Daimakaimura (Ghouls 'n Ghosts) for the Atari STE
Postby Anima » Tue Apr 11, 2017 5:01 pm
At first I would like to say that I am not sure if the Atari STE will be able to have the power for a good port. Considering that the CPS1 system is clocked at 10 MHz (even worse: the ported game source code runs on a 12 MHz machine). Anyway, at least the Falcon will be definitely a good target but needs some gameplay code changes to get it running. Unfortunately they're playing with the stack frame data on certain places and this is clearly a no-go on the MC68030.
The game code has been ported using a special version of MAME in combination with a special disassembler which produce a source code which can be reassembled with vasm and reused by MAME. This was important to check if the code can be changed by adding/removing code parts. This method works for any MC68000 based games so theoretically almost anything running on that CPU can be ported "easily".
The Daimakaimura game code runs in the same address range like on the arcade machine so that (undetected, non-relocated) addresses hidden in the data area didn't break the game logic.
JagPad/PowerPad support is implemented so you can start and play the game. In fact, the gameplay is complete and "only" the sound and graphics are missing.
So let's have a look how far I can get.
Re: Daimakaimura (Ghouls 'n Ghosts) for the Atari STE
Postby shoggoth » Tue Apr 11, 2017 5:15 pm
Chuck Norris of code.
EvilFranky
Postby EvilFranky » Tue Apr 11, 2017 5:21 pm
Superb Anima.
EvilFranky
Postby EvilFranky » Tue Apr 11, 2017 5:37 pm
Anima wrote:Daimakaimura (Ghouls 'n Ghosts) for the Atari STE
Was this the reason why you gave up on the Final Fight (also a CPS1 game) Falcon port Anima? This rings a bell...
Just realised how many amazing games are running on CPS1 actually. Not all of them are candidates for ports obviously.
Estrayk
Postby Estrayk » Tue Apr 11, 2017 5:46 pm
Great News Anima! you are the master!
I know that its very soon for requests, but I'd like make a question about the sound & music. Also will be implemented? YM2151 emulator? without sound but with audio effects? If you decided launch it for Falcon, can be used the DSP for load the original music (like a sample) meanwhile we play?
thanks for your epic work!
MM41
Postby MM41 » Tue Apr 11, 2017 7:56 pm
Great ☺, thanks Amina !
CiH
Postby CiH » Tue Apr 11, 2017 10:30 pm
Whoo!
AtariCrypt
Postby AtariCrypt » Tue Apr 11, 2017 10:46 pm
Oh boy!!! :cheers:
Postby Anima » Wed Apr 12, 2017 9:24 am
EvilFranky wrote:Was this the reason why you gave up on the Final Fight (also a CPS1 game) Falcon port Anima? This rings a bell...
Yes, but also having a decompression/decryption routine at start was a problem for a straight forward disassembling of Final Fight on the X68000. That's, in fact, a good thing with a program stored in ROM: you don't have to fear self modifying code.
Estrayk wrote:I know that its very soon for requests, but I'd like make a question about the sound & music. Also will be implemented? YM2151 emulator? without sound but with audio effects? If you decided launch it for Falcon, can be used the DSP for load the original music (like a sample) meanwhile we play?
It depends what is possible on the specific system. For the Falcon I have same ideas based on an optimised version of the Cho Ren Sha 68k DSP sprite engine so that I could also think of adding sound emulation. But this is something for the future.
EvilFranky
Postby EvilFranky » Wed Apr 12, 2017 10:00 am
Thanks for the explanation Anima :cheers:
So actually the Final Fight CPS arcade board would be a better target for a conversion rather than the X68000 version, with some effort anyway. Interesting.
Postby Anima » Wed Apr 12, 2017 10:37 am
EvilFranky wrote:So actually the Final Fight CPS arcade board would be a better target for a conversion rather than the X68000 version, with some effort anyway. Interesting.
Yes that's correct. Well, a CPS1 "MMU emulator" for the Falcon is actually a tempting idea on the first look. At least it's a way less technically "demanding" system than the Neo Geo. Unfortunately a special MC68030 MMU approach will not work on accelerated systems.
dlfrsilver
Postby dlfrsilver » Wed Apr 12, 2017 11:43 am
Very interesting.... ok, so i guess that Strider X68000 for which i put my hands in also use the same decompression/decryption system......
Anima, do you plan to make the game code ressourced available ? Anyway that's a great idea :)
How much ram do the game will need on STE ? 4mb of ram ?
