhalten. In this way remains the use of Cubase Audio keyboard click on the request received. Die gewünschte Eingangsquelle kann per Software angewählt werden, was bei mir allerdings nicht immer funktioniert hat. The desired input source can be selected via software, but what I always did not work at.
Auf der Soundlifter-Platine findet man ausschließlich hochwertige Bauteile - und das hört man auch! On the sound board lifter can be found only high quality components - and you can hear that too! Der Falcon mit einem Soundlifter klingt um Welten sauberer als ohne! Sowohl der Frequenzgang ist entscheidend verbessert worden (siehe Abbildung) als auch die Signal/Noise-Ratio (Geräuschspannungsabstand), wobei wir hier nur mit einem ATARI-Falcon-TestKit den Höreindruck objektivieren konnten. The Falcon with a sound lift sounds worlds cleaner to than without! Both the frequency response has been markedly improved (see figure) and the signal / noise ratio (noise ratio), where we here a ATARI Falcon test kits the sound stage objectify could only . Ich hätte aber keine Bedenken, einen mit Soundlifter ausgerüsteten Falcon030 ohne weitere Zusatzgeräte wie Interface oder DAT-Recorder für eine CD-Produktion einzusetzen. But I had no concerns, equipped with a sound lift Falcon030 without additional interface devices such as DAT or CD recorder for production use.
i think it works via dsp addressing so any audio tool like cubase etc that addresses the dsp
will see this much like the soundpool tools are seen
this is a codec uses a crystal sound chip
{second sound card}
looking in other places i see there is a cookie it uses modifes Xbios calls
so.. the jury is out
i looked through all the software i have and no sign of its drivers or acc etc
ill look about and see if i can dig something up
nice bit of kit for sure...! LB :coffe:
xfalcon
Postby xfalcon » Fri Oct 22, 2010 11:42 am
simbo wrote:i think it works via dsp addressing so any audio tool like cubase etc that addresses the dsp
All audio-apps like CAF, Studio Son, A-Traker and so on..., working with the soundlifter, but only with one of the two inputs.
The software is only used to select the input source.
simbo wrote:ill look about and see if i can dig something up
thanks
chris
nativ
Postby nativ » Sun Nov 14, 2010 10:15 am
[quote="simbo"]
I guess after seeing the picture, that this device is very similar to an FA8, it was my understanding that the FA8 was mainly provided to output sound via the rca/phono jacks. I guess it too might have had two (a stereo pair) defined for input, I didn't see any options in Cubase for this only options for FDI or Jack input?
Could it be it is working? Are you able to generate an output from the ports previously used for input? Or generate a 6/8 channel output?
Regards
xfalcon
Postby xfalcon » Fri Nov 19, 2010 8:57 am
Thanks to all,
now i have found the tool.
:thumbs:
vhenares
Postby vhenares » Mon Nov 21, 2016 12:16 pm
Hello, can you tell me the program name for the Soundlifter card? Can you give me a link?
Regards,
Víctor
I live en Atari World TOS
NGFrankW
Postby NGFrankW » Sat Mar 04, 2017 12:55 pm
The SoundLifter tools sl_auto.prg and sl_ctrl.prg can be found here: http://forum.atari-home.de/index.php?topic=6563.0
From the sl_ctrl.txt (German):
--- snip ---
Kurzanleitung zu SL_CTRL / SL_AUTO
SL_CTRL und SL_AUTO dienen dazu, den zweiten Eingang des Codecs im Falcon,
der durch SoundLifter zug„nglich wird, auch mit Programmen zu benutzen, die
dafr eigentlich nicht vorgesehen sind. Dazu sind zwei Programme n”tig:
SL_AUTO.PRG geh”rt in den AUTO-Ordner Ihrer Bootpartition. Es installiert
sich im XBIOS-Trap und kann alle Programmbefehle, die den Eingang umschalten
sollen, abfangen und eigene Werte einsetzen. Nach dem Booten ist SL_AUTO erst
einmal inaktiv und st”rt die normale Funktion des Rechners nicht.
SL_CTRL kann wahlweise als Programm (.PRG) oder als Accessory (.ACC)
verwendet werden, indem man die Datei umbenennt. Als Accessory geh”rt es ins
Wurzelverzeichnis Ihrer Bootpartition (normalerweise C:), als Programm kann
es an eine beliebige Stelle kopiert und gestartet werden.
Mit SL_CTRL kann man einstellen, wie SL_AUTO sich verh„lt. Es gibt 2
M”glichkeiten:
- Inaktiv: Es wird der Eingang benutzt, den Ihr Digital-Audio-Programm
selber einstellt. Dies ist die Standardeinstellung nach dem Booten,
solange SL_CTRL nicht gestartet wurde.
- Aktiv: die Einstellungen des Digital-Audio-Programmes werden ignoriert,
und es werden die Eing„nge benutzt, die Sie in SL_CTRL einstellen. In
dieser Einstellung kann man den 2. Eingang auch mit Programmen benutzen,
die selber nicht die M”glichkeit haben, den Eingang umzuschalten.
Mit 'Sichern' werden die aktuellen Einstellungen von SL_CTRL aktiviert und in
die Programmdatei (SL_AUTO.PRG) gespeichert, so daž sie auch nach dem
n„chsten Reset erhalten bleiben. Dazu darf die Programmdatei nicht
schreibgeschtzt sein.
Die Einstellungen werden nach dem n„chsten Booten auch dann aktiviert, wenn
SL_CTRL noch nicht gestartet wurde.
SL_CTRL und SL_AUTO geh”ren zu SoundLifter von Thorsten Auweiler und drfen
nur auf Rechnern mit eingebautem SoundLifter benutzt werden.
(C) 1994 Michael Schwingen
--- snip ---
Best regards
Frank