Postby Anima » Wed Apr 12, 2017 1:46 pm
dlfrsilver wrote:Anima, do you plan to make the game code ressourced available ? Anyway that's a great idea :)
I think there are two issues making the source code public. First it's still not completely relocatable and (even more important) there are legal questions about the copyright. Besides that, I'd like to share it, why not.
Regarding the memory requirement it'll need 4 MB RAM on the Atari STE for sure. The game code itself is 1 MB in size so there's not much space left for a scrolling double+background buffering. Also the sprites will take another huge chunk of RAM as well.
leech
Postby leech » Wed Apr 12, 2017 3:23 pm
This is awesome and has a lot of potential. Though if it basically uses MAME code (if I'm misunderstanding this, please tell me), does that mean it would need the rom from the arcade to play? in which case the actual source code for the modified MAME should be freely distributable, right?
(Oh, maybe re-reading that, it sounds like MAME was used to disassemble the original ROM and then its source was modified, which is absolutely brilliant, though I also would think that any patches to the source could be distributed, just not the actual source, which would need to be disassembled by anyone who wants to work on this modification, right? Yeah, you're right, that gets into weird legal areas).
Postby Anima » Wed Apr 12, 2017 4:15 pm
leech wrote:(Oh, maybe re-reading that, it sounds like MAME was used to disassemble the original ROM and then its source was modified, which is absolutely brilliant, though I also would think that any patches to the source could be distributed, just not the actual source, which would need to be disassembled by anyone who wants to work on this modification, right? Yeah, you're right, that gets into weird legal areas).
The MAME source has been modified so that it will save telemetry data when the game is running. This telemetry data and the program ROM are being processed by a special disassembler which produces a real source code of the program.
Here's an actual snippet:
L_00016dca:
    cmpi.b  #$2,$50dc(a5)                           ; [00000001] 00016dca: 0c2d 0002 50dc
    beq.b   L_00016df4                              ; [00000001] 00016dd0: 6722
    move.w  d0,d5                                   ; [00000001] 00016dd2: 3a00
    jsr     L_00002184.w                            ; [00000001] 00016dd4: 4eb8 2184
    beq.b   L_00016df4                              ; [00000001] 00016dd8: 671a
    addq.b  #$1,-$766c(a5)                          ; [00000001] 00016dda: 522d 8994
    addq.b  #$1,$50dc(a5)                           ; [00000001] 00016dde: 522d 50dc
    jsr     L_000026dc.w                            ; [00000001] 00016de2: 4eb8 26dc
    bsr.w   L_00016e32                              ; [00000001] 00016de6: 6100 004a
    add.w   d5,d5                                   ; [00000001] 00016dea: da45
    move.w  L_00016df6(pc,d5.w),d5                  ; [00000001] 00016dec: 3a3b 5008
    jmp     L_00016df6(pc,d5.w)                     ; [00000001] 00016df0: 4efb 5004
L_00016df4:
    rts                                             ; [00000001] 00016df4: 4e75
L_00016df6:
    dc.w    L_00016e74-L_00016df6
    dc.w    L_00016ed4-L_00016df6
    dc.w    L_00016f9c-L_00016df6
    dc.w    L_00016f14-L_00016df6
L_00016dfe:
    cmpi.b  #$2,$50dc(a5)                           ; [00000001] 00016dfe: 0c2d 0002 50dc
    beq.b   L_00016e28                              ; [00000001] 00016e04: 6722
    move.w  d0,d5                                   ; [00000001] 00016e06: 3a00
    jsr     L_00002184.w                            ; [00000001] 00016e08: 4eb8 2184
    beq.b   L_00016e28                              ; [00000001] 00016e0c: 671a
    addq.b  #$1,-$766c(a5)                          ; [00000001] 00016e0e: 522d 8994
    addq.b  #$1,$50dc(a5)                           ; [00000001] 00016e12: 522d 50dc
    jsr     L_000026dc.w                            ; [00000001] 00016e16: 4eb8 26dc
    bsr.w   L_00016e32                              ; [00000001] 00016e1a: 6100 0016
    add.w   d5,d5                                   ; [00000001] 00016e1e: da45
    move.w  L_00016e2a(pc,d5.w),d5                  ; [00000001] 00016e20: 3a3b 5008
    jmp     L_00016e2a(pc,d5.w)                     ; [00000001] 00016e24: 4efb 5004
L_00016e28:
    rts                                             ; [00000001] 00016e28: 4e75
L_00016e2a:
    dc.w    L_00016ea4-L_00016e2a
    dc.w    L_00016ef4-L_00016e2a
    dc.w    L_00016fcc-L_00016e2a
    dc.w    L_00016f34-L_00016e2a
As you can see, the source is formatted and even jump tables are being detected and resolved. Unfortunately, there are still some dirty tricks in the code which will definitely lead to a crash when "moving" the whole program to a different address.
Reassembling this source with vasm without any changes will produce an identical program ROM and this can be reused by the modified MAME.
So what's different in the code on the Atari STE? Actually some program code below $800 has been moved to a higher address location and the exception vectors for the VBL and HBL have been hijacked. The Atari STE VBL now draws some red blocks, the JagPad/keyboard input is being processed and then it calls the original code. That's basically all.
dlfrsilver
Postby dlfrsilver » Wed Apr 12, 2017 5:27 pm
there's another thing : This game takes a lot of memory, because all the game is directly accessible.
Are you planning to make the game loading only the needed parts for each level ? This will also allow to reduce seriously the amount of colors without making the graphics too much painful to convert in term of palette.
Postby Anima » Wed Apr 12, 2017 6:24 pm
dlfrsilver wrote:there's another thing : This game takes a lot of memory, because all the game is directly accessible.
That's right. The main problem here is to find out which tiles will be used at what stage. Sometimes sprites will be reused on later levels just only with a new palette.
dlfrsilver
Postby dlfrsilver » Wed Apr 12, 2017 6:51 pm
I think i can do something here :)
What i propose, is to make an excel file for each tile bank, and then indicate like :
Sprite level 1
Sprite level 3
Sprite level 5
Boss sprite part 1
Background level 1 Background level 5
Foreground level 2 Background level 3
I can do that puzzle, by indicating you the tile word references, that are stored inside the game code. That's easy in the capcom games. But it can also take a bit of time. but it's doable.
Oh and the best, i have started a while ago to extract each tile part, and then via a specific mame version, extract the palettes, and then use a tilemapper, which allowed me to get the tile sheets exactly like how the capcom guys have them in their archive service :)
on the palette side, it's going to be fun, because basically, the arcade machine is doing palette changes very often ingame. using the same thing but applied to the 16 colors palette of the ST would be very cool, graphically and technically.
dlfrsilver
Postby dlfrsilver » Wed Apr 12, 2017 7:03 pm
oh and a good new : each sprite has a fixed palette of 16 colors. The palettes changes are done on the backgrounds.
NGF
Postby NGF » Wed Apr 12, 2017 7:25 pm
Awesome project!
Anyhow, why not use the original ST versions music for the STE, it's pretty good actually for ST standards and then use the arcade versions sfx?
Then maybe the Falcon is able to playback more "advanced" music.
Postby Anima » Wed Apr 12, 2017 8:13 pm
dlfrsilver wrote:What i propose, is to make an excel file for each tile bank, and then indicate like :
Sprite level 1
Sprite level 3
Sprite level 5
Boss sprite part 1
Ok, that sounds interesting. Are you also able to find out which sprites/tiles will be flipped horizontally and/or vertically? This is quite important because it increases the graphics memory usage by a good margin.
In respect of the graphics I'm about to extend MAME to create images out of the sprites with a realtime mapping to a given 16 colours palette. This data will be used later on to create the compiled Blitter sprites.
NGF wrote:Anyhow, why not use the original ST versions music for the STE, it's pretty good actually for ST standards and then use the arcade versions sfx?
That sounds like a good idea.
dlfrsilver
Postby dlfrsilver » Thu Apr 13, 2017 6:39 am
Well all the sprites are at least flipped horizontally in ghouls'n'ghosts. What do you plan, keeping the routine which flip the sprite frames, or do you need to have the sprites already flipped ?
Just tell what you need.
That sounds like a good idea.[/quote]
Or transcoding the YM2151 partitions data to make the music working on the STE YM chip ?
Postby Anima » Thu Apr 13, 2017 7:47 am
dlfrsilver wrote:Well all the sprites are at least flipped horizontally in ghouls'n'ghosts. What do you plan, keeping the routine which flip the sprite frames, or do you need to have the sprites already flipped ?
When you're certain that you can sort out the tile/sprite usage of each stage than I'll try to include all flipped sprites as well. Other assets can be loaded when the level changes.
I guess the 4 MB will be filled up quite easily without a loading strategy. The ugly part is that all TOS related variables and other stuff is killed in the lower address range so I will have to restore that before getting access to the OS file functions. However, I think this will be still fast enough to be a viable solution.
Postby Anima » Sat Apr 15, 2017 4:00 am
First sprite extracting attempts:
EvilFranky
Postby EvilFranky » Sat Apr 15, 2017 8:56 am
How are you going to approach the limited STE 16 colour display Anima? Will be a challenge converting...
Return to “Games”
